Help with slow to load right click on icons. - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 02-09-2019, 12:33 AM
white owl's Avatar
Rep: 114 (Unique: 86)
Has it always been this way or did it happen after an update?
I'd make a bootable flash drive with Windows to-go or create a new install on a partition, boot into that and see if the issue is there. If it's not you have an issue with your installation of windows or with something installed/not installed on it.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #12 of 15 (permalink) Old 02-09-2019, 01:04 AM
Memory Overclocker
Rep: 0
Good general idea, but maybe just boot into safe mode first and try that.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
post #13 of 15 (permalink) Old 02-09-2019, 01:20 AM
white owl's Avatar
Yeah probably do that first. Sometimes Windows will break on it's own via update and Safe Mode could give you the same issue...or not? Even if the issue isn't present in Safe Mode the final outcome will likely be a clean install unless you can figure out exactly what the issue is.
Windows constant network/RAM/CPU usage, bloatware and re-installation of the bloatware and inconvenient updates that could bork your rig are the primary reasons I disable all that garbage. Windows is always just like I left it, no surprises.
Fyi, if you're making a new partition or Windows to-go stick, don't worry about activation or any of that if you don't want. Windows works exactly the same way without activation.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #14 of 15 (permalink) Old 02-11-2019, 01:20 AM - Thread Starter
Jellystab's Avatar
Rep: 1 (Unique: 1)
I finally fixed the issue!
I downloaded all of my motherboard drivers. I installed the first driver which was the Intel Chipset drivers, and instantly everything was opening much quicker.
After I restarted, everything opened instantly. Right clicking on icons or folders was quick again, opening Chrome was quick, opening other windows like the Networks and Sharing window loaded instantly.
I've been running my computer for more than a day straight now (not shutting it down, no reboots etc.) and everything is still running great. Before it would take about a day until everything was super slow.
Thanks to everyone that helped me resolve this issue! +Rep for all!
Jellystab is offline
post #15 of 15 (permalink) Old 02-11-2019, 01:29 AM
Kill Confirmed
speed_demon's Avatar
Rep: 57 (Unique: 47)
Haha yep, not having the Intel drivers sure causes lots of headaches. It's good to hear you're all fixed up now.
speed_demon is offline
