Delid questions - Page 2 - Overclock.net - An Overclocking Community
Delid questions
post #11 of 13 (permalink) Old 01-06-2019, 02:30 PM
Overclocker
OrganizedChaos's Avatar
Rep: 0
Quote: Originally Posted by Silicon Lottery View Post
Quote:Originally Posted by NBrock
Hi Silicon Lottery!
I plan on deliding my 4790k and was wondering if you would be willing to share what epoxy you use to re-attach the IHS and what liquid electrical take you use on the resistors.
Thanks!
This is similar to what we use, but comes in a smaller size:
Silicone
Liquid electric tape
Black Friday is coming up, and we're going to have a really low price on delidding ourselves if that interests you btw.
Quote:Originally Posted by The EX1
IMO, you shouldn't use an epoxy to permanently reattach the IHS. It creates a small gap between the die and the IHS, which is what causes a lot of the heat problems in the first place. Put a good liquid metal TIM on the die and lay the IHS back on top. Pick up some liquid electrical tape and put a thin layer on the exposed components on the PCB. Then reinstall the CPU back into the motherboard. Be sure to hold the IHS in place as you lower the locking arm.
If you use enough pressure when drying, there will be no difference in temperatures compared to just letting the IHS sit free. There won't be a gap (at least not nearly as large) like there was before delidding, I've tested this dozens of times.
If the gap is a big concern to you, you could paint a small amount of silicone on the inside of the IHS like I've shown in the picture below. The silicone will be squished down once you put the IHS back on, so it should be the same as letting the IHS sit free.
Quote: Originally Posted by ThrashZone View Post
Hi,
Liquid tape
One might need to redo a delid if not done properly
I had to redo my silicon lottery delid
They left the original Intel sealant instead of removing it so the contact is minimal for the liquid metal and just used more LM which drooped.... from too much space...
Any silicone based sealant can be used to reseal the cap
Just a small bead across the bottom and up a little to catch any if it drips... and a couple dots on the top to hold it till it dries.
So would silicon like the one mentioned in the quote above by silicon lottery allow me to delid again with the die mate if necessary?
[Build Log]
OrganizedChaos
(19 items)
Intel Core I7 8700k
Asus Maximus X Hero (Wi-Fi AC)
Nvidia Geforce GTX 1080 FTW
G.Skill Trident
Samsung EVO 850 SSD
Western Digital Black Edition
EVGA SuperNova 850 G2
EK Supremacy EVO
EK-FC1080 GTX FTW
EK Coolstream PE 360mm
EK-XRES 140 Revo D5 PWM + Multi-port Top added on
Phanteks Enthoo Luxe (Tempered Glass)
Operating System
Windows 10
ASUS ROG SWIFT PG279Q
Keyboard
Corsair K70 RGB
Mouse
Logitech G-400s
Mousepad
Razr Scarab - Battlefield 3 Edition
Audio
Logitech Z-5500
Audio
Hyper-X Cloud II
OrganizedChaos is offline
post #12 of 13 (permalink) Old 01-06-2019, 06:42 PM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Not sure why anyone would surround the chip with adhesive
Silicon lottery does it because they ship chips all over and the LM will likely move all over the place since they use a boat load of LM
No normal user needs that much sealant.
The image I showed was a redone silicon lottery delid
No delid tool will open one like I showed
It took a heat gun and couple razor blades to get it open.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #13 of 13 (permalink) Old 01-06-2019, 07:22 PM
Overclocker
Rep: 0
Oh gotcha. Ok thanks!
[Build Log]
OrganizedChaos
(19 items)
Intel Core I7 8700k
G.Skill Trident
Samsung EVO 850 SSD
EK Supremacy EVO
EK-FC1080 GTX FTW
Operating System
Windows 10
Keyboard
Corsair K70 RGB
Mouse
Logitech G-400s
Mousepad
Audio
Logitech Z-5500
Audio
Hyper-X Cloud II
