Upgrade Time - A Few Changes About Reusing Components - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 12-31-2018, 12:26 PM - Thread Starter
SDBolts619's Avatar
Rep: 8 (Unique: 8)
Looks like it might be time for a system upgrade. Not so much because my rig is performing badly - I primarily play Destiny 2 and am happy with performance as is. However, my daughter, who uses my old gaming rig, is getting more heavily into content creation via Photoshop and such. I'm pretty sure that the old Core 2 Quad setup she's on is not the best for this. I guess if I were a super generous parent, I'd just upgrade her rig, but... you know, nothing wrong with hand me down stuff, right?
I currently have a 3770k setup that's been running at 4.9ghz for years on end with no issues. I have a Gigabyte GA-Z77X-UD5H motherboard and use an original Swiftech H220 cooler in a Silverstone Raven case all drive by a Silverstone ST1000-P. I want to keep the same case, as I love it, it fits where I need it to and I think that the 90 degree rotated design is still one of the best out there.
I've leaning towards a 9900k based system (Although I'm still open to the 9700k - feel free to convince me one way or the other) with a Gigabyte Designaire Z390 motherboard. Obviously, this means new RAM and I'd add an M2 drive as well for the OS.
My daughter's rig is a Q9550 based setup on a EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i motherboard in a Coolermaster Cosmos case with a Silverstone ST75F power supply.
So, here's my questions:
1) My current rig has all custom cabling and sleeving that I made. Can this be reused on the new motherboard? Have the PSU connectors changed between the 3rd Gen I7 and the 9th Gen I9? I have checked out some photos of the two motherboards and am not 100% sure about the 4pin connector on the newer board. I'm currently at work, but hopefully can try to make sure that there is a 4pin somewhere on my current motherboard. I'd really rather not have to make and sleeve new cables if it isn't needed.
2) I have an original H220 from Swiftech. Will this just need a cooling block adapter from Swiftech if I want to reuse it?
2a) If I went with a new Swiftech H240, are those able to be mounted on the bottom of the case?
3) Is my ST1000P power supply up to powering this new build? I'd drop one of my HDD's with the addition of an M2 drive as well as ditching optical drives, etc, so I think the new build might use less power than the current one.
And a couple of questions pertaining to my daughter's rig:
1) Will the ST75F PSU be up to the 3770k?
2) Her rig currently has a pair of 660 Ti video cards. What would be a good single card to replace them with in her machine? I'm thinking a 1060 with high VRAM due to what she uses it for. (She does game, but mostly stuff like The Isle, which I don't think is too system intensive)
Thanks in advance for any help with all the questions!
Blue Raven
(19 items)
Core i9 9900k
Gigabyte Z390 Aorus Ultra
EVGA GTX 1080 Ti FTW3
Corsair Dominator Platinum
Samsung 970 PRO NVMe PCIe M.2 2280
Samsung 860 EVO
Samsung 850 EVO
WD Caviar Green
Optical Drive
Samsung Writemaster DVD/RW
Silverstone Strider PS-ST90F-Ti
Swiftech H220
Silverstone Raven RV02-EW
Operating System
Windows 10
Asus ROG PG348Q
Keyboard
Corsair K95 RGB
Mouse
Corsair M95
Mousepad
Corsair MM300
Audio
Steelseries Arctis 7
Other
Razer Orbweaver
SDBolts619 is offline
post #2 of 3 (permalink) Old 12-31-2018, 12:35 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
Your PSU is fine to keep. ATX and EPS and PCI-E connections are all the same. If you have custom replacement cables and upgrade your PSU, no, you need new ones. If you have custom extensions, yes, you can move them to a new PSU.
9700K makes more sense for most people. If all you do is game, get the 9700K. If you'll use HT, get the 9900K.
1060 6GB or RX 580 would be a good upgrade from SLI 660 Tis.
I ran a Silverstone SFX-L 500w just fine on much higher end hardware than you're planning on running on a 750w unit. Aside from being a bit excessive, the ST75F is fine for your daughters build.
Look on Swiftech's site for what mounts it'll work on, but 1155/1150/1151 are basically always interchangeable.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #3 of 3 (permalink) Old 12-31-2018, 12:55 PM - Thread Starter
SDBolts619's Avatar
Rep: 8 (Unique: 8)
Thanks for the feedback Pook. After looking at the manuals for both motherboards, it does look like the Designaire has a 4pin 12v connector that my current mobo doesn't have. I'm sure I have open spots on my PSU, so will have to make one new cable. Still, it's way better than a whole set!
Blue Raven
(19 items)
Core i9 9900k
Samsung 860 EVO
Samsung 850 EVO
WD Caviar Green
Optical Drive
Swiftech H220
Operating System
Windows 10
Asus ROG PG348Q
Keyboard
Corsair K95 RGB
Mouse
Corsair M95
Mousepad
Corsair MM300
Audio
Other
Razer Orbweaver
