[GUIDE] How to Play Assassin's Creed 1 & 2 wiith a Wireless 360 Controller, mapped correctly (works with some other Ubi games too) - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 09-08-2012, 04:07 AM - Thread Starter
So, I recently bought Assassin's Creed II on Uplay and found out the controller mapping for the Wireless 360 Controller is completely broken. You can't map the triggers as they are picked up as Axis (this is Microsoft's fault) and Ubisoft never bothered to work around this. Therefore, you can't map the "High Profile Mode" to the Right Trigger (RT) like it would be on the consoles, as well as the Left Trigger for locking on. You ultimately had to sacrifice centering the camera and contextual camera to use these which wasn't acceptable.
For some, this is annoying. And It took me an hour of searching to find the solution. Hopefully, this page gets picked up in Google and stops others from having to look as hard.
For this guide you need this exact version of the Xbox 360 Controller Emulator. Other, newer versions will NOT work (I tried):
x360ce.App-2.0.2.51.zip 620k .zip file
Credit to the original creators here: http://code.google.com/p/x360ce/
But I do repeat, do not use any other version than the one posted above. Newer version won't work smile.gif
The Guide:
  1. First download the attachment: x360ce.App-2.0.2.51.zip 620k .zip file
  2. Turn on your Wireless 360 Controller and sync it with your receiver (if you hadn't already done that).
  3. Extract it to a folder somewhere on your computer and run the file within called x360ce.exe.
  4. It will ask to create two default files. Click yes to both.
  5. The screen should now look like this:
  6. Now click the Presets dropdown box at the bottom of the program and choose "Controller (Xbox 360 Wireless Receiver for Windows)" and then click "Load".
  7. Now click the Options tab and set Fake WMI to "EnabledUsb" and Fake DI to "EnabledCallback and also uncheck the "Use Init beep" tickbox. It should look like this:
  8. Click "Save" at the bottom right of the program, then close it.
  9. Now you need to navigate to the folder you extracted the attached program to and find these two files in the red box:
    and copy them into your Assassin's Creed 1 or 2 (or both if you own both?) root folder or where ever the game's executable is like this:
  10. Now run the game and select the 360 controller in the options... It should look like this:
Notes:
If you followed this guide to the letter it will now work correctly! I've tried this on two different PC's running with two different receivers! If it doesn't work, go back and try again. Delete the files from the x360ce folder and start over.
The only nuance with this is you can't remap the controls using this mod. So you can't change the triggers around in the in-game menu (but you could using the program if you studied it) but it works EXACTLY like the console controls which is basically what you want if you're using this guide wink.gif
This guide was made using AC2, I don't have AC1 on the PC but the source said it works fine on AC1 too. Same process (you can use the exact same files also) just drop them in the folder that has the game's main executable.
This guide is also said to work with Splinter Cell. If someone wants to try this and let me know about that, that'd be great.
Finally, this isn't necessary on Brotherhood and Revelations AFAIK as it was sorted by then. Lazy Ubisoft couldn't be arse dot patch the older games mad.gif
Rubers is offline
post #2 of 22 (permalink) Old 01-07-2013, 06:54 PM
subkinetix's Avatar
Rep: 0
Is there a means of doing this with the wired 360 controller? When I do it like this the mappings are all messed up for mine.
EDIT: Nevermind I got it working. To anyone having the same issue just grab the latest version of the program.
subkinetix is offline
post #3 of 22 (permalink) Old 10-01-2013, 04:19 AM
gotts2swim's Avatar
Rep: 0
Which program did you have to update? x360ce or Assassin's Creed? I tried updating the emulator and it doesn't work at all for me :/ Let me know. Thanks!!
gotts2swim is offline
post #4 of 22 (permalink) Old 08-15-2014, 04:39 PM
Rep: 2 (Unique: 2)
Thanks alot mate!
Armor III
(15 items)
i7 3930K 4.7Ghz
Asus Rampage IV Extreme
MSI GTX 980 TI Gaming 6G SLI
Corsair Vengeance 32GB DDR3-1600
Samsung 2TB
Samsung 640GB
2x OCZ Vertex 3 120GB (RAID-0)
Seagate 3TB
OCZ Vertex 4 256GB (boot)
Optical Drive
Samsung DVD/RW
Corsair AX1200 PSU
Corsair 900D
Operating System
Windows 10 Pro
ASUS ROG PG279Q 165hz
Keyboard
Corsair Vengeance K90
Equinoxe is offline
post #5 of 22 (permalink) Old 01-25-2015, 08:16 AM
Lexxy's Avatar
Rep: 0
I know this is an older thread, but just wanted to say thanks.
I grabbed the first Assassin's Creed game off of steam and had the problems with the triggers being assigned to axis.
I found this thread and followed your instructions and it worked perfectly.
If it makes any difference i'm using windows 8.1 and had zero problems getting this to work.
Thanks so much for this.
Lexxy is offline
post #6 of 22 (permalink) Old 05-16-2015, 10:49 AM
Valaro12's Avatar
Rep: 0
Thank you very much for this. Makes all the Assassins Games work in tandem without the crazy controller changes. Much appreciated! Works exactly like you said.
Valaro12 is offline
post #7 of 22 (permalink) Old 06-08-2015, 07:34 PM
Father Bean's Avatar
Rep: 0
DUDE!!! I know this is an old discussion but THANK YOU SOOO MUCH FOR THIS!!! I love AC but have gotten tired of poor frame rates on console and finally built a PC to play them all the way I want them to perform. You can not imagine how disappointed I was with the lack of controller support for 1 & 2 (and I hate wired controllers). RIGHT ON!!! THANKS AGAIN!!!
Edward Johnson
Santa Cruz, CA:thumb:
Father Bean is offline
post #8 of 22 (permalink) Old 08-17-2015, 10:35 AM
truetuna's Avatar
Rep: 0
Thank you SOOOOOOOOOOO much. I registered to overclock.net just to express my gratitude!!! I tried other methods online and only one of them works (the mapping) but the Vibration didn't. I followed step by step what you described and it works perfectly! **WITH** Vibration! Thanks!
I was gaming it on
Game: The Assassin's Creed Director's Cut Edition PC
OS: Windows 7
Controller: Xbox 360 Wireless
Other folks who don't want to be hampered by the original "Partial" controller support. do give it a try. it works!
truetuna is offline
post #9 of 22 (permalink) Old 09-19-2015, 12:59 PM
JLansing's Avatar
Rep: 0
Sorry to bump an old thread! But I had to say thank you to the OP! I've been looking everywhere for a fix to this! My camera was going crazy in game and just circling around my character! I couldn't make it stop. I thought maybe something was wrong with the controller and even took my controller apart to make sure that it was okay.
I am also posting to confirm that this works with the Xbox One controller on Windows 10. I did have to run the program in compatibility mode (Windows 7). Awesome job. I was going to have to watch a Youtube video of all cut scenes and miss out on this whole game because I didn't want to play it with the lame keyboard controls. (Keyboard wouldn't be lame if they would change the hints in game about how to do things to reflect the new bindings that you set).
P.S.
Ubisoft, you suck. Fix your games. lol
JLansing is offline
post #10 of 22 (permalink) Old 10-16-2015, 08:49 AM
vRenegade's Avatar
Rep: 0
There's been a recent steam sale in which I've bought all of the Assassins Creed games and I'm playing them one by one. This helped me out so much! All I can say is, I ran into one problem. Not sure if it's because I own the game on Steam or something else, but once I put the files into the directory (Assassins Creed 1), every time I launched the game, I got a white screen and it failed to respond. Simply run the program as administrator if you have the same problem. Tested and working with both "Wired Xbox One Controller" & "Wireless Xbox 360 Controller" on Assassins Creed 1, Windows 7. Thanks a lot for the help biggrin.gif This thread is the reason I signed up here wink.gif
vRenegade is offline
