Help setting gigabyte ram timings - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 02-17-2014, 04:23 AM - Thread Starter
No matter what I do I can't get my ram to run at 9-9-9-24, it is always locked on 11-11-11-28. I have XMP enabled on Profile1, it's running at the correct voltage 1.5v. I enter the correct timings, but on the left side of UEFI bios I can see that nothing I do changes it..
im having this exact issue
http://www.tomshardware.com/answers/id-1974577/skill-ripjaws-manually-changing-ram-timing-working.html#12698899
he just explained it better
ranseed is offline
post #2 of 13 (permalink) Old 02-17-2014, 04:45 AM
eXXon's Avatar
Rep: 326 (Unique: 247)
Disable XMP and then you can set the timings manually, but you'll also have to set the correct speed.
RAIL Does Not Mean POWER.
Look up this Database before buying a PSU.
eXXon is offline
post #3 of 13 (permalink) Old 02-17-2014, 04:54 AM - Thread Starter
I think this version of my bios is bugged, even when XMP is disabled and I put in my timings it doesn't change
ranseed is offline
post #4 of 13 (permalink) Old 02-17-2014, 04:56 AM
eXXon's Avatar
Do you hit enter when entering a value? Apologies if it sounds stupid, no offence intended.
eXXon is offline
post #5 of 13 (permalink) Old 02-17-2014, 05:06 AM
Derp's Avatar
Rep: 735 (Unique: 515)
This happens on my gigabyte Z87 as well sometimes. If you set the timings and the changes don't show up in windows then shutdown the system (not a reboot, a shutdown) and boot back up and the changes should show up now.
Derp is offline
post #6 of 13 (permalink) Old 02-17-2014, 05:06 AM - Thread Starter
No offense taken at all, I had to double check to make sure it wasn't that. On the UEFI bios, pressing enter just selects the value when you are inputing your timings.
It's also under bios It doesn't change at all, on the left side
ranseed is offline
post #7 of 13 (permalink) Old 02-17-2014, 05:08 AM
mdocod's Avatar
Rep: 621 (Unique: 408)
What specific motherboard is it?
What specific RAM kit is it?
A CPU performance comparison chart.
"Kind of a ring thing, comes with a dialer, you hit the symbols, it spins around and lights come on, it kind of flushes sideways" -O'Neill
mdocod is offline
post #8 of 13 (permalink) Old 02-17-2014, 05:13 AM - Thread Starter
GIGABYTE GA-Z87-D3HP and G.SKILL Ares Series 8GB (2 x 4GB) 1600
ranseed is offline
post #9 of 13 (permalink) Old 02-17-2014, 05:16 AM
eXXon's Avatar
Warning: Spoiler! (Click to show)
Can you try 'Advanced Manual' instead of 'Manual' ?
You'll have to set the timing for both channels if it works.
eXXon is offline
post #10 of 13 (permalink) Old 02-17-2014, 05:19 AM - Thread Starter
Aha! That worked. Thanks
ranseed is offline
