[Official] - Xeon X5660-X58 Review & Discussion [and Xeon L5639 benchmarks inside] - Page 816 - Overclock.net - An Overclocking Community
View Poll Results: Was my review helpful?
Yes 251 95.08%
No 13 4.92%
Voters: 264. You may not vote on this poll
post #8151 of 8155 (permalink) Old 10-11-2019, 02:12 PM
Avid Memer
chessmyantidrug's Avatar
Rep: 230 (Unique: 172)
There's plenty of modern cases with great airflow, but it's going to hard to experience that airflow with a bunch of hard drives in the case. They achieve the great airflow was unimpeded air coming through the front panel. Manufacturers are also selling their cases with the lowest HDD support possible needing to purchase brackets to support additional drives. I'm glad I don't need so much HDD space or I wouldn't have been able to go with the ITX case I picked. I'm going to replace a 2.5" drive with a M.2 drive at some point. Just a matter of the price making sense.
El Diablo
(19 items)
Intel Xeon X5670
Asus Sabertooth x58
EVGA GTX 1070
Mushkin 6x2GB XP3-12800
Samsung 850 PRO
Samsung Spinpoint F1
Samsung 850 EVO
Toshiba P300
Optical Drive
Samsung SH-S203B
Corsair AX750
Thermalright Ultra 120 Extreme
Fractal Design Define R4
Operating System
Windows 10 Home 64-bit
BenQ RL2455HM
BenQ XL2420Z
Keyboard
Deck Legend - Fire
Mouse
Razer Lachesis
Mousepad
SteelSeries QcK Gaming Mouse Pad
Audio
Astro A50
chessmyantidrug is offline
post #8152 of 8155 (permalink) Old 10-21-2019, 05:15 AM
AeroZ's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by Kana-Maru View Post
I'm "thinking" about buying another Mid-Tower case to replace my old 2013 NZXT. The only issue is most of the newer cases is that although they look nice they have has limited support for things I need\use. Features such fan controllers and expansion slots such as 4 HDD slots + 2 HDD slots for RAID 10 and RAID 1 setup. I guess I could switch to all SSDs to replace my HDDs, but the HDDs (2TBs+) prices are so much more reasonable.
Plus I have a fan controller (5.25mm) then there's the issue of air flow. The older X58 NEEDS great air flow which appears to be lacking in a lot of nice looking cases. The AIOs also don't seem that great since older hotter units aren't the target. I wish I could find my older Kuhler CPU cooler, but they no longer make them, but my current AIO for now.
Then again I guess I could use that money I would spend on a nice case to get more performance upgrades or something. I don't know. I never know since I'm still enjoying this platform and plan on getting as much performance out of it before I build a new PC.
Sorry for being lazy and not searching through this huge thread but which programs do you use to test OC stability?
AeroZ is offline
post #8153 of 8155 (permalink) Old 10-21-2019, 06:03 PM - Thread Starter
Kana-Maru's Avatar
Rep: 198 (Unique: 128)
Exactly, it’s just a matter of price and making sense. I’ve been getting rid of a lot of programs and junk I haven’t used in years or things that aren’t that important to make space. I do have a pretty good back up. Going mostly SSD was the plan for my next build (and current at some point). I do have 2 SSDs in RAID 0 now, but I got these drives many years ago. HDDs are simply affordable, but there are good 1TB SSDs with great speeds around $90-$110 dollars now. That still doesn’t compare to 1TB to 2TBs HDDs for only $40-$55. The speed makes up for the SSD price though .
SSDs also seems to have better reliability since I’ve been running my 3 SSDs (2 of them in RAID) for several years now. I had a bad experience with a SSD back in 2013. Took awhile to get over that fear lol. I’ve been looking at PCIe M.2 cards and RAID cards.
No problem. You can use quite a few programs. Prime95 is a good one for RAM\CPU and many other components, but be careful not to damage anything from the heat. IntelBurnTest is old and nice + it can really cook the CPU. MemTest64 for RAM. For GPUs you can use Furmark or the presets. Cinebench R10, R11, R15 and R20 are good test to see how stable your build is. There are many others as well, but that should be enough to get your started.
Kana-Maru is offline
post #8154 of 8155 (permalink) Old 10-22-2019, 12:07 AM
AeroZ's Avatar
Rep: 2 (Unique: 2)
Still the “good ol prime95” then heh. I’ve been using it myself since I started OC’ing when I got a 2500K many years ago.
About a year ago I was able to get a leftover PC with X58 motherboard. At that time it had the i7-920 that I switched out to x5670.
From the sandy bridge days I’m used to using prime for testing as well. After the shorter initial tests I run custom test with full FFT range, 90-95% memory and 10 minutes for each test. If that doesn’t crash for 1-2 days then I claim it as stable.
Do you think that IBT would do the same or better job quicker or long prime test is still the way to go?
Sent from my iPhone using Tapatalk
AeroZ is offline
post #8155 of 8155 (permalink) Old 10-22-2019, 03:26 PM - Thread Starter
Kana-Maru's Avatar
Prime95 still has it's purpose, but be careful with it as with all stress testing. I guess you won't really know how stable a machine unless you stress it for many hours under different conditions. I usually make sure I'm rock solid by stress testing for MANY hours or a few days at a time when I can monitor the machine.
Many years and counting and I've never had a crash @ 4.6Ghz or 4.8Ghz + 1600Mhz RAM or 2000\2100Mhz ECC Server RAM. I Since this machine is so old now I run it at 3.8Ghz most of the time and can still get great FPS @ 4K with 2019 games WHILE recording. Can't wait for RDR2 to release on PC.
