Delid questions - Overclock.net - An Overclocking Community
Delid questions
Old 11-16-2016, 01:13 PM - Thread Starter
Water-cooler
NBrock's Avatar
Rep: 44 (Unique: 38)
Hi Silicon Lottery!
I plan on deliding my 4790k and was wondering if you would be willing to share what epoxy you use to re-attach the IHS and what liquid electrical take you use on the resistors.
Thanks!
NBrock is offline
Old 11-16-2016, 01:19 PM
More Vcore
The EX1's Avatar
Rep: 107 (Unique: 99)
IMO, you shouldn't use an epoxy to permanently reattach the IHS. It creates a small gap between the die and the IHS, which is what causes a lot of the heat problems in the first place. Put a good liquid metal TIM on the die and lay the IHS back on top. Pick up some liquid electrical tape and put a thin layer on the exposed components on the PCB. Then reinstall the CPU back into the motherboard. Be sure to hold the IHS in place as you lower the locking arm.
Test Bench
(14 items)
1920X Threadripper
ASUS ROG Zenith Extreme
ASUS RX 560 Strix
ASUS RX 560 Strix
ASUS RX 560 Strix
G.Skill Tridentz DDR4
Western Digital Blue M.2
EVGA 1600 G2
Noctua NH-U12S TR4-SP3
Corsair SP120s
Corsair AF140
Corsair 780T White
Operating System
UNRAID
ASUS VG245H
ASUS VG245H
ASUS VG245H
Keyboard
RAZER Black Widow Ultimate
Keyboard
RAZER Black Widow Ultimate Overwatch Edition
Keyboard
Logitech G15
Mouse
Razer Naga
Mouse
Steelseries Warcraft MMO Mouse
Mouse
Logitech G502
Audio
Razer Kraken 7.1
Other
USB Hubs/extensions/cables
Intel Core i7 6950X
ASUS ROG Rampage V Edition 10
nVidia Titan Xp Collector's Edition Galatic Empire
Corsair Special Edition Blackout Dominator DDR4
Samsung 960 EVO M.2 NVM.e
Crucial MX300 SSD
OCZ SSD
Corsair HX1000i Platinum
Custom red sleeved cables
EK RGB Monoblock
Alphacool Monsta 360mm Radiator-White
Hadwarelabs NEMESIS GTX 560mm Radiator
Noiseblocker 120mm PWM fans-White
Noiseblocker eLoop 120mm fan-Red
Noctua Industrial 140mm fans
Phobya Slim 180mm fans
Swiftech D5 Pump
Bitspower D5 pump top
Bitspower D5 pump mod kit
Singularity Computers Ethereal Dual Reservoir mounts
Monsoon Free Center compression fittings
Bitspower Deluxe White fittings
Primochill Grillz Hex radiator grill
Primochill Advanced LRT Tubing
Koolance in-line filter
XSPC G 1/4 temperature sensor
Silverstone PWM fan hub
EK M.2 Heatsink - Nickle
FrozenQ LFX Reservoirs - White
FrozenQ LFX Aluminum Reservoir collars
Silverstone TJ11
Custom acrylic panels
Operating System
Windows 10
Alienware AW3418DW Ultrawide
Keyboard
GALAX HOF
Mouse
Razer Starcraft II Edition Mouse
Mousepad
GALAX RGB Mousepad
Audio
ASUS Supreme FX Hi-Fi DAC
Audio
Sennheiser Game Zero - White
Other
NZXT USB 2.0 internal hub
Other
NZXT Hue+
Other
Darkside LEDs and extensions
Ryzen R7 1800X
ASUS ROG Crosshair VI
Powercolor RX Vega 64 Red Devil
RX Vega 64 Limited Edition
GALAX HOF Limited Edition DDR4
Western Digital Black
Optical Drive
ASUS Blu-Ray/DVD-RW
EVGA 750 GQ
EVGA 750 GQ
Deepcool Captain 240mm
Primochill Praxis Wet Bench
Operating System
Windows 10
The EX1 is online now
Old 11-16-2016, 02:10 PM
Customer Support
Silicon Lottery's Avatar
Rep: 142 (Unique: 97)
Originally Posted by NBrock View Post
Hi Silicon Lottery!
Thanks!
This is similar to what we use, but comes in a smaller size:
Silicone
Liquid electric tape
Black Friday is coming up, and we're going to have a really low price on delidding ourselves if that interests you btw. thumb.gif
If you use enough pressure when drying, there will be no difference in temperatures compared to just letting the IHS sit free. There won't be a gap (at least not nearly as large) like there was before delidding, I've tested this dozens of times.
If the gap is a big concern to you, you could paint a small amount of silicone on the inside of the IHS like I've shown in the picture below. The silicone will be squished down once you put the IHS back on, so it should be the same as letting the IHS sit free.
Silicon Lottery is offline
Old 11-16-2016, 02:27 PM - Thread Starter
Water-cooler
NBrock's Avatar
Silicone
Thanks so much for the response, I really appreciate it. FYI both links are to the same thing.
Everything I have read or heard about you guys is top notch. I'll keep my eye open for your black Friday deals.
NBrock is offline
Old 11-16-2016, 03:15 PM
Customer Support
Whoops, here's the electric tape.
Old 11-16-2016, 06:49 PM - Thread Starter
Water-cooler
NBrock's Avatar
No worries! Thanks again for the info, I appreciate it.
NBrock is offline
Old 01-06-2019, 01:35 AM
Overclocker
OrganizedChaos's Avatar
Rep: 0
Sorry to resurrect this thread..
I'm going to be de-lidding my 8700k and was wondering if the silicon referenced in this thread is permanent once cured, or if it can be removed again with the delid die mate in the event that a re-application of liquid metal is needed. Also, since it seems the liquid electrical tape is recommended to cover exposed components on the PCB under the IHS, would it also be strong enough to hold the IHS down if applied around the edges?
I'd feel more comfortable if the IHS were re-attached some way, however it would seem like it would be a bad move to use a method that was permanent..?
[Build Log]
OrganizedChaos
(19 items)
Intel Core I7 8700k
Asus Maximus X Hero (Wi-Fi AC)
Nvidia Geforce GTX 1080 FTW
G.Skill Trident
Samsung EVO 850 SSD
Western Digital Black Edition
EVGA SuperNova 850 G2
EK Supremacy EVO
EK-FC1080 GTX FTW
EK Coolstream PE 360mm
EK-XRES 140 Revo D5 PWM + Multi-port Top added on
Phanteks Enthoo Luxe (Tempered Glass)
Operating System
Windows 10
ASUS ROG SWIFT PG279Q
Keyboard
Corsair K70 RGB
Mouse
Logitech G-400s
Mousepad
Razr Scarab - Battlefield 3 Edition
Audio
Logitech Z-5500
Audio
Hyper-X Cloud II
OrganizedChaos is offline
Old 01-06-2019, 02:18 AM
white owl's Avatar
Rep: 114 (Unique: 86)
LET works but if you don't have it you can use cellulose based clear nail polish (most clear is cellulose).
You don't need to re-apply liquid metal, mine ran for 3 years or so before I redid it and it made literally no difference.
To fasten the IHS just use RTV silicone (gasket maker). Use small dabs on the corners so it doesn't interfere with your IHS gap. I prefer to use nothing since the socket latch holds it in place.
I lay my case on it's side when I put the CPU in, center the IHS then latch it down.
There are several guides for all this.
Not sure why you'd want to but I'm sure clear nail polish and LET would hold the IHS down but I'd be worried about things like that or superglue bonding to the PCB and tearing it if the lid ever needed to come back off.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
Old 01-06-2019, 09:34 AM
Overclocker
Rep: 0
I may just leave it unattached then; thinking about trying to keep it perfectly still while clamping it down in the socket made me a little nervous.
Hypothetically, will the RTV silicon break loose if your were to need to get the IHS off again in the future? And I assume when you were talking about the liquid tape or clear polish you meant to cover the PCB around the die?
[Build Log]
OrganizedChaos
(19 items)
Intel Core I7 8700k
G.Skill Trident
Samsung EVO 850 SSD
EK Supremacy EVO
EK-FC1080 GTX FTW
Operating System
Windows 10
Keyboard
Corsair K70 RGB
Mouse
Logitech G-400s
Mousepad
Audio
Logitech Z-5500
Audio
Hyper-X Cloud II
Old 01-06-2019, 09:40 AM
Overclocker in training
ThrashZone's Avatar
Rep: 31 (Unique: 23)
Hi,
Liquid tape
One might need to redo a delid if not done properly
I had to redo my silicon lottery delid
They left the original Intel sealant instead of removing it so the contact is minimal for the liquid metal and just used more LM which drooped.... from too much space...
Any silicone based sealant can be used to reseal the cap
Just a small bead across the bottom and up a little to catch any if it drips... and a couple dots on the top to hold it till it dries.
Name:	SL delid opened.jpg
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
