Help me with my Home Theater PC Build is this overkill? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 50 (permalink) Old 02-28-2015, 11:00 PM - Thread Starter
Rep: 0
I agree that is why I go for aircooling in my systems
How ABOUT THIS?
Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
predalien is offline
post #22 of 50 (permalink) Old 02-28-2015, 11:01 PM
What should be here ?
huzzug's Avatar
Rep: 358 (Unique: 256)
If you will not be gaming or light gaming, have you considered the idea of going with an AMD APU ??
#2 their debt is insane, even for a "diverse field" company. They cannot even afford to service the debt maintenance let alone make an actual dent in the debt itself. - Internet Stranger
huzzug is offline
post #23 of 50 (permalink) Old 02-28-2015, 11:02 PM - Thread Starter
Rep: 0
Moderate Gaming is what I am looking at. Most of my games at medium settings.
post #24 of 50 (permalink) Old 02-28-2015, 11:03 PM
MapRef41N93W's Avatar
Rep: 191 (Unique: 143)
How ABOUT THIS?
If you can get that to fit in a Node 804 then it would be exactly what you need. Just use only one fan with it and you'll have a dead silent cooler that keeps your CPU cool.
MapRef41N93W is offline
post #25 of 50 (permalink) Old 02-28-2015, 11:10 PM - Thread Starter
Rep: 0
I don't think that cooler is going to fit. Plus I want to overlock that processor. So I am seeing water cooling as an option.
post #26 of 50 (permalink) Old 02-28-2015, 11:13 PM
I just don't want to but that cooler and it doesnt fit. Plus I want to overlock that processor. So I am seeing water cooling as an option.
You can easily max a Pentium on a Hyper 212. They only draw about 90 watts at 1.4v:
Hyper 212 is about equal to an H75, potentially slightly better.
post #27 of 50 (permalink) Old 02-28-2015, 11:16 PM - Thread Starter
Rep: 0
Water cooler with noctua fans. I think wont be that bad. What are my best options for a 120mm water cooler?
post #28 of 50 (permalink) Old 02-28-2015, 11:20 PM
You'd have a quieter build then but still the pump noise. AIOs also don't do well with low RPM fans, performance degrades quite a bit.
post #29 of 50 (permalink) Old 02-28-2015, 11:25 PM - Thread Starter
Rep: 0
For a Processor I think I will go for an i5
Intel Core i5-4460
As for an Air Cooling option. How about this?
Rosewill RCX-Z1 Long life ball bearing for over 45,000/hrs CPU Cooler
and I can replace the fan with a noctua fan
Cooler Master Hyper T2 - Compact CPU Cooler with Dual Looped Direct Contact Heatpipes
post #30 of 50 (permalink) Old 02-28-2015, 11:38 PM - Thread Starter
Rep: 0
or
Cooler Master GeminII M4 - CPU Cooler with 4 Direct Contact Heatpipes
Or use the stock heatsink?
