3 monitor office pc build - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 02-03-2015, 07:05 PM - Thread Starter
Plateworks's Avatar
Rep: 2 (Unique: 2)
Hi, I've been task to build an office PC for an accountant that does a lot of remote logins, pdf converting and the general office stuff. They will be running a 3 monitor setup 1440p and 2 1080p. I would prefer to stick with Intel. Wondering if anyone can recommend a build with the best price/performance ratio? Thanks!
Plateworks is offline
post #2 of 15 (permalink) Old 02-03-2015, 08:34 PM
Tjj226 Angel's Avatar
Rep: 506 (Unique: 335)
http://pcpartpicker.com/p/YpyfCJ
This would be a great little build.
You should be just fine with running 3 monitors off the mobo.
The only thing I do not like is the PSU.
because this is using an M.2 drive and no video card, you only need the 24pin power connector and the 8 pin cpu power connector.
Therefore it would be nice to find a fully modular or at least semi modular PSU that spares you from having to fight with all the cables.
Tjj226 Angel is offline
post #3 of 15 (permalink) Old 02-03-2015, 08:55 PM
Ironman517's Avatar
Rep: 437 (Unique: 314)
Good build, I do like the parts. My only suggestion if your going to go ITX and no dedicated GPU, get a smaller case like the mini-box and pico-psu
Also, for the tasks at hand, They would be fine with an i3. It would save ~$60 with a very minor performance loss for their applications. I would also think about getting a hard drive for storage, caching and a page file so the SSD doesn't get ruined. Smaller SSD if you go with a HDD, otherwise keep the large SSD.
If you get the mini-box, you need to get a HDD/SSD Mounting bracket, one for each drive, I don't remember mine coming with one. I am not sure if you need a low-profile cooler, the Intel one is pretty small to begin with.
They have plenty of other small ITX cases as well, you should check them out
http://www.mini-box.com/Enclosures
Software Engineer in Satellite CommunicationsFaceepalm Quotes (Click to show)
Office + 3 monitors = more than 8gb.
A PC from 2000 can play Crysis at 20FPS. Playable.
how come i get 30 more fps with 16 gb than 8gb?
Your motherboard burst into flames.
No, you cannot use it.
Clubs/Validations (Click to show)
Ironman517 is offline
post #4 of 15 (permalink) Old 02-03-2015, 09:12 PM - Thread Starter
Plateworks's Avatar
Rep: 2 (Unique: 2)
Thanks a lot for the build this is what I was looking for. Had no idea they had a motherboard that could power 3 monitors.
post #5 of 15 (permalink) Old 02-03-2015, 09:25 PM
Ironman517's Avatar
the newer ones can, it is fairly recent. Even with old motherboards you could get a USB adapter for additional displays too.
post #6 of 15 (permalink) Old 02-03-2015, 10:03 PM
I was looking for a smaller case and could not find one.
If the power supply is any good, then yeah, I would go for that.
post #7 of 15 (permalink) Old 02-04-2015, 06:01 AM
Ironman517's Avatar
Here is some more suggestions in order of price:
$570 i5 ITX Build (Click to show)
PCPartPicker part list
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($171.98 @ NCIX US)
Motherboard: ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard ($129.99 @ Micro Center)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive ($59.95 @ SuperBiiz)
Storage: Western Digital WD Blue 500GB 2.5" 5400RPM Internal Hard Drive ($39.95 @ SuperBiiz)
Other: Mini-Box with Pico PSU ($102.00)
Other: 2x HDD brackets ($4.00)
Total: $567.86
$450 i5 MATX Build (Click to show) $430 i3 ITX Build (Click to show)
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($99.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H81N Mini ITX LGA1150 Motherboard ($63.99 @ SuperBiiz)
Total: $429.87
$380 i3 MATX Build (Click to show)
post #8 of 15 (permalink) Old 02-06-2015, 12:07 AM
mathelm's Avatar
Rep: 53 (Unique: 44)
You need to make sure you get the right monitors if you plan on running them off of that MB, as one of the HDMI ports is a input. Not to mention how slow they will be sharing a measly 8gb with the system...
http://www.asrock.com/mb/intel/Z97E-ITXac/index.asp?cat=
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4670 3.4GHz Quad-Core Processor ($203.99 @ SuperBiiz)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard ($81.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1333 Memory ($114.30 @ Newegg)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive ($84.99 @ Amazon)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($48.00 @ Amazon)
Video Card: XFX Radeon R7 250X 2GB Core Edition Video Card ($94.99 @ SuperBiiz)
Case: Thermaltake Urban S1 MicroATX Mini Tower Case ($32.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($56.99 @ SuperBiiz)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($12.99 @ SuperBiiz)
Total: $731.23
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-02-06 02:24 EST-0500
Upped the PSU for future add on's....
mathelm is offline
post #9 of 15 (permalink) Old 02-06-2015, 06:35 AM
Ironman517's Avatar
Total: $731.23
You know this is an office PC... 8GB of RAM is fine. 8GB is not "measly." 8GB is quite a lot for office tasks. The largest RAM hogger you have in an office setting is Outlook, which could use about 1GB.
A dedicated GPU is not needed, just buy the appropriate cables, you will need 1 x DVI, 1 x HDMI, and 1 x Display Port and get adapter cables, should cost between $10-$20 per cable. Much cheaper than getting a dedicated GPU.
post #10 of 15 (permalink) Old 02-06-2015, 09:20 AM
mathelm's Avatar
Office + 3 monitors = more than 8gb. I mean the only reason to have 3 monitors for working is either multitasking and/or graphics editing. And a lot of things aren't immediately necessary, but people tend to pile onto the best worker. Plus the largest "RAM hog" is web browsers. And without that dedicated GPU, you will need a display port, whereas most monitors do have both HDMI and/or DVI. Plus think how slow you'd be pushing that many pixels with shared MB memory (and in your case, only 8gb to boot).
I think that's a great price for a versatile 3 monitor office PC...
mathelm is offline
