Far Cry 3 Anti-Aliasing Problem - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 12-04-2012, 08:16 AM - Thread Starter
veljaaa's Avatar
Rep: 0
Hi, guys, I have a little problem with Anti-Aliasing in Far Cry 3. Some objects in the game have really rough edges even with MSAA set to 8x. I've tried changing the settings in NVidia control panel, and enabling FXAA, but nothing has changed.
Everything but Post FX in the game settings is set to Ultra (or highest possible setting), the resolution is 1080p, same as my desktop resolution, with standard alpha to coverage and HBAO.
I have the newest drivers (310.64 Beta), and my PC specs are:
GPU: Gainward GeForce GTX 590
CPU: Intel i7 2600k @ 4.5 GHz
RAM: 4x 4 GB
SSD: Kingston HyperX 120 GB
Here are some screenshots to show you the problems, but it looks even worse in motion.
Click for a bigger resolution, open in New Tab for 1080p.
No MSAA:
8x MSAA:
Notice how the trees in the backgrond and the planks on the fence look much better, but the floor, the bottom of the fence and the shotgun grip look as rough as on the first one.
And the shadows on vehicles look blocky. (shadows on Ultra, 8x MSAA)
I would appreciate it if you could help me get this fixed.
veljaaa is offline
post #2 of 20 (permalink) Old 12-04-2012, 08:27 AM
Retired Staff
ACHILEE5's Avatar
Rep: 786 (Unique: 486)
Where is that screenshot take from (mark it on map) and I'll go there and see what I get smile.gif
ACHILEE5 is offline
post #3 of 20 (permalink) Old 12-04-2012, 09:04 AM - Thread Starter
veljaaa's Avatar
Rep: 0
Here it is:
BTW, I had to take a picture of it, print screen + paste in paint just pastes a black image, same with Quick Screen Capture, and in-game screenshot shows the game, not the map, even though the map was open when I took it.
P.S. You can go there to compare how the game looks on your PC vs mine, but the aliasing is visible anywhere in the game, that's just where I happened to be at when I took the screenshots.
veljaaa is offline
post #4 of 20 (permalink) Old 12-04-2012, 09:13 AM
Hacktun3d
MrWhiteRX7's Avatar
Rep: 46 (Unique: 39)
Originally Posted by veljaaa View Post
Here it is:
I know you're on Nvidia card, but maybe you have a similar option? In my catalyst control center for my amd card I set my anti-aliasing to supersample and it cleared up the extra edges that weren't smoothing out.
2700x - taichi x470 - trident z 3466 16gb - vega 64 - 1300g2 psu - 256gb m.2 os drive - multiple samsung ssd's for games - nzxt mid tower - schiit audio uber 2 dac/ amp - dt990 pros - acer 1440p 144hz 27" freesync - fk2 mouse - monoprice cherry kb
MrWhiteRX7 is offline
post #5 of 20 (permalink) Old 12-04-2012, 09:18 AM - Thread Starter
veljaaa's Avatar
Rep: 0
I've tried turning the FXAA on, and setting it up to 32x CSAA in NVidia Control Panel, and the only thing it did is lower the framerate and cause some objects to flicker, with no improvements whatsoever.
The edges look good in every other game, even with only 4x MSAA.
veljaaa is offline
post #6 of 20 (permalink) Old 12-04-2012, 09:30 AM
Retired Staff
ACHILEE5's Avatar
I just went there and yeah, it does look rough redface.gifWarning: Spoiler! (Click to show)
ACHILEE5 is offline
post #7 of 20 (permalink) Old 12-04-2012, 09:49 AM - Thread Starter
veljaaa's Avatar
Rep: 0
Do you have an ATI or an NVidia card? Anyway, I will wait for the next patch or drivers to roll out, and see what happens then. Thanks for your help. smile.gif
veljaaa is offline
post #8 of 20 (permalink) Old 12-04-2012, 10:34 AM
alawadhi3000's Avatar
Rep: 194 (Unique: 152)
310.70 drivers were released.
My PC
(22 items)
Aorus X7 DT v7
(11 items)
Home Server
(18 items)
AMD Ryzen 3950X
ASUS X570 Strix-E
MSI NVIDIA RTX 2080 Ti Seahawk EK X
64GB GSkill Trident Z RGB DDR4 3600MHz CL16
Samsung PM981a 2TB NVMe SSD
Seagate IronWolf Pro 12TB
Optical Drive
LG 14X BluRay Writer
Corsair HX1000i 1000W
EK ASUS X570 Strix-E Monoblock
Swiftech MCP35X (Dual DDC) Pump
EK X3 250 Reservoir
2x EK XE480 Radiators
Corsair 900D
Operating System
Windows 10 Pro
LG C9 55" UHD OLED Smart TV
Keyboard
GSkill KM780R RGB w/Cherry MX Brown
Mouse
Logitech G900
Mouse
Razer ExactMat
Audio
Klipsch RC-52 II Center Speaker
Audio
Pioneer S-RS3SW Subwoofer
Audio
Logitech G35
Audio
Pioneer VSX-930-K Receiver
Intel Core i7 7820HK
Aorus HM175
NVIDIA GTX 1080 Notebook
32GB Kingston Hyper X DDR4 2400MHz
2TB HP EX950 M.2 NVMe SSD
Aorus 255W Power Adapter
Aorus X7 DT v7
Operating System
Windows 10 Pro
17.3" AUO 1440p 120Hz TN
Keyboard
Aorus RGB
AMD Ryzen 7 2700
ASUS Prime X470-Pro
Zotac NVIDIA GT520
32GB GSkill SniperX DDR4 3200MHz
2x Seagate IronWolf 12TB
Seagate Exos 12TB
Seagate Ironwolf Pro 12TB
2x WD HC520 12TB
2x Seagate Ironwolf Pro 14TB
2x WD HC530 14TB
Seagate Ironwolf Pro 16TB
2x Seagate EXOS 16TB
Rosewill Capstone 750W
AMD Wraith Spire LED
Fantec SRC-4240X07
Operating System
Windows Server 2019 Data Center
Other
IBM ServeRAID M1015
Other
LSI SAS 9207-8i
alawadhi3000 is offline
post #9 of 20 (permalink) Old 12-04-2012, 12:09 PM
Retired Staff
ACHILEE5's Avatar
In my Sig is a link to "How to put your Rig in your Sig" if you was wanting to know how smile.gif
ACHILEE5 is offline
post #10 of 20 (permalink) Old 12-05-2012, 03:13 PM
davidbongman's Avatar
Rep: 0
I have the same issue,
660TI Nvidia,
I want to mention (this is a gamebreaker sadly) using driver based anti-aliasing in this game causes the scope dots and crosshairs from appearing, resulting in a clear scope.
The only AA method that doesn't cause the scopes to be clear and without reticles are the SuperSampling and the Sparse Grid Supersampling.
Another technique is to try and change the AA compatibility in Nvidia Inspector to " Far Cry 2 " 0x00008000 (dx9) and 0x00100000 (dx11).
I haven't noticed any improvements other than when I splice the in game AA with Driver Based AA while the inspector setting is set to 'override'.
Only that this causes extreme frame drops and that dreaded no reticle for scopes issue..
davidbongman is offline
