the RROD Project Resurrection - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 07-06-2012, 10:04 PM
DraXxus1549's Avatar
Rep: 19 (Unique: 19)
I've reflowed a couple of xbox using a heatgun and they are both running strong still. Are you using a heatgun or did you try the overheating method?
DraXxus1549 is offline
post #12 of 16 (permalink) Old 07-07-2012, 04:01 PM - Thread Starter
Jollyriffic's Avatar
Rep: 57 (Unique: 48)
my friend that i got it from used the towel method and also tape.
since i just got the e74 all i really need to do is heat up one chip back by the fans, but i dont have a heat gun..
the only other option i might try is wrapping up the board and tossing it into the oven
Jollyriffic is offline
post #13 of 16 (permalink) Old 08-09-2012, 01:50 PM
222Panther222's Avatar
Rep: 36 (Unique: 35)
You might try this and see if it work..
_
Never believe the hype.
Consoles aren't about hardware, they're about good games.
_________________________________________________________
222Panther222 is offline
post #14 of 16 (permalink) Old 08-09-2012, 02:09 PM - Thread Starter
i no longer have the rrod issue. after gaming pretty hard on it for a few days i did however get a e74 error. just waiting on some thermal tape from ebay and that will be fixed also
post #15 of 16 (permalink) Old 08-09-2012, 05:05 PM
_
post #16 of 16 (permalink) Old 07-02-2013, 08:57 AM
Majestic_Lizard's Avatar
Rep: 38 (Unique: 34)
I realize this is an older thread...
That being said, the OP has some great ideas and he has done fantastic work.
However, without measuring the ambient temperatures of his CPU, GPU, EDRAM, he is just stabbing in the dark.
What you want to do is get the ambient temperatures for the CPU, GPU, and EDRAM below 50 C.
Some ways to do that are:
(1) Run the fans off of the 12 volt.
* the voltage supplied by the 360 is not enough and only kicks up when temperatures are so high that the console would be damaged anyway. Although no-lead solder melts at 220 C, it begins to deform and warp much earlier. So, if the console is heating up to 100C and cooling down to 60C, the solder joints will get brittle and break.
(2) Install an intake fan blowing air down in the lower right hand corner of the console.
*There must also be a vent installed on the top of the case for this.
*The fan can be a smaller fan, such as a 60 mm or 40 mm, (or two of them) and should not touch the CPU heat sink.
(3) Do not cover the CPU heat sink. Only cover where it connects to the shroud.
(4) Rig two 80mm intake fans to the right side of he XBOX as it is sitting horizontally. Rig an 80 mm exhaust fan to the back of the XBOX 360.
* This should be rigged to their own 12 volt power supply, not that of the XBOX 360.
* The additional internal case fans can also be run from that 12 volt power supply.
(5) Install some vents running along the left side of the console above the DVD drive to compensate for the blocked vents of the hard drive.
(6) The X Clamp mod is unnecessary. Changing the thermal compound is a good idea.
(7) Follow the OPs example of creating a shroud for the GPU and separating the large shroud in the center to divide the air between the CPU and GPU.
By doing those things I was able to drop the ambient temperatures on my Xenon XBOX like so:
Before Modification
CPU --- GPU -- RAM
73°C -- 77°C -- 80°C
After Modification
CPU ---- GPU ---- RAM
47°C -- 47°C -- 45°C
After playing the XBOX 360 for over an hour the temperatures do not even reach the original ambient temperatures.
After one hour of Gears of War 2
CPU --- GPU -- RAM
59°C -- 69°C -- 55°C
Majestic_Lizard is offline
