the RROD Project Resurrection - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 07-05-2012, 12:00 AM - Thread Starter
Jollyriffic's Avatar
Rep: 57 (Unique: 48)
figured i would post this here..
I wrote this for the gaming forum i am a part of, so if any of it seems like i'm explaining too much, that's why.
not everyone is a computer/electronics geek, so here's the work log from the site.
got a RROD 360 yesterday from a friend. he said i could have it. so the plan is to re-flow the solder on the gpu (graphics chip) and the cpu (the processor). then maybe get the same heatsink that is on the cpu (taller one) and put the same one on the gpu (shorter one). after that i need to make a case for it all to fit in. check out some of the pics
I'm not really planning on this working, i got it off of him to get ideas on modding my own xbox case. but figured while i have it lets play around and see if we cant get it to work.. hell i have fixed much worse off electronics than this.
open and ready to be blown out, always clean before your rip up electronics.
338
the rear and ONLY fans, they could come in handy
338
the gpu heatsink, is the one that is lower with the heatpipe coming off the side to a smaller cooler. the larger one is for the cpu.
338
All clean, blew out the case with 120psi
338
338
CPU cleaned, GPU still has their thermal paste on it.
not sure why but their paste seems more like hard gum than a paste.
338
The CPU cleaned to a mirror finish.
it actually was cleaned 3 more times till it was finally totally clean
338
the gpu paste close up
338
Macro shot of the cpu (central processing unit)
a CPU interprets instructions and carries out the data processing, think of it a brain. however it doesn't store data like a human brain that would be the Hard Drive.
338
Macro Shot of the GPU (Graphics Processing Unit)
this chip does all of your video rendering, if you see it, this chip showed it to you.
338
338
338
i had some extra time on my hands while on the phone with my brother and busted out the dremel and buffing compound. i got the heat sinks semi-mirrored. a little bit of over kill but whatever.
dropped some antec formula 5 silver thermal compound. (the best thermal compound you can buy)
put on a thin layer for both the gpu and cpu..
then i left the xbox with the fans off for about 30mins letting the xbox burn in. shut it down and rebooted.
Works like new now.
Case before cutting.
338
338
338
Removed the grill in the back, since there are two grills in the back it severly decreases the air being pushed out of the back of the xbox.
338
338
Next i went and cut out slats in the back to help remove back presser on the fans.
I didn't want to remove the entire back, i want to keep it looking semi stock but also add a nice look to it. what do you guys think?
338
338
338
338
This is what the original fan shroud (the white thing behind the heat sinks looks like)
as you can see the shroud just barely touches the fins. so proper cooling of the heat sinks (both gpu and cpu) isn't being accomplished.
370
So i made a semi shroud enclosure for the gpu and cpu.
this will cool the heat sinks much more effectively.
338
338
338
338
Fans put in. with this cut like it is, there feels to be about 4x the air movement/pressure vs my stock xbox, if not more.
338
338
338
338
Jollyriffic is offline
post #2 of 16 (permalink) Old 07-05-2012, 02:43 AM
In a van...DOWNBYTHERIVER
Madman340's Avatar
Rep: 120 (Unique: 107)
The images don't show up. They are uploaded to the other forum's server, and that server requires a forum account to view them.
Madman340 is offline
post #3 of 16 (permalink) Old 07-05-2012, 09:03 AM - Thread Starter
fixed. sure wish you could upload more than a single image at a time...
post #4 of 16 (permalink) Old 07-05-2012, 11:00 AM
Madman340's Avatar
I like what you did with the plastic grill. Looks nice.
post #5 of 16 (permalink) Old 07-05-2012, 12:48 PM - Thread Starter
thanks
there arent pictures of it but i did replace the x-brace on both the gpu and cpu also.
post #6 of 16 (permalink) Old 07-05-2012, 01:42 PM
Madman340's Avatar
Originally Posted by Jollyriffic View Post
thanks
Not with another clamp, I hope!
post #7 of 16 (permalink) Old 07-05-2012, 02:16 PM - Thread Starter
used machine screws, vinyl and zinc washers.
tightened them just enough to keep them from falling out under vibration.
pretty much your standard x-clam replacement with parts from lowes.
post #8 of 16 (permalink) Old 07-05-2012, 06:08 PM
Madman340's Avatar
Yep. I did the same thing, but it wasn't enough. RIP my launch console... A reflow might have worked but I was done with it at that point.
post #9 of 16 (permalink) Old 07-05-2012, 06:20 PM
so does it work?
Mr-Elite1337 is offline
post #10 of 16 (permalink) Old 07-05-2012, 07:32 PM - Thread Starter
it worked for about 15hrs but then i got e74 error.
if i can find someone with a heat gun i can reflow the ana chip.
it will still work but the last thing i want to do is play on that one when i have another xbox that works fine. so its sitting on the floor chillin till i can reflow it.
