How To: Unbrick Your Bricked Graphics Card/Fix a Failed BIOS Flash - Page 31 - Overclock.net - An Overclocking Community
post #301 of 306 (permalink) Old 05-06-2019, 03:36 PM
frer8833's Avatar
Rep: 0
I have palit (dual fan) gtx 1060 6gb and i flashed it with a bios for Palit (jetstream) gtx 1060 6b, and the display started acting up, flickering and stuff and then i restarted the PC and now the card doesn't post (i write this using iGPU). I reflashed back to correct bios that i found on techpowerup.com but still not problem solved.
Edit: ok, the problem was old bios from 2016 (not compatible with new nvidia drivers and windows 10), i reflashed a new bios from 2018 (unverified from techpowerup) and now gpu works again.
frer8833 is offline
post #302 of 306 (permalink) Old 05-14-2019, 12:55 PM
Rep: 0
Hello I've a problem, I tried to OC my 980ti with asus gpu tweak 2 and it brokes my GPU, it isnt detected anymore (even if the fans are still working as 100% speed) so I cant use nvflash or anything.
Is there any fix ?
Thanks you guys !
Saokkei is offline
post #303 of 306 (permalink) Old 06-07-2019, 03:02 PM
Screwball's Avatar
Rep: 4 (Unique: 4)
I am getting Adapter not found Error: 0FL01
Any help?
Screwball is offline
post #304 of 306 (permalink) Old 10-27-2019, 04:39 PM
Rep: 0
Any help?
Me too, i can not find bricked GTX 1070 graphic adapter number !!
command
Nvflash --list
n1m1abc is offline
post #305 of 306 (permalink) Old 02-01-2020, 10:57 AM
Rep: 0
Hello, when flashing my xfx rx-480 4gb has been blocked and I have a black screen in any of the two bios that I select, I have installed in a computer with integrated graphics and it does not start the bios. I tried with a bridge on pins 1-8 of one of the bios chips or on the other or both at the same time and the same result constantly restarts the computer without arriving to load the bios of the motherboard. I'm lost and I don't know how to fix it, if anyone has any ideas I appreciate it.
rafa68 is offline
post #306 of 306 (permalink) Old 03-28-2020, 03:03 PM
Rep: 0
How to get it to recognize the adapter?
Quote: Originally Posted by ploy View Post
<div class="quote-container" data-huddler-embed="/t/593427/how-to-unbrick-your-bricked-graphics-card-fix-a-failed-bios-flash/240#post_26173301" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Screemi</strong> <a href="/t/593427/how-to-unbrick-your-bricked-graphics-card-fix-a-failed-bios-flash/240#post_26173301"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Hi<br><br>
i already posted in the polaris bios mod thread but found this one while googling. maybe it's the better place to discuss my problem<br><br>
no i found the following quote in the comments of the 8-1 pin method:<br>
that seems to be the case for my card. does anybody have an idea how to fix it apart of the pin shortening?<br><br>
if not i have to go the pin route. does anybody have an idea where the bioschip of the strix 480 is located? after some googling i found a picture of the back of the pcb but the resolution is not that high. i marked the ic i suspect to be the bios.<br><br><a class="H-lightbox-open" href="https://www.overclock.net/content/type/61/id/3062255/"><img alt="" class="lightbox-enabled" data-id="3062255" data-type="61" src="https://www.overclock.net/content/type/61/id/3062255/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><br>
€dit:<br><br>
I tried atiflash 4.17 from 2013 but i get a "adapter not found". any other dos versions i can try?<br><br><br>
€dit: i used every force string available with atiflash and what can i tell you: The freaking Card is up and running again!!!! should have tried that earlier. already got my solder iron ready <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"><br><br><a class="H-lightbox-open" href="https://www.overclock.net/content/type/61/id/3062329/"><img alt="" class="lightbox-enabled" data-id="3062329" data-type="61" src="https://www.overclock.net/content/type/61/id/3062329/width/350/height/700/flags/LL" style="; width: 350px; height: 177px"></a></div>
</div>
Was that the correct chip? Which is pin 1 and pin 8?
How did you get it to recognize the GPU? Mine's still prompts "adapter not found". Tried unlock rom and force commands but nothing.
SinisterSinner is offline
