[Official] - Xeon X5660-X58 Review & Discussion [and Xeon L5639 benchmarks inside] - Page 814 - Overclock.net - An Overclocking Community
View Poll Results: Was my review helpful?
Yes 254 95.13%
No 13 4.87%
Voters: 267. You may not vote on this poll
post #8131 of 8251 (permalink) Old 06-11-2019, 10:14 PM
AllenG's Avatar
Rep: 28 (Unique: 24)
Quote: Originally Posted by Kana-Maru View Post
Actually I was thinking about building a small portable ITX\Micro-ATX type of build a few years ago. I would have two PCs, one stationary and one portable. Since the Fury X is a very small GPU I was going to move it over the portable build. The portable would have been similar to your needs such as long vacations. Laptops are fine for short vacations and I normally VPN into my home network and connect to my PC remotely. The main reason for the portable PC is that the Laptop is just to slow for my needs after a while.
I have thought about smaller “main” build, but I do need the HDD space so I guess a Mid-Tower is the smallest I’d go I guess, unless you have something in mind(?). M.2\SSD storage is more affordable and takes up nearly no space compared to old HDDs. The HDDs would mostly be for RAID 10 setups, but I suppose I could use a USB 3.0\3.1 RAID backup solution instead of having it inside the PC itself.
This is what i ended up doing as a everyday usage replacement for my main sig rig i ended up building a ITX Ryzen 7 1700 @ 3.8 (was the best performance ratio per watt i could achieve in such a small box on air) w/ 32gb of c14 3200 ram. Ran a short gtx1060 6gb with a single NVME ssd and two SATA ssd's. Definitely an upgrade at 1/5 space used and like 1/4 the wattage drawn... under full cpu and gpu load machine only pulls 360w from the wall, the i7/gtx780 pulled 920w. If i was more gaming oriented, i probably wouldn't have went ITX though as all the high end cards don't fit very easy and if they do, the rig is already almost micro atx size. That being said, running on a 1440p 60hz single monitor setup the gtx1060 does well enough.
Still built a threadripper with vega 64 like 6 months later for heavier tasks, but tbh i don't use it anywhere near as much as i do the ITX rig as it already handles most tasks with ease.
I have all my spinning media in a NAS that i store most things on, besides my normal usage stuff on the local SSD's. I'll say that is definitely a determining factor when deciding between ITX and MATX/ATX. With USB3.0 you have a good solution as you described though... if i were only working from one computer at a time with my data on the drives then your idea is exactly how i would be doing it too. If i were building a machine might now for all use and wanted a couple 3.5 HDD's and full size video cards, i'd probably go MATX. Only reason i say not to bother with full ATX is because most of the main stream platforms don't offer enough pci-e lanes to need all 6 or 7 slots anyways. Most of the real estate just goes to waste.
i7 990x @ 4.69GHz
Asus Rampage III Extreme
EVGA GTX780 FTW ACX 2.0 3GB
12 GB Samsung DDR3L @ 2100Mhz
Samsung 840 Pro 256gb Raid0 On LSI 9207
Samsung 840 Pro 512gb
PSN across 10Gb Fiber
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
DTek Fuzion V2 CPU Block w/ Quad Insert
Laing D5 pump {2MT}
2 x Black Ice Pro 240 Radiators {2MT}
EK Full Cover RIIIE Nickel/Acetal Block
Lian Li PC-A10B
Operating System
Windows 8.1 Enterprise X64
Monoprice 27in WQHD IPS
Keyboard
Das Keyboard Model S
Audio
Creative X-Fi Fatal1ty Platinum
Other
LSI 9207-8i SAS6G Raid Controller
Other
Intel XF SR 10Gb Fiber Adapter
Pentium G3258 @ 4.5GHZ
MSI PC Mate Z97
EVGA GTX 970 SC ACX2.0 4GB
8GB Mushkin Blackline DDR3 2133
256 GB Plextor M6 SSD
WD Black 640GB Raid0
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Windows 10 Enterprise x64
Changhong 42in 1080p TV
Keyboard
HP Wireless Keyboard & Thumb tracker
Mouse
Audio
Creative Sound Blaster X-Fi Fatality
Intel Xeon x5687 @ 3.6GHZ
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
24GB Hynix DDR3 1333 2R-X4 ECC
Samsung 850 Evo 500GB
Seasonic S12II 620W
Intel LGA1366 HDX Cooler for Extreme Edition CPU
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #8132 of 8251 (permalink) Old 06-15-2019, 12:49 PM - Thread Starter
Kana-Maru's Avatar
Rep: 201 (Unique: 130)
Man I have some ideas, but I’m trying to take the cheapest most effective route at this point. Then later I will upgrade to what I want. I guess I’m just putting builds together and waiting to see what’s worth it and what isn’t. Luckily I’m on a single PC as of right now. I’d definitely prefer to have a RAID 10 setup since I’m not the best when it comes to backups.
I’ve been checking out some PC cases. They seem to be limited to only 2x 2.5 HDD slots in most cases. I can use 6 (and more if I needed it) in my current case which is an older case. I don’t really care for all the RGB stuff, but it seems liquid cooling has taken up the space where HDD or removable HDD cages used to be. I have a removable HDD cage in my build, but I’m currently running 2 different RAIDs so I have it installed. SSDs can be installed directly on the board which is cool, but replacing HDDs are easy and more affordable when it comes to storage capacity. I’m not sure how long a SSD running RAID setups would perform with a lot of backups throughout the year. At least with an HDD it will be much less expensive to keep the RAID going.
I’m not going a lot of gaming on my PC like I used to so I was simply going to transfer my Fury X to my next build for now. As you saw above I’m STILL playing game @ 4K in 2019 with no issues. It’s time for a better architecture and CPU. I want a 8-Core Ryzen, but I think I might have to settle for the 6 core and decently priced motherboard (B550 or something).
Kana-Maru is offline
post #8133 of 8251 (permalink) Old 06-23-2019, 09:53 AM
the matty's Avatar
Rep: 1 (Unique: 1)
What's the rough average people get out of X5660's? My old i5 isn't really cutting it any longer and I've been offered a rampage 3 gene and 12gb ram (I have 16gb spare from the i5 build so will have 24gb total) for £55 from a friend which I've taken and should be here Tuesday, I have played with 1366 xeons before so I know what I'm doing overclocking wise but I've only ever played with a decent bin X5650 (that was 4.4GHz 1.35v) several decent X5670s (4.5GHz between 1.35v and 1.4v on all of them) and a dud bin X5680 (4.2GHz 1.45v) but with funds being a little tight I've had to step back to an X5660 from my usual go to X5670 as the X5660 was about half the cost of the X5670 (£10 as opposed to £20), but all in all I was just wondering what to expect from it as a rough average, if I can get above 4GHz then that'll be enough for what I do but the more the better
Many thanks in advance
current rig: intel i7 4930K at 4.6GHz 1.4v, P9X79 pro, 32gb DDR3 1866MHz (4gbx8), RX 580 8gb, be quiet dark rock pro 3, evga 1600 G2, 128gb SSD for boot and a 1TB ssd for games, 2x1200p 24", 1x1080p 23" 1x1080p 24"
rig at the other halves: xeon X5660 at 4.4GHz, 12gb DDR3, RX 580 (I cart the 580 from my main rig back and forth), 212 evo, 500w seasonic thing, 64gb ssd for boot, 500gb hdd for games, 1x1080p
white Hanekawa
(18 items)
X5670
rampage 3 gene
RX Vega 56
24gb DDR3
kingston 128gb
samsung 840 evo 1TB
EVGA 1600 G2
masterbox 3.1 lite
Operating System
win 10 pro
3x1080p
Keyboard
Durgod K320
Mouse
Logitech G402 Hyperion Fury
core 2 duo E6300
cheapo OEM board
onboard
2gb
2tb WD green
80gb samsung HDD (OS)
1tb seagate
1tb seagate
stock 500w psu
coolermaster CM 103
some OEM asus one
Operating System
windows server 2012 R2
none, headless
Keyboard
none, headless
Mouse
none
Mouse
none
Audio
none
Other
Dell perc H200
the matty is offline
post #8134 of 8251 (permalink) Old 06-25-2019, 07:43 AM
Mentally Insane User
99belle99's Avatar
Rep: 5 (Unique: 5)
4.2-4.6GHz average. I daily 4.2Ghz with 1.3Volts stable for a few years now. I can easily get it to 4.6Ghz but that requires more volts so I do not bother.
Ryzen 7 3700X Owner!
Radeon RX 5700 XT Owner!
99belle99 is offline
post #8135 of 8251 (permalink) Old 06-25-2019, 12:55 PM
the matty's Avatar
Rep: 1 (Unique: 1)
ahh great thainks, my cpu arrived today, not as nice a bin as i'd have liked but good enough, am running 4.1GHz 1.31v but it takes me around 1.45v to get 4.5GHz, i may run that though when my new cooler arrives with these cpus being so cheap now it doesn't particularly matter if it dies
white Hanekawa
(18 items)
X5670
rampage 3 gene
RX Vega 56
24gb DDR3
kingston 128gb
samsung 840 evo 1TB
EVGA 1600 G2
masterbox 3.1 lite
Operating System
win 10 pro
3x1080p
Keyboard
Durgod K320
Mouse
core 2 duo E6300
cheapo OEM board
onboard
2gb
2tb WD green
1tb seagate
1tb seagate
stock 500w psu
coolermaster CM 103
some OEM asus one
Operating System
none, headless
Keyboard
none, headless
Mouse
none
Mouse
none
Audio
none
Other
Dell perc H200
post #8136 of 8251 (permalink) Old 06-25-2019, 05:12 PM
crazycrave's Avatar
Rep: 5 (Unique: 5)
https://valid.x86.fr/gujwe6
I use turbo for the 23x and 24x and it loves it..
Ryzen 5 3600
Gigabyte AB350M-DS3H CF
G-SKill 16Gb
Red Dragon RX 570 8Gb
Corsair TX 650 watt
https://valid.x86.fr/yhrtin
crazycrave is offline
post #8137 of 8251 (permalink) Old 06-26-2019, 01:16 AM
the matty's Avatar
Rep: 1 (Unique: 1)
Same, Im using the 23 multi myself: https://valid.x86.fr/shyv5f
white Hanekawa
(18 items)
X5670
rampage 3 gene
RX Vega 56
24gb DDR3
kingston 128gb
samsung 840 evo 1TB
EVGA 1600 G2
masterbox 3.1 lite
Operating System
win 10 pro
3x1080p
Keyboard
Durgod K320
Mouse
core 2 duo E6300
cheapo OEM board
onboard
2gb
2tb WD green
1tb seagate
1tb seagate
stock 500w psu
coolermaster CM 103
some OEM asus one
Operating System
none, headless
Keyboard
none, headless
Mouse
none
Mouse
none
Audio
none
Other
Dell perc H200
post #8138 of 8251 (permalink) Old 06-26-2019, 07:33 PM - Thread Starter
Kana-Maru's Avatar
With my X5660 I can run:
3.8Ghz @ 1.18 (Stable)
4.0Ghz @ 1.21v (Stable)
4.2Ghz
4.6Ghz @ 1.35-1.36v (Stable)
4.8Ghz @ 1.41v (Stable)
The HIGHEST I've hit was with the X5660 was 5.5Ghz and I can't remember the vCore off the top of my head but I almost killed the CPU.
With my L5639 which is 60W TDP I pushed it to 4.5Ghz-46Ghz @ 1.46v
I normally run 3.8Ghz unless I need more for benchmarking purposes. I'm pretty much done benchmarking this platform and 3.8Ghz is enough for 4K gaming. Well at least 4K gaming in RE2 on nearly 100% maxed settings while recording gameplay footage (I have the video on YT).
Unless I need more i normally just run 3.8Ghz since it's the summer time now and I'll like to watch the temps. Plus as I stated earlier 3.8Ghz seems to be the sweet spot for my needs on a daily basis at the moment.
post #8139 of 8251 (permalink) Old 06-26-2019, 08:37 PM
crazycrave's Avatar
Rep: 5 (Unique: 5)
I just moved up to 4.5Ghz and 2 passes so far on Fire Strike http://www.3dmark.com/fs/19681543
Ryzen 5 3600
G-SKill 16Gb
Corsair TX 650 watt
post #8140 of 8251 (permalink) Old 06-27-2019, 06:12 AM
the matty's Avatar
Rep: 1 (Unique: 1)
i like running 4.5 but it's too much of a voltage spike really, my poor 212 evo doesn't like 1.45v much XD
white Hanekawa
(18 items)
X5670
rampage 3 gene
RX Vega 56
24gb DDR3
kingston 128gb
samsung 840 evo 1TB
EVGA 1600 G2
masterbox 3.1 lite
Operating System
win 10 pro
3x1080p
Keyboard
Durgod K320
Mouse
core 2 duo E6300
cheapo OEM board
onboard
2gb
2tb WD green
1tb seagate
1tb seagate
stock 500w psu
coolermaster CM 103
some OEM asus one
Operating System
none, headless
Keyboard
none, headless
Mouse
none
Mouse
none
Audio
none
Other
Dell perc H200
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
