*solved - Page 2 - Overclock.net - An Overclocking Community
*solved
post #11 of 14 (permalink) Old 01-07-2012, 01:37 AM
Rep: 48 (Unique: 37)
Maybe your monitor has a button to switch between hdmi, vga, dvi. Mine has. Also... you could try using a different cable/slot.
Viski is offline
post #12 of 14 (permalink) Old 01-07-2012, 01:42 AM
Demented's Avatar
Rep: 339 (Unique: 301)
Originally Posted by imzgrimreaper View Post
I tried it with my motherboard. I assumed I had everything plugged and powered(?).
I also tried it with my own video card and still nothing. It is a radeon HD 6450 sapphire. I do not see any PCI-E power plugs and I had this card used on a previous computer recently - no problems encountered.
How dd you 'try t with my motherboard' if there are no video connection ports on it? How did you connect our monitor to you 6450?
Old Faithful
(17 items)
Core i5 2500K [4.0Ghz][100x40][1.2v]
MSi P67A-GD65 [4.3 BIOS]
NVIDIA RTX 2060 Super FE
12GB Corsair Vengeance 1600Mhz [9-9-9-24]
Crucial M4 256GB [CORE]
WD Caviar Black 1TB [FILEZ]
WD Caviar Black 2TB [GAMEZ]
Optical Drive
LG Blu-Ray Combo
Seasonic
Corsair H50 [Push/Pull][UltraKaze 3Ks]
Lian Li Lancool PC-K62
Operating System
Windows 10 x64 Pro
ViewSonic Elite XG270QG
Keyboard
Logitech G110
Keyboard
Razer N52TE
Mouse
Razer Naga Epic
Audio
X-Fi Titanium
Demented is offline
post #13 of 14 (permalink) Old 01-08-2012, 11:29 AM - Thread Starter
imzgrimreaper's Avatar
Rep: 0
Originally Posted by kyismaster View Post
i made the same mistake.
Make sure the 8 pin power cable to the Top Left hand corner of your mobo is TIGHTLY in place, or it will not boot tongue.gif, none the less power up.
i mean, the first time i plugged it in there, i thought it was in, then i tried doing Mem-ok which allowed the PC to have power, but do nothing else. Then when i plugged that in tighter, it worked! thumb.gif
also make sure on the back of the power supply is set to 120v not 240.
There is ..? I tried it and nothing came up, so I then tried it with my video card, and still nothing came up.
To reassure everyone though; my solution was simply to unplug everything and plugged everything back. The monitor finally reacted as I plugged it in my video card(radeon 6450) with the HDMI cable.
Thanks everyone biggrin.gif I'll see if I can upload my build through my signature like I see how some people have it here smile.gif
imzgrimreaper is offline
post #14 of 14 (permalink) Old 01-09-2012, 03:15 PM
kyismaster is offline
