Help me with my Home Theater PC Build is this overkill? - Overclock.net - An Overclocking Community
post #1 of 50 (permalink) Old 02-28-2015, 09:11 PM - Thread Starter
Rep: 0
I am building another computer for a home theater.I need some advice on what I should go for. I will be hooking this pc up to a 70 inch television.
I am always open to suggestions. So what would you go for?
what air cooler should I go for?
Parts I already own
Geforce GTX 650 Ti 2gb Reference model
Hardrives
2 western digital black 2.5 in drives
Here is the list I am going with so far.
SILVERSTONE Grandia Series GD10B Aluminum HTPC for ATX / Micro-ATX / SSI-CEB Computer Case
CORSAIR HXi CP-9020072-NA 750W ATX12V / EPS12V 80 PLUS PLATINUM Certified Full Modular Power Supply
Ram
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
CPU Which I plan on overclocking
Intel Pentium G3258 Haswell Dual-Core 3.2GHz LGA 1150 53W Desktop Processor BX80646G3258
ssd
SAMSUNG 850 EVO-Series MZ-75E120B/AM 2.5" 120GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
Operating system
Microsoft Windows 8.1 Pro - Full Version (32 & 64-bit)
predalien is offline
post #2 of 50 (permalink) Old 02-28-2015, 09:26 PM
What should be here ?
huzzug's Avatar
Rep: 357 (Unique: 256)
You would not need that big PSU for the build. Any decent 450W would be plenty. Also, what motherboard will you be using ??
#2 their debt is insane, even for a "diverse field" company. They cannot even afford to service the debt maintenance let alone make an actual dent in the debt itself. - Internet Stranger
huzzug is offline
post #3 of 50 (permalink) Old 02-28-2015, 09:30 PM - Thread Starter
Rep: 0
For a motherboard
ASUS MAXIMUS VII IMPACT LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
What do you suggest for a solid power supply I am not cheaping out on a power supply?
post #4 of 50 (permalink) Old 02-28-2015, 09:41 PM
huzzug's Avatar
Something like this. Also, for motherboard, i'd recommend Gigabyte, unless you prefer Asus.
huzzug is offline
post #5 of 50 (permalink) Old 02-28-2015, 09:43 PM
MythTFLfan29's Avatar
Rep: 37 (Unique: 29)
Rosewill Capstone series is pretty good, along with most Seasonic or Silverstone , though they will cost more than the Rosewill. Antec has a few choice units as well. You can always check the PSU thread here and find the recommeded PSU's in a certain wattage range. Hope those will give you some clarity. thumb.gif
MythTFLfan29 is offline
post #6 of 50 (permalink) Old 02-28-2015, 09:46 PM
mathelm's Avatar
Rep: 53 (Unique: 44)
If you ever want to add actual TV to it, windows 7 with media center may be a better choice, as both it and 8 are to get win 10 free...
And check out pcpartpicker....
mathelm is offline
post #7 of 50 (permalink) Old 02-28-2015, 09:52 PM
MapRef41N93W's Avatar
Rep: 191 (Unique: 143)
Even this would be enough for your build http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033&cm_re=antec_earthwatts_green-_-17-371-033-_-Product
Will you be playing any 4k content? If so you will want an i3 over the Pentium.
MapRef41N93W is offline
post #8 of 50 (permalink) Old 02-28-2015, 09:54 PM
Linux Lobbyist
RAND0M1ZER's Avatar
Rep: 87 (Unique: 82)
Honestly dude, is there any reason you don't just get an Intel NUC or something similar?
I have been using XBMC on a Chromebox and I am very happy with it
Programmers write programs, who writes apps?
RAND0M1ZER is offline
post #9 of 50 (permalink) Old 02-28-2015, 10:22 PM - Thread Starter
Rep: 0
Thank-you again folks for your advice as always and i made some changes. I have a huge steam library so gaming on a 70 inch t.v is a must.
Fractal Design FD-CA-NODE-804-BL Black Aluminum / Steel Micro ATX Cube Case Computer Case ATX PSUs up to 260 mm deep Power Supply
GIGABYTE GA-H81M-DS2V LGA 1150 Intel H81 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Processor
Memory
Cpu Cooler
CORSAIR Hydro Series H50 120mm Quiet Edition Liquid CPU Cooler – Intel Only
SSD
SAMSUNG 850 EVO
Operating System
Windows 81.
Power supply
post #10 of 50 (permalink) Old 02-28-2015, 10:29 PM
Processor
Memory
Cpu Cooler
SSD
SAMSUNG 850 EVO
Operating System
Windows 81.
Corsair H50 is one of the worst AIOs on the entire market. Not worth buying whatsoever. It's worse than a Zalman CNSP8900 while running significantly louder, costing more, and being far more prone to breaking down. If you are going to go AIO you generally want to go at least with an H75 and preferably a better unit than that. Though it's not really necessary here as the Pentiums run really cool. I'd suggest a cheap air cooler like the CNSP8900 which can actually fit in the Node 804.
