[Official] - Xeon X5660-X58 Review & Discussion [and Xeon L5639 benchmarks inside] - Page 222 - Overclock.net - An Overclocking Community
View Poll Results: Was my review helpful?
Yes 251 95.08%
No 13 4.92%
Voters: 264. You may not vote on this poll
post #2211 of 8155 (permalink) Old 11-17-2014, 09:54 AM - Thread Starter
Kana-Maru's Avatar
Rep: 198 (Unique: 128)
This is why I stated "Since it can be difficult the manufactures gave us what we wanted & added LLC\Vdroop options". Overclocking with Vdroop can be difficult and rather confusing. I see where you are coming from and you aren't the first to that focus solely on voltage. Anything below 1.35v "is good" and you'll probably never see the spikes, but the CPU will handle the voltage differently depending on your settings. 1.329v is what you see, but that doesn't mean that's the end of the story. I personally still wouldn't run 1.33v [1.329v] 24/7 through my CPU. Just know that vdroop is there for a good reason. If you choose to use it or not I can't argue with that.
Edit:
Also as I stated above. I will attempt to run some test throughout the week and post proof behind my reasoning. I live a fairly busy life so I try to do as much as I can whenever I can.
Another Edit:
I just saw all of the edits you made as well. I guess I might now have to run test or anything like that. Also I don't get along with that website you posted lol.
Kana-Maru is offline
post #2212 of 8155 (permalink) Old 11-17-2014, 11:43 AM
u3b3rg33k's Avatar
Rep: 156 (Unique: 132)
Originally Posted by intelchief View Post
Actually i've reached 4320Mhz with Vdropp disabled (1.329V on Both CPUs, VTT - 1.325 and ram 1.6V) I tried to reach this with Vdroop Enabled and it was impossible. I needed to set in bios more than 1.4V(compared to 1.33125 with Vdroop disabled) which still was not enough(i stopped because i dont want to dmg my CPU's)
my spec:
2x. X5670 (BCLK 180Mhz with Turbo, speedstep and C1E)
Evga SR2
12Gb ram
GTX670
Antec HCP 1000W
And i dont have different voltage on those CPUs (my motherboard require higher value in bios to give the same voltage on the second CPU)
Both CPU's are running with 1.329V
Vtt1.325
IOH 1.35
Correct me if I'm wrong, but isn't Vdroop really just what naturally happens when you draw current in any electrical system, ever (causing voltage to fall)? And "disabling" vdroop actually causes the VRMs to increase voltage as current draw increases in order to maintain a more constant voltage?
MacBook
(12 items)
i7-970 @ 4.14GHz 1.350v
P6T7 WS Supercomputer
MSI 7970 GHz Edition
HIS 6950
48GB Crucial Ballistix @1660MHz 9-9-9-27
intel 480GB 520 series
Momentus XT
AX850
INX-720
PC-Z60
Operating System
win7pro
Soyo P-MVA 1200p 24"
Dell 24" 1200p
Dell 17" 4:3 (market tickers)
Keyboard
Dell Quietkey
Mouse
Logitech G5
T7500
Laptop Motherboard
GMA X3100
2x2GB DDR2 667
intel X-25M
Optical Drive
HL-DT-ST DVDRW GSA-S10N
MagSafe
Heatpipe & blower
1280x800 TN
Keyboard
Apple US
Mouse
trackpad
Audio
Intel High Definition Audio
u3b3rg33k is offline
post #2213 of 8155 (permalink) Old 11-17-2014, 11:44 AM
intelchief's Avatar
Rep: 0
so it looks like i have to spend the night to find stable settings with Vdroop on. But when i want to have ~1.3V under load, in IDLE voltage will reach probably 1.4V - its not safe i think.
intelchief is offline
post #2214 of 8155 (permalink) Old 11-17-2014, 01:23 PM
Linux Lobbyist
GENXLR's Avatar
Rep: 8 (Unique: 6)
Kana, So is LLC bad then? I use it all the time on all my rigs because it counter Vdroop. I know it's there for a reason but i thought it's better to counter it so that the voltage doesn't drop. Without it, any OC i run seems to fail UNLESS i set it close to 1.4V
Is this a sign of degradation?(I hope thats the right word x.x)
GENXLR is offline
post #2215 of 8155 (permalink) Old 11-17-2014, 02:03 PM - Thread Starter
Kana-Maru's Avatar
Please stop posting anandtech stuff in my topics. I had something short of a scuffle with that sites administrators and moderators. So if you guys could just edit those links it would be greatly appreciated.
Originally Posted by GENXLR View Post
lil off topic, perfect example of
Other than that XD
YES!!!! Joking lmao. It might not be a sign of degradation and then again it could be. We have plenty of headroom, but some users want unrealistic results. Especially users who doesn't really need "that" much performance. In so many words you could argue that LLC is bad, however, an overclocker might think otherwise. There are a few tricks and counters though. LLC is there solely for overclocking. I think it takes much more skill to OC with Vdroop than it does without it. I guess I'm taking OC to a sports level or something lol.
post #2216 of 8155 (permalink) Old 11-17-2014, 02:51 PM
intelchief's Avatar
Rep: 0
just one more question Kana-Maru. What maximum voltage in IDLE u think is safe for longer period of time? 1.35? (I've seen your voltage for 4.6Ghz - 1.45 for me looks like - devil.gif )
post #2217 of 8155 (permalink) Old 11-17-2014, 03:05 PM
Rep: 29 (Unique: 18)
1.45 is possible to use for short periods of time... Its a chip burner in the long term... I'd stay away from that voltage at all cost if possible... .135v as a 24/7 voltage is reasonable
EvilMonk is offline
post #2218 of 8155 (permalink) Old 11-17-2014, 04:15 PM - Thread Starter
Kana-Maru's Avatar
What monk said smile.gif. I'll elaborate a bit more.
First of all I think you meant "4.8Ghz" smile.gif. My 4.6Ghz OC runs at 1.34v - 1.358v 4.8Ghz runs at 1.456v. Also the voltage isn't constant. I'm not running max voltages during Idle and loads. Even with minor loads [10% - 40%] my CPU doesn't run at the maximum voltage.
I believe my 4.6Ghz Idle voltage averaged around 1.1v something. My 4.8Ghz Idle was 1.1 something as well. I honestly would have to either test again or find my old post. So the Idle voltages are perfectly fine. Whenever I run 4.8Ghz @ 1.45v it is solely for benchmarks or gaming [1.45v is not the idle].
So the maximum idle voltage that I feel is safe is anything under 1.15v. I think that's a safe number for high overclocks. Minor OCs [3.6Ghz - 4Ghz] will probably be closer to 0.09v - 1.0v
post #2219 of 8155 (permalink) Old 11-17-2014, 05:06 PM
intelchief's Avatar
Rep: 0
aft
I believe my 4.6Ghz Idle voltage averaged around 1.1v something. My 4.8Ghz Idle was 1.1 something as well. I honestly would have to either test again or find my old post. So the Idle voltages are perfectly fine. Whenever I run 4.8Ghz @ 1.45v it is solely for benchmarks or gaming.
yep wink.gif my fault -4.8Ghz
Idecided to turn on Vdroop and started from the beginning.
How it's possible that your IDLE voltages are so low?! confused.gif Can u tell me what vaules in BIOS are choosed for CPu voltages?
My IDLE Voltages according to Bios/eleet/cpu'z are 1.37 but during stress voltage is droping down to 1.31V - that gives me stable(for now - still testing) 4.2Ghz. Did you turn on some options in Bios(i mean for example c1e?)
post #2220 of 8155 (permalink) Old 11-17-2014, 05:06 PM
Basically I can only give a simple explanation since all I learned here came from you... I can cover the basic stuff but the deeper explanations you have to take care of that since you know a lot more than I do since you and the guys here are the one that I learned everything I know from thumb.gif
**Edit**
I should get the haswell Xeon E3-1246V3 and the motherboard tomorrow both cleared customs in Montreal around 5PM so they should get delivered around noon tomorrow... I received the 32Gb of G.Skill Trident X DDR3 2400 CL10 today and I just feel like I won't have lots of overclocking room with that thing since its locked and they don't really overclock with the bclk...
EvilMonk is offline
