Rampage IV Extreme X79 , CPUTIN 127ºc and shutting down
Hello
I have a very big problem here, I have bought the :
1- Rampage IV Extreme X79.
2- i7 3930k processor.
3-Vengeance 16 GB quad channel 9-9-9-24 1600Mhz.
4- MSI GTX 580 ( SLI ) x2.
5- Corsair 1200w AX.
6-Corasir H100.
7- Blue-Ray player.
The problem is that the system all the time freezes while in the system on idle situation or surfing and sometimes freezes on the windows start-up logo? .Sometimes shutdown by its self after 5 minutes to 15 minutes of starting i have troubleshoot every thing in it and i found that the CPUTIN Temp is very very high , every one told me that it's fake just update the BIOS, I updated the BIOS and it's the same thing , all the monitor programs : HWmonitor , Speecy , Everest and OCCT all of them shows the 127c . the real thing i don't know what is it ? every one is saying this is no problem at all but the system just restarting and shutting down by it self.
Do you Think it's From the CPU ? Or the Motherboard ?
I have installed the system many Times . the solution i have tried is to many :
[*] i have removed the GPU card many times and test the 2 of them separately .
[*] Changed thermal compound 2 times ?
[*] remove the BIOS battery .
[*] But the RAM on X.M.P Mode.
[*] FORMAT.
[*] UPDATED the BIOS to the latest FIRMWARE.
[*] Changed the memory places .
[*]Tried to Give a stable voltage
I just hated this problem and now I'm waiting For the last time to see if i will have a solution here or i will send the MB to the reseller.
i have the BIOS temps :
CPU TEMP - 25
MB - 27
PCH 32
The Bios photos
Thank you,
Waiting for your response.....
