Overclock to get fps. - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 03-15-2015, 09:47 AM - Thread Starter
danteover's Avatar
Rep: 0
I want to overclock my pc, I need a little more performance to play a couple games that I have. I've never done it before, i'm newb in overclock, but i've read a lot about it. I know my PC is old, but it's what i have right now. Someone recommended me the EVGA Precision x16. I need to know how or what I need to change to get at least a couple more fps. Please avoid comments like "buy another pc" or things like that. I'll add a report of my pc from Everest.
Report.txt 637k .txt file
danteover is offline
post #2 of 8 (permalink) Old 03-15-2015, 09:52 AM
Da Boss
NexusRed's Avatar
Rep: 145 (Unique: 123)
What's your system specs? Can't help you overclock if we don't know anything about your system. Like walking into a doctors office and saying it hurts...... WHAT HURTS? lmao
NexusRed is offline
post #3 of 8 (permalink) Old 03-15-2015, 12:11 PM
Rep: 17 (Unique: 17)
If you have an Intel and NVIDIA system, the following will help.
- CPU-Z
- GPU-Z
- Real Temp
Monitoring programs for your various hardware to show information such as clocks, settings, temps, and what hardware you have.
- Super Pi
Great tool for quickly seeing if your settings actually make a difference ( CPU based.) because when you overclock, even with a stable overclock, you can't always guarentee that it you will benefit from it. Take Ivy Bridge ( Intel's CPU ) for example. The colder the CPU, the better it runs. 5GHz stable on IB with 80 degrees won't perform as good a 5GHz IB chip at 30 degrees. ( numbers aren't idealistic / real, for example only )
- FireStorm
- Kepler BIOS Tweaker
Tools for overclocking and tweaking your NVIDIA graphics card at the BIOS level. FireStorm will flash your GPU while KBT changes the settings.
- NVIDIA Inspector
Another great tool for monitoring NVIDIA based cards. Also has overclocking features, and the ability to change game settings like in the NVIDIA control panel, but much, much more diverse with the settings.
- NV LDDMKM Tool
Great tool at overclocking your NVIDIA's Pixel Clock bandwidth. Helpful if you want to downsample any resolutions, though you probably won't be doing that.
- Mem TweakIt ( Tool used to view RAM / Memory settings from within Windows. )
- Memtest86+ is used at the msdos level to check that your RAM is running okay. Usually used after overclocking or before putting new ram in a system to test if there are any faults.
- MSi Afterburner
Use this instead of EVGA Precision X. They are both coded by the same guy who made MSi Afterburner, however, Precision X isn't as good, especially at the moment.
- Heaven Benchmark
One of the more popular stress testing programs dedicated to your graphics card, this helps you know if your GPU settings will work or not. If you see any artifacts, lines, glitches, anything that shouldn't be on your screen when you run it, then you need to rethink about which settings you used, and what to lower or increase. For example increasing your core clock can produce artifacts, so you'd think lowering the core clock will work, but you could also increase your voltage to the card and that too will remove the artifacts.
- Prime95
- Intel Burn Test
These two are used to stress test your CPU. It's essentially the benchmark, to see if your overclocked settings worked or not.
- Your BIOS
Loads of settings, stuff to tweak and change. Most commonly with Overclockers is that we make everything manual and turn off anything that's automatic, such as Intel SpeedStep ( reduces core clocks / frequency when temps are too high )
- The ability to increase your fans speed. ( SpeedFan works, but is difficult to get setup. ASUS AI Suite works, but only for ASUS motherboards. There's other programs for GIGABYTE, etc...)
This will help reduce your temperatures, as that is the single most important thing. High temperatures = barrier.
As for overclocking itself, figure out the hardware you have ( download a program called SPECCY, it will list EVERYTHING you have.) and then from there, go into your specific hardware sub forums and ask questions there as you'll receive specific help for that piece of hardware. For example, if you have an Intel Ivy Bridge CPU and an ASUS motherboard, go here https://www.overclock.net/t/1291703/ivy-bridge-overclocking-guide-asus-motherboards )
Camera Gear: Canon 1100D • Canon 50mm f/1.8 • Canon 18-55mm f/3.5-5.6 • Velbon EX-430 Tripod
Steam: BindiiNathan XFIRE: Curleyyy Origin: Curleyyy
Curleyyy is offline
post #4 of 8 (permalink) Old 03-15-2015, 04:05 PM - Thread Starter
danteover's Avatar
Rep: 0
Here's the everest Report. I've uploaded it on .txt but couldn't download it cuz i'm not in a group. Warning: Spoiler! (Click to show)
[ EVEREST Ultimate Edition ]
Versión EVEREST v5.50.2100/es
Módulo de rendimiento 2.5.292.0
Página Web http://www.lavalys.com/
Tipo de informe Asistente de informes
Computadora ASHRALL-PC
Generador Ashrall
Sistema operativo Microsoft Windows 7 Home Premium 6.1.7601
Fecha 2015-03-15
Hora 13:44
[ Resumen ]
Computadora:
Tipo de computadora Equipo basado en ACPI x86
Service Pack del sistema operativo Service Pack 1
Internet Explorer 8.0.7601.17514
DirectX DirectX 11.0
Nombre de la computadora ASHRALL-PC
Nombre de usuario Ashrall
Dominio de inicio de sesión Ashrall-PC
Fecha / Hora 2015-03-15 / 13:44
Motherboard:
Tipo de CPU DualCore Intel Celeron E3300, 2500 MHz (12.5 x 200)
Nombre del motherboard Biostar G41-M7 (2 PCI, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video, LAN)
Chipset del motherboard Intel Eaglelake G41
Memoria del sistema 2048 MB (DDR2-800 DDR2 SDRAM)
DIMM3: Kingston 99U5429-007.A00LF 2 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
Tipo de BIOS AMI (09/23/09)
Puerto de comunicación Puerto de comunicaciones (COM1)
Monitor:
Placa de video NVIDIA GeForce 210 (1024 MB)
Aceleradora 3D nVIDIA GeForce 210
Monitor Dell E170S [17" LCD] (N445N02H2HTB)
Multimedia:
Placa de sonido nVIDIA HDMI @ nVIDIA GT218 - High Definition Audio Controller
Placa de sonido Realtek ALC662 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Almacenamiento:
Controlador IDE Controladora de almacenamiento ATA serie Intel(R) 82801GB/GR/GH (familia ICH7) - 27C0
Controlador IDE Controladoras de almacenamiento Ultra ATA Intel(R) 82801G (familia ICH7) - 27DF
Controlador de almacenamiento MagicISO SCSI Host Controller
Disquetera Unidad de disquete
Disco rígido Generic USB CF Reader USB Device
Disco rígido Generic USB MS Reader USB Device
Disco rígido Generic USB SD Reader USB Device
Disco rígido Generic USB SM Reader USB Device
Disco rígido SAMSUNG HD321HJ ATA Device (320 GB, 7200 RPM, SATA-II)
Disco óptico MagicISO Virtual DVD-ROM0000
Disco óptico SONY DVD RW AD-7240S ATA Device
Estado SMART de los discos rígidos OK
Particiones:
C: (NTFS) 233.8 GB (93.9 GB libre)
D: (NTFS) 65767 MB (56236 MB libre)
Tamaño total 298.0 GB (148.8 GB libre)
DMI:
DMI Fabricante del BIOS American Megatrends Inc.
DMI Versión del BIOS 080015
DMI Fabricante del sistema BIOSTAR Group
DMI Nombre del sistema G41-M7
DMI Versión del sistema ' '
DMI Número de serie del sistema None
DMI UUID del sistema 00020003-00040005-00060007-00080009
DMI Fabricante del motherboard BIOSTAR Group
DMI Nombre del motherboard G41-M7
DMI Versión del motherboard ' '
DMI Número de serie del motherboard None
DMI Fabricante del chasis BIOSTAR Group
DMI Versión del chasis ' '
DMI Número de serie del chasis None
DMI Identificador del chasis None
DMI Tipo de chasis Desktop Case
DMI Sockets de memoria Total / Libres 4 / 3
[ DMI ]
[ BIOS ]
Propiedades del BIOS:
Fabricante American Megatrends Inc.
Versión 080015
Fecha de salida 09/23/2009
Tamaño 1024 KB
Dispositivos de arranque Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Funciones disponibles Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Estándares soportados DMI, APM, ACPI, ESCD, PnP
Posibilidades de expansión ISA, PCI, USB
[ Sistema ]
Propiedades del sistema:
Fabricante BIOSTAR Group
Producto G41-M7
Versión ' '
Número de serie Ninguno/a
SKU# To Be Filled By O.E.M.
Familia To Be Filled By O.E.M.
Identificador único universal 00020003-00040005-00060007-00080009
Tipo de arranque Botón de encendido/apagado
[ Motherboard ]
Propiedades del motherboard:
Producto G41-M7
Versión ' '
[ Controlador de memoria ]
Propiedades del controlador de memoria:
Método de detección de errores 64-bit ECC
Corrección de errores Ninguno/a
Memoria entrelazada soportada 1-Way
Memoria entrelazada actual 1-Way
Tipos de memoria soportadas DIMM, SDRAM
Voltajes de memoria soportados 3.3V
Tamaño máximo de los módulos de memoria 4096 MB
Slots de memoria 4
[ Procesadores / Intel(R) Celeron(R) CPU E3300 @ 2.50GHz ]
Propiedades del procesador:
Fabricante Intel
Versión Intel(R) Celeron(R) CPU E3300 @ 2.50GHz
Número de serie To Be Filled By O.E.M.
Etiqueta To Be Filled By O.E.M.
Número de pieza To Be Filled By O.E.M.
Reloj externo 200 MHz
Velocidad de reloj máxima 2500 MHz
Velocidad de reloj actual 2500 MHz
Tipo Central Processor
Voltaje 1.3 V
Estado Activado/a
Identificación del socket CPU 1
Unidades HTT / CMP 1 / 2
[ Overclock ]
Propiedades de la CPU:
Alias de la CPU Wolfdale-1M
Escalonamiento de la CPU R0
Engineering Sample No
CPUID Nombre de la CPU Intel(R) Celeron(R) CPU E3300 @ 2.50GHz
CPUID Revisión 0001067Ah
CPU VID 1.1000 V
Velocidad de la CPU:
Reloj de la CPU 2499.9 MHz (original: 2500 MHz)
Multiplicador de la CPU 12.5x
FSB de la CPU 200.0 MHz (original: 200 MHz)
Bus de la memoria 400.0 MHz
Relación DRAM:FSB 12:6
Caché de la CPU:
Caché de código L1 32 KB per core
Caché de datos L1 32 KB per core
Caché L2 1 MB (On-Die, ECC, ASC, Full-Speed)
Identificación del motherboard 64-0100-009999-00101111-092309-Eaglelake$G41AM923_G41-M7 (G41AM923 BFS) BIOS DATE: 09/23/09
Propiedades del chipset:
Tiempos de Memoria 6-6-6-15 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
Fecha del BIOS del sistema 09/23/09
Fecha del BIOS de video 01/10/14
Propiedades del procesador gráfico:
Placa de video nVIDIA GeForce 210
Nombre código de la GPU GT218 (PCI Express 2.0 x16 10DE / 0A65, Rev B1)
Velocidad de reloj de la GPU (Geometric Domain) 405 MHz (original: 589 MHz)
Velocidad de reloj de la GPU (Shader Domain) 810 MHz (original: 31232 MHz)
Reloj de la memoria 249 MHz
[ Sensor ]
Propiedades del sensor:
Tipo de sensor ITE IT8718F (ISA A10h)
Tipo de sensor de la GPU Diode (NV-Diode)
Intrusión detectada en el chasis Sí
Temperaturas:
Motherboard 37 °C (99 °F)
CPU n.º 1 / núcleo n.º 1 51 °C (124 °F)
CPU n.º 1 / núcleo n.º 2 47 °C (117 °F)
Aux 41 °C (106 °F)
diodo GPU 45 °C (113 °F)
SAMSUNG HD321HJ 34 °C (93 °F)
Coolers:
CPU 2557 RPM
Valores de voltaje:
Núcleo de la CPU 1.36 V
+2.5 V 1.17 V
+3.3 V 3.25 V
+5 V 4.97 V
+12 V 12.10 V
Puesta en espera +5 V 4.81 V
Batería VBAT 3.26 V
Debug Info F 0108 FFFF FFFF 0000 0000
Debug Info T 41 37 178
Debug Info V 55 49 CB B9 BD 77 4D (7F)
[ CPU ]
Juego de instrucciones x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Velocidad de reloj original 2500 MHz
Multiplicador de la CPU Min / Máx 6.0x / 12.5x
Multi CPU:
Identificación del motherboard Intel Eaglelake
CPU #1 Intel(R) Celeron(R) CPU E3300 @ 2.50GHz, 2499 MHz
CPU #2 Intel(R) Celeron(R) CPU E3300 @ 2.50GHz, 2500 MHz
Fabricante de la CPU:
Nombre de la empresa Intel Corporation
Información del producto http://www.intel.com/products/processor
Uso de la CPU:
CPU n.º 1 / núcleo n.º 1 0 %
CPU n.º 1 / núcleo n.º 2 0 %
[ Motherboard ]
Propiedades del bus principal:
Tipo de bus Intel AGTL+
Ancho de bus 64 bit
Reloj real 200 MHz (QDR)
Reloj efectivo 800 MHz
Ancho de banda 6400 MB/s
Propiedades del bus de memoria:
Tipo de bus DDR2 SDRAM
Ancho de bus 64 bit
Reloj real 400 MHz (DDR)
Propiedades del bus del chipset:
Tipo de bus Intel Direct Media Interface
Información física del motherboard:
CPU sockets/slots 1 LGA775
Slots de expansión 2 PCI, 1 PCI-E x16
Slots de RAM 2 DDR2 DIMM
Dispositivos integrados Audio, Video, LAN
Forma Micro ATX
Tamaño del motherboard 180 mm x 240 mm
Chipset del motherboard G41
Fabricante del motherboard:
Nombre de la empresa Biostar Group
Información del producto http://www.biostar.com.tw/app/en/mb/index.php
Descarga del BIOS http://www.biostar.com.tw/app/en/support/download.php
Actualización del controlador http://driveragent.com?ref=59
Actualizaciones del BIOS http://www.esupport.com/biosagent/index.cfm?refererid=40
[ Memoria ]
Memoria física:
Total 2047 MB
Usada 1458 MB
Libre 588 MB
Uso 71 %
Espacio de intercambio:
Total 4094 MB
Usada 2552 MB
Libre 1541 MB
Uso 62 %
Memoria virtual:
Total 6141 MB
Usada 4011 MB
Libre 2130 MB
Uso 65 %
Archivo de paginación:
Archivo de paginación C:\pagefile.sys
Tamaño actual 2047 MB
Uso Actual / Pico 660 MB / 924 MB
Uso 32 %
Physical Address Extension (PAE):
Soportado por el sistema operativo Sí
Soportado por la CPU Sí
Activo Sí
[ SPD ]
[ DIMM3: Kingston 99U5429-007.A00LF ]
Propiedades del módulo de memoria:
Nombre del módulo Kingston 99U5429-007.A00LF
Número de serie 972047BCh (3158778007)
Fecha de fabricación Semana 22 / 2010
Tamaño del módulo 2 GB (2 ranks, 8 banks)
Tipo de módulo Unbuffered DIMM
Tipo de memoria DDR2 SDRAM
Velocidad de la memoria DDR2-800 (400 MHz)
Ancho de bus del módulo 64 bit
Voltaje del módulo SSTL 1.8
Método de detección de errores Ninguno/a
Tasa de actualización Reducido (7.8 us), Self-Refresh
Tiempos de Memoria:
@ 400 MHz 6-6-6-18 (CL-RCD-RP-RAS) / 24-51-3-6-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-43-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-34-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
[ Chipset ]
[ Northbridge: Intel Eaglelake G41 ]
Propiedades del Northbridge:
Northbridge Intel Eaglelake G41
Revisión / Stepping 03 / A3
Forma del componente 1254 Pin FC-BGA
Tamaño del componente 3.4 cm x 3.4 cm
Tecnología utilizada 65 nm
Voltaje del núcleo 1.125 V
In-Order Queue Depth 12
Controlador de memoria:
Tipo Dual Channel (128 bit)
Modo Activo Single Channel (64 bit)
Tiempos de Memoria:
CAS Latency (CL) 6T
RAS To CAS Delay (tRCD) 6T
RAS Precharge (tRP) 6T
RAS Active Time (tRAS) 15T
Row Refresh Cycle Time (tRFC) 52T
RAS To RAS Delay (tRRD) 3T
Write Recovery Time (tWR) 15T
Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 6T
Read To Write Delay (tRTW) 8T
Write To Read Delay (tWTR) Same Rank: 12T, Different Rank: 5T
Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 6T
Read To Precharge Delay (tRTP) 5T
Write To Precharge Delay (tWTP) 15T
Precharge To Precharge Delay (tPTP) 1T
Refresh Period (tREF) 3120T
DRAM Read ODT 3T
DRAM Write ODT 6T
MCH Read ODT 11T
Performance Level 4
Read Delay Phase Adjust Neutral
DIMM3 Clock Fine Delay 10T
DIMM4 Clock Fine Delay 0T
Corrección de errores:
ECC No soportado
ChipKill ECC No soportado
RAID No soportado
ECC Scrubbing No soportado
Slots de memoria:
Slot DRAM n.º 1 2 GB (DDR2-800 DDR2 SDRAM)
Controlador gráfico integrado:
Tipo de controlador gráfico Intel GMA X4500
Estado del controlador gráfico Desactivado/a
Controlador PCI Express:
PCI-E 2.0 x16 port #2 En uso @ x16 (nVIDIA GeForce 210 Video Adapter, nVIDIA GT218 - High Definition Audio Controller)
Fabricante del chipset:
Información del producto http://www.intel.com/products/chipsets
Descargar el controlador http://support.intel.com/support/chipsets
[ Southbridge: Intel 82801GB ICH7 ]
Propiedades del Southbridge:
Southbridge Intel 82801GB ICH7
Revisión / Stepping E1 / A1
Forma del componente 652 Pin mBGA
Tamaño del componente 3.1 cm x 3.1 cm
Voltaje del núcleo 1.05 V
High Definition Audio:
Nombre del códec Realtek ALC662
Identificación del códec 10EC0662h / 1565821Eh
Revisión del códec 00100101h
Tipo de códec Audio
Formatos de sonido soportados 44 kHz, 48 kHz, 96 kHz, 16 bit, 20 bit, 24 bit
PCI-E 1.0 x1 port #1 Vacío
PCI-E 1.0 x1 port #2 En uso @ x1 (Realtek RTL8139/810x Fast Ethernet Adapter)
[ BIOS ]
Tipo de BIOS AMI
Fabricante del BIOS:
Nombre de la empresa American Megatrends Inc.
Información del producto http://www.ami.com/amibios
[ ACPI ]
[ APIC: Multiple APIC Description Table ]
Propiedades de la tabla ACPI:
Firma ACPI APIC
Descripción de la tabla Multiple APIC Description Table
Dirección de memoria 7FFA0390h
Tamaño de la tabla 108 bytes
OEM ID 092309
OEM Table ID APIC1041
OEM Revision 20090923h
Creator ID MSFT
Creator Revision 00000097h
Local APIC Address FEE00000h
[ DSDT: Differentiated System Description Table ]
Firma ACPI DSDT
Descripción de la tabla Differentiated System Description Table
Dirección de memoria 7FFA0440h
Tamaño de la tabla 23600 bytes
OEM ID G41AM
OEM Table ID G41AM923
OEM Revision 00000923h
Creator ID INTL
Creator Revision 20051117h
nVIDIA SLI:
SLI Certification No está presente
PCI 0-0-0-0 (Direct I/O) 8086-2E30 (Intel G41)
PCI 0-0-0-0 (HAL) 8086-2E30 (Intel G41)
[ FACP: Fixed ACPI Description Table ]
Firma ACPI FACP
Descripción de la tabla Fixed ACPI Description Table
Dirección de memoria 7FFA0200h
Tamaño de la tabla 132 bytes
OEM ID 092309
OEM Table ID FACP1041
Creator ID MSFT
SMI Command Port 000000B2h
PM Timer 00000808h
[ FACS: Firmware ACPI Control Structure ]
Firma ACPI FACS
Descripción de la tabla Firmware ACPI Control Structure
Dirección de memoria 7FFAE000h
Tamaño de la tabla 64 bytes
[ GSCI: Intel GMCH SCI Table ]
Firma ACPI GSCI
Descripción de la tabla Intel GMCH SCI Table
Dirección de memoria 7FFAE0C0h
Tamaño de la tabla 8228 bytes
OEM ID 092309
OEM Table ID GMCHSCI
Creator ID MSFT
[ MCFG: Memory Mapped Configuration Space Base Address Description Table ]
Firma ACPI MCFG
Descripción de la tabla Memory Mapped Configuration Space Base Address Description Table
Dirección de memoria 7FFA0400h
Tamaño de la tabla 60 bytes
OEM ID 092309
OEM Table ID OEMMCFG
Creator ID MSFT
[ OEMB: OEM Specific Information Table ]
Firma ACPI OEMB
Descripción de la tabla OEM Specific Information Table
Dirección de memoria 7FFAE040h
Tamaño de la tabla 114 bytes
OEM ID 092309
OEM Table ID OEMB1041
Creator ID MSFT
[ RSD PTR: Root System Description Pointer ]
Firma ACPI RSD PTR
Descripción de la tabla Root System Description Pointer
Dirección de memoria 000F8EB0h
Tamaño de la tabla 20 bytes
OEM ID ACPIAM
RSDP Revision 0
RSDT Address 7FFA0000h
[ RSDT: Root System Description Table ]
Firma ACPI RSDT
Descripción de la tabla Root System Description Table
Dirección de memoria 7FFA0000h
OEM ID ACRSYS
OEM Table ID ACRPRDCT
Creator ID MSFT
RSDT Entry #0 7FFA0200h
RSDT Entry #1 7FFA0390h
RSDT Entry #2 7FFA0400h
RSDT Entry #3 7FFAE040h
RSDT Entry #4 7FFAE0C0h
RSDT Entry #5 7FFB0500h
RSDT Entry #6 7FFA0050h
[ SLIC: Software Licensing Description Table ]
Firma ACPI SLIC
Descripción de la tabla Software Licensing Description Table
Dirección de memoria 7FFA0050h
Tamaño de la tabla 374 bytes
OEM ID ACRSYS
OEM Revision 00000001h
Creator ID ANNI
Creator Revision 00000001h
Versión de SLIC 2.1
[ SSDT: Secondary System Description Table ]
Firma ACPI SSDT
Descripción de la tabla Secondary System Description Table
Dirección de memoria 7FFB00F0h
Tamaño de la tabla 1030 bytes
OEM ID DpgPmm
OEM Table ID P001Ist
OEM Revision 00000011h
Creator ID INTL
Firma ACPI SSDT
Dirección de memoria 7FFB0500h
Tamaño de la tabla 867 bytes
OEM ID DpgPmm
OEM Table ID CpuPm
OEM Revision 00000012h
Creator ID INTL
[ Video de Windows ]
[ NVIDIA GeForce 210 ]
Propiedades de la placa de video:
Descripción del dispositivo NVIDIA GeForce 210
Identificación de la placa GeForce 210
Identificación del BIOS Version 70.18.6e.0.55
Tipo de chip GeForce 210
Tipo de DAC Integrated RAMDAC
Fecha del controlador 02/02/2015
Versión del controlador 9.18.13.4144 - nVIDIA Detonator 41.44
Proveedor del controlador NVIDIA
Tamaño de la memoria 1024 MB
Controladores instalados:
nvd3dum 9.18.13.4144 - nVIDIA Detonator 41.44
nvwgf2um 9.18.13.4144
Fabricante de la placa de video:
Nombre de la empresa NVIDIA Corporation
Información del producto http://www.nvidia.com/page/products.html
Descargar el controlador http://www.nvidia.com/content/drivers/drivers.asp
[ Video PCI / AGP ]
nVIDIA GeForce 210 Placa de video
nVIDIA GeForce 210 Aceleradora 3D
[ GPU ]
[ PCI Express 2.0 x16: nVIDIA GeForce 210 ]
Versión del BIOS 70.18.6E.00.55
Dispositivo PCI 10DE-0A65 / 0000-0000 (Rev B1)
Transistores 260 millón/es
Tecnología utilizada 40 nm
Tamaño interno 57 mm2
Tipo de bus PCI Express 2.0 x16 @ x16
Tamaño de la memoria 1 GB
Reloj RAMDAC 400 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Unified Shaders 16 (v4.1)
Soporte de hardware para DirectX DirectX v10.1
Pixel Fillrate 1620 MPixel/s
Texel Fillrate 3240 MTexel/s
Tipo de bus DDR3
Ancho de bus 64 bit
Reloj real 249 MHz (DDR)
Reloj efectivo 499 MHz
Ancho de banda 3992 MB/s
Uso:
GPU 10%
Controlador de memoria 13%
Video Engine 0%
nVIDIA ForceWare Clocks:
Standard 2D GPU: 405 MHz, Shader: 810 MHz, Memoria: 250 MHz
Low-Power 3D GPU: 589 MHz, Shader: 1402 MHz, Memoria: 450 MHz
Fabricante del procesador gráfico:
nVIDIA GPU Registers:
nv-000000 0A8280B1
nv-0010F0 00000000
nv-001218 00000000
nv-001540 F3010001
nv-0015F4 00000000
nv-0015F8 00000000
nv-0015FC 00000000
nv-001600 00000000
nv-001850 00000000
nv-004000 18010115
nv-004004 0006250A
nv-004008 80000000
nv-00400C 00000000
nv-004018 10005000
nv-00401C 00000000
nv-004020 00000000
nv-004024 00000000
nv-004028 00000000
nv-00402C 00000000
nv-004120 00063030
nv-004124 00063030
nv-004128 00063121
nv-004200 0001001C
nv-004220 0001001C
nv-00C040 20001000
nv-00E114 00000001
nv-00E118 00000000
nv-00E11C 00000001
nv-00E120 00000000
nv-00E820 01010015
nv-00E8A0 01010015
nv-020008 C0083693
nv-020014 FA580387
nv-020400 0000002E
nv-100000 00000042
nv-100200 00222800
nv-10020C 40000000
nv-100214 00000000
nv-100474 00000000
nv-100714 F0000001
nv-100914 00000000
nv-101000 8040548E
nv-10F590 00000000
[ nVIDIA SLI ]
nVIDIA SLI:
Estado SLI Desactivado/a
[ Monitor ]
[ Dell E170S ]
Propiedades del monitor:
Nombre del monitor Dell E170S
Identificación del monitor DELA04A
Modelo DELL E170S
Tipo de monitor 17" LCD (SXGA)
Fecha de fabricación Semana 8 / 2010
Número de serie N445N02H2HTB
Tamaño de visión máximo 34 cm x 27 cm (17.1")
Relación de aspecto de la imagen 5:4
Frecuencia horizontal 30 - 81 KHz
Frecuencia vertical 56 - 76 Hz
Reloj de píxel máximo 140 MHz
Resolución máxima 1280 x 1024
Gama 2.20
Soporte para modo DPMS Standby, Suspend, Active-Off
Modos de video soportados:
640 x 480 76 Hz
800 x 480 76 Hz
800 x 600 76 Hz
1024 x 600 76 Hz
1024 x 768 76 Hz
1152 x 864 76 Hz
1280 x 720 76 Hz
1280 x 768 76 Hz
1280 x 800 76 Hz
1280 x 1024 75 Hz
Fabricante del monitor:
Nombre de la empresa Dell Computer Corporation
Información del producto http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=4009&cs=19&l=en&s=dhs
Descargar el controlador http://support.dell.com/support/topics/global.aspx/support/product_support/en/monitor_download?c=us&cs=04&l=en&s=bsd
[ Escritorio ]
Propiedades del escritorio:
Tecnología utilizada Mostrar entramado
Resolución 1280 x 1024
Profundidad de color 32 bit
Planos de color 1
Resolución de las fuentes 120 dpi
Píxeles Ancho / Alto 36 / 36
Diagonal en píxeles 51
Tasa de actualización vertical 60 Hz
Fondo de pantalla de escritorio C:\Users\Ashrall\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
[ OpenGL ]
Propiedades de OpenGL:
Fabricante NVIDIA Corporation
Renderer GeForce 210/PCIe/SSE2
Versión 3.3.0
Versión del lenguaje "Shading" 3.30 NVIDIA via Cg compiler
OpenGL DLL 6.1.7600.16385(win7_rtm.090713-1255)
Controlador ICD nvoglv32.dll (9.18.13.4144 - nVIDIA Detonator 41.44)
Multitexture Texture Units 4
Occlusion Query Counter Bits 32
Sub-Pixel Precision 8 bit
Max Viewport Size 8192 x 8192
Max Cube Map Texture Size 8192 x 8192
Max Rectangle Texture Size 8192 x 8192
Max 3D Texture Size 2048 x 2048 x 2048
Max Anisotropy 16
Max Clipping Planes 8
Max Display-List Nesting Level 64
Max Draw Buffers 8
Max Evaluator Order 8
Max General Register Combiners 8
Max Light Sources 8
Max Pixel Map Table Size 65536
Min / Max Program Texel Offset -8 / 7
Max Texture Array Layers 512
Max Texture LOD Bias 15
Max Vertex Array Range Element Size 1048575
Compatibilidad OpenGL:
OpenGL 1.1 Sí (100%)
OpenGL 1.2 Sí (100%)
OpenGL 1.3 Sí (100%)
OpenGL 1.4 Sí (100%)
OpenGL 1.5 Sí (100%)
OpenGL 2.0 Sí (100%)
OpenGL 2.1 Sí (100%)
OpenGL 3.0 Sí (100%)
OpenGL 3.1 Sí (100%)
OpenGL 3.2 Sí (100%)
OpenGL 3.3 Sí (100%)
OpenGL 4.0 No (38%)
Max Stack Depth:
Attribute Stack 16
Client Attribute Stack 16
Modelview Matrix Stack 32
Name Stack 128
Projection Matrix Stack 4
Texture Matrix Stack 10
Draw Range Elements:
Max Index Count 1048576
Max Vertex Count 1048576
Extended Lighting Parameters:
Max Shininess 128
Max Spot Exponent 128
Transform Feedback:
Max Interleaved Components 64
Max Separate Attributes 4
Max Separate Components 4
Framebuffer Object:
Max Color Attachments 8
Max Render Buffer Size 8192 x 8192
Imaging:
Max Color Matrix Stack Depth 2
Max Convolution Width / Height 11 / 11
Vertex Shader:
Max Uniform Vertex Components 4096
Max Varying Floats 60
Max Vertex Texture Image Units 32
Max Combined Texture Image Units 96
Geometry Shader:
Max Geometry Texture Units 32
Max Varying Components 60
Max Geometry Varying Components 124
Max Vertex Varying Components 60
Max Geometry Uniform Components 2048
Max Geometry Output Vertices 1024
Max Geometry Total Output Components 1024
Fragment Shader:
Max Uniform Fragment Components 2048
Vertex Program:
Max Local Parameters 1024
Max Environment Parameters 256
Max Program Matrices 8
Max Program Matrix Stack Depth 1
Max Tracking Matrices 8
Max Tracking Matrix Stack Depth 1
Max Vertex Attributes 16
Max Instructions 16384
Max Native Instructions 16384
Max Temporaries 4096
Max Native Temporaries 4096
Max Parameters 1024
Max Native Parameters 1024
Max Attributes 16
Max Native Attributes 16
Max Address Registers 2
Max Native Address Registers 2
Fragment Program:
Max Local Parameters 512
Max Texture Coordinates 8
Max Texture Image Units 32
Max Parameters 1024
Max Attributes 16
Max Address Registers 1
Max Native Address Registers 1
Max ALU Instructions 16384
Max Native ALU Instructions 16384
Max Texture Instructions 16384
Max Native Texture Instructions 16384
Max Texture Indirections 16384
Max Native Texture Indirections 16384
Max Execution Instructions 16777216
Max Call Stack Depth 32
Max If Statement Depth 64
Max Loop Depth 64
Max Loop Count 16777216
post #5 of 8 (permalink) Old 03-16-2015, 02:11 AM
Hardware Maniac
bonami2's Avatar
Rep: 54 (Unique: 41)
You wont gain any benefit from overclocking this sorry.
And anyways it look like a prebuilt system that already kill cpu overclocking.
And that geforce 210 is just good as a htpc Gpu and even then
Fx-6300 5.1 5 GHz Overclock Club i7-4790k 5.1 Asus P8P67 |--| i7 2600k 4.5ghz | Corsair H110i GTX ASETEK | DeepCool Matrexx 55 White | Corsair RM 1000X | Crucial MX100 512gb + 4x Kingston 256gb + 2x Wd Blue 4tb | Asus Strix OC GTX 1070 | MSI GTX 1050 Ti |
bonami2 is offline
post #6 of 8 (permalink) Old 10-31-2017, 10:03 AM
RustySpoons's Avatar
Rep: 4 (Unique: 3)
Agreed. New system time.
RustySpoons is offline
post #7 of 8 (permalink) Old 10-31-2017, 10:22 AM
Da Boss
NexusRed's Avatar
Lol you just necro'd a thread from 2015 fam. Mods should lock this asap.
NexusRed is offline
post #8 of 8 (permalink) Old 10-31-2017, 01:19 PM
Rep: 4 (Unique: 3)
Yeah not even sure how I replied to this in the beginning, I was replying in the Z370 VRM thread, but it popped up in here.
I couldn't delete my post so thought i'd post something on topic lol!
