I spent $1000 and im having problems!!! Please help i5 2500k - Page 3 - Overclock.net - An Overclocking Community
post #21 of 67 (permalink) Old 03-18-2012, 03:12 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
also one more not a ntoskrnl it is a usb driver i think
On Fri 3/2/2012 8:03:20 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\030212-13135-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0x2DEC2)
Bugcheck code: 0xFE (0x5, 0xFFFFFA8009F0E1A0, 0x80861C2D, 0xFFFFFA800B483C48)
Error: BUGCODE_USB_DRIVER
file path: C:\Windows\system32\drivers\usbport.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: USB 1.1 & 2.0 Port Driver
Bug check description: This indicates that an error has occurred in a Universal Serial Bus (USB) driver.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
i5Phreak is offline
post #22 of 67 (permalink) Old 03-18-2012, 03:15 AM
Benz's Avatar
Rep: 23 (Unique: 23)
Try this
MyLittleSomething
AMD Ryzen 5 3600X
GIGABYTE X470 Aorus Gaming 7 WiFi
Sapphire Radeon RX 5700 XT Nitro+
G.Skill F4-3200C14D-16GFX
Intel® SSD 600p Series
WD2003FZEX
Club 3D CSP-D700CB
Noctua NH-D15 SE-AM4
NZXT H440
Operating System
Windows 10 Pro
Keyboard
Some anti-ghosting crap.
Mouse
Razer Deathadder Elite
Audio
Onboard ALC1220
Benz is offline
post #23 of 67 (permalink) Old 03-18-2012, 03:17 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
benz what is this going to do ? when i have failure it wont restart ? and how would that be benificial to me ? wouldent that cause more problems ?
i5Phreak is offline
post #24 of 67 (permalink) Old 03-18-2012, 03:19 AM
I just have to ask: Is the multiplier the ONLY thing you changed? Did you change the voltages?
If you didn't, you have the answer right here.
Edit: Just saw the minidump above..
Sent from my GT-I9100 using Tapatalk
bruflot is offline
post #25 of 67 (permalink) Old 03-18-2012, 03:21 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
yes that's the only thing i changed ... i need to increase my voltage huh ill get a reading now of what it currently is
i5Phreak is offline
post #26 of 67 (permalink) Old 03-18-2012, 03:24 AM
Pinoy po mga koya
jprovido's Avatar
Rep: 291 (Unique: 246)
seems like you have an aftermarket cooler. have you installed the cooler properly?. download coretemp http://www.alcpu.com/CoreTemp/ and tell us the temps you are getting.
| Coffeechan | i7 [email protected] | Gigabyte Aorus Gaming 7| 32GB G.Skill Ripjaws V @ 3200Mhz | Zotac Gaming RTX 2080 Ti | (2X)Samsung 950 Pro 512GB, (2X)Mushkin ECO3 480GB RAID0, 12TB HDD | Corsair AX760 | NZXT S340 Elite | 34" Samsung CF791 | Vizio 65" P-Series 2018
| Matichan | R5 [email protected] | Asus Prime B350m | 16GB Corsair Vengeance Pro RGB @ 3200Mhz CL14 | ASUS ROG STRIX GTX 1080 Ti | Intel 545s 512GB, SiliconPower 512GB SSD, 6TB HDD | EVGA 750 G3 | NZXT H400i | 34" Dell Alienware AW3418DW 3440x1440 120hz G-Sync |
jprovido is offline
post #27 of 67 (permalink) Old 03-18-2012, 03:25 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
didnt mean to post 3 times lol
i5Phreak is offline
post #28 of 67 (permalink) Old 03-18-2012, 03:25 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
guess ill change 2
i5Phreak is offline
post #29 of 67 (permalink) Old 03-18-2012, 03:29 AM - Thread Starter
i5Phreak's Avatar
Rep: 0
anyways under 100 % load prime 95 i dont go over 70 degrees normal operating is at around 33
also my 4th core is always a little hotter around 3 to 4 degrees ?
i5Phreak is offline
post #30 of 67 (permalink) Old 03-18-2012, 03:42 AM
Linux Lobbyist
damnwebsite's Avatar
Rep: 16 (Unique: 16)
if you really did push the 2500k to 3.9ghz without changing then theres your problem, when you're not gaming im assume intel speedstep jumps in and makes sure that the full clock isnt on so when you're messing around on web browser etc youre only ~3.3ghz, but when you game it pushes it to 3.9ghz when the cpu doesnt have enough power (v's) to do so
damnwebsite is offline
