I spent $1000 and im having problems!!! Please help i5 2500k - Page 4 - Overclock.net - An Overclocking Community
post #31 of 67 (permalink) Old 03-18-2012, 02:44 AM
snipekill2445's Avatar
Rep: 133 (Unique: 97)
And to the OP, I think your problem is not enough Voltage getting to the processor. Are you using stock Vcore settings? If so, that's the problem. You may need a Vcore of about 1.35 or so, maybe more or less. Just remember, when you increase the voltage, you also increase heat. So keep an eye on your core heat, and don't let it get about 72c or so.
snipekill2445 is offline
post #32 of 67 (permalink) Old 03-18-2012, 02:58 AM
Look, I don't know if you know this, but I'll breafly explain to you what overclocking is:
You have a processor which runs at 3.3Ghz. By overclocking it, you makes it run faster than the base clock (3.3Ghz).
But to run faster, you need more food. By food, I mean voltages.
It's like you run for 10 hours without eating food. Eventually you'll pass out (BSOD), but by eating too much you'll run slower.
Therefore, you'll have to find the exact amount of food that works for you. Nobody can tell you exactly how much you need, since everyone is difference. The only way to find out is to stress test.
Now, since you have something called "SpeedStep", you basically slows down and starts to walk (~1.6GHz), that's why you "survive" a couple of hours before you BSOD.
bruflot is offline
post #33 of 67 (permalink) Old 03-18-2012, 03:22 AM
Kai`'s Avatar
Rep: 9 (Unique: 6)
Test everything at stock before OC'ing through memtest86+, linx, etc. etc. Once you've confirmed that the CPU/RAM/Mobo is stable you can eliminate hardware problems. THEN you can start tweaking/overclocking. Given your description it looks like you have not followed the correct procedure for overclocking your CPU, so just do some reading on that thread that was linked. But imo I think it's lack of vcore from the OC, but test at stock just to confirm you have no inherent hardware faults.
Kai` is offline
post #34 of 67 (permalink) Old 03-18-2012, 04:51 AM
Rep: 134 (Unique: 116)
Hey mate. Just found this for you. It might be worth a shot
_________________________________________________________________
Stop error code F4, CRITICAL_OBJECT_TERMINATION. BSOD Index
Kernel base = 0xfffff800`01a55000 PsLoadedModuleList = 0xfffff800`01c92e50
Debug session time: Fri Oct 8 14:07:48.380 2010 (GMT-4)
System Uptime: 0 days 1:15:52.005
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Uninstall your CD Virtualization program, Daemon Tools or Alcohol 120%. They use a driver, found in your dump, sptd.sys, that is notorious for causing BSODs. Use this SPTD uninstaller when you're done: DuplexSecure - Downloads. When you run the uninstall tool, select uninstall; do not select reinstall.
K62-RIG is offline
post #35 of 67 (permalink) Old 03-18-2012, 05:57 AM
Benz's Avatar
Rep: 23 (Unique: 23)
Originally Posted by i5Phreak View Post
yes that's the only thing i changed ... i need to increase my voltage huh ill get a reading now of what it currently is
benz what is this going to do ? when i have failure it wont restart ? and how would that be benificial to me ? wouldent that cause more problems ?
Exactly, so you can tell us the error code then we'll be able to help you.
But I think there's not enough juice getting to your CPU. Use dynamic core DVID to play with it.
MyLittleSomething
AMD Ryzen 5 3600X
GIGABYTE X470 Aorus Gaming 7 WiFi
GIGABYTE Aorus GeForce GTX 1070 Ti
G.Skill F4-3200C14D-16GFX
Intel® SSD 600p Series
WD2003FZEX
Club 3D CSP-D700CB
Noctua NH-D15 SE-AM4
NZXT H440
Operating System
Windows 10 Pro
Keyboard
Some anti-ghosting crap.
Mouse
Razer Deathadder Elite
Audio
Onboard ALC1220
Benz is offline
post #36 of 67 (permalink) Old 03-18-2012, 06:04 AM
Schmuckley's Avatar
Rep: 698 (Unique: 562)
You should be a little more specific about your hardware.F'rinstance..Is that 550w psu a Diablotek?.That being said..2500Ks..are like disposable diapers..Pretty sure there's a brick in mine..
Schmuckley is offline
post #37 of 67 (permalink) Old 03-18-2012, 06:23 AM
sutty's Avatar
Rep: 6 (Unique: 6)
When you BSOD, could you tell us the error code, I suspect it will be a 101 example -
432
sutty is offline
post #38 of 67 (permalink) Old 03-18-2012, 01:39 PM - Thread Starter
i5Phreak's Avatar
Rep: 0
i already posted error codes also my v core voltage is at the standard 1.25 v hasn't changed ... and what would i overclock for other then gaming ?
i5Phreak is offline
post #39 of 67 (permalink) Old 03-18-2012, 01:45 PM
Linux Lobbyist
PCCstudent's Avatar
Rep: 260 (Unique: 223)
Folding,Folding,Folding
PCCstudent is offline
post #40 of 67 (permalink) Old 03-18-2012, 01:46 PM
LTC
LTC's Avatar
Rep: 38 (Unique: 36)
Seriously, load the default settings in your BIOS, do your PC crash then? If not, try to bump voltage to 1.3V and your multiplier to 40, and see if it crashes then...
// Ryzen 2700X 4GHz // GSkill 16GB F4-3600 // 256GB 970 Evo NVME // Gigabyte 2080 Gaming OC White // NZXT H500i //
LTC is offline
