i7-950 no oc BSOD 9c - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 09-22-2011, 02:12 AM - Thread Starter
Velathawen's Avatar
Rep: 123 (Unique: 115)
Hey guys, as the title states, one of the builds I've done from 2010 has started to act up and I can't seem to figure out why. It has sufficient cooling and has never been OC'd.
CPU - i7 950
Motherboard - Gigabyte X58A-UD3R
Ram - 4 x 3 GB A-DATA DDR3-1600 ram CL9
HDD - Western Digital Caviar Black 1TB
GPU - GTS 250
PSU - Corsair TX 750W
Optical - Sony 22x DVD Burner
CPU Cooler - Thermalright Silver Arrow
Case - CoolerMaster HAF 932
OS - Windows 7 64 Professional from MSDN (only ever authenticated from this system)
I have looked around and it seems that 9c occurs when the system encounters an error when attempting to communicate with one of the components. The BSODs tend to happen at idle, with simple web browsing and word processing, never when gaming or p95.
Thus far, the system has BSOD twice today in a time span of 5 hours. Currently running Prime 95 blend to check for errors, all temps seem to be reasonable. Load voltage is also noted at 1.232v for stock speeds.
Velathawen is offline
post #2 of 6 (permalink) Old 09-22-2011, 04:21 AM
andrewmchugh's Avatar
Rep: 626 (Unique: 493)
Ran memtest?
Graduate of Computer Science (Game Engineering) - Newcastle University
andrewmchugh is offline
post #3 of 6 (permalink) Old 09-22-2011, 04:28 AM
Darksoul844's Avatar
Rep: 49 (Unique: 47)
Darksoul844 is offline
post #4 of 6 (permalink) Old 09-22-2011, 05:22 AM - Thread Starter
Velathawen's Avatar
Running prime atm, will do memtest after another few hours ; ;
post #5 of 6 (permalink) Old 09-22-2011, 01:29 PM
Rep: 117 (Unique: 57)
If you still having problems?
Try this, sometimes windows can get corrupted, or the HDD.
CMD prompt type (sfc /scannow) and when that is done try the same at the CMD prompt type (chkdsk /r ) it will give you this...Chkdsk cannot run because it is in use, would you like to schedule for the next restart? Select yes and reboot.
H969 is offline
post #6 of 6 (permalink) Old 09-23-2011, 01:41 AM - Thread Starter
Velathawen's Avatar
I left prime running overnight and was greeted by a beautiful log in screen this morning.
Sent from my GT-I9000 using Tapatalk
