need suggestions with 9900k upgrade - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 02-10-2019, 03:11 AM - Thread Starter
SONICDK's Avatar
Rep: 1 (Unique: 1)
hey, im looking for upgrade for my pc, i been looking at some parts, i would really like some input and suggestion, also putting my reason behind the parts
i want air cooling, my target is to overclock the 9900k to 5.0-5.1 on all cores, dont know what thermal paste to buy,
it would be my first time really overclocking a cpu, except my poor 2600 non k, that i could increase ration to from 3.4, to 3.9
motherboard:
Gigabyte Z390 AORUS MASTER, seen some reviews, and gamers nexus really talked well about the vrm, i need some reasons to buy such an expensive motherboard, the AORUS ULTRA is the same price here where im bying, so my budget choice would be Aorus Elite
9900k, the price is too close to the 9700k, so i just want to go all in on cpu,
Noctua NH-D15, checked some reviews and seem like this is marginal better that dark rock pro 4 and nh-dh15s, and seems to be quiet all of them?
memory: 2x8gb
G.Skill: 4133 Mhz cl 19-19-19-39 "F4-4133C19D-16GTZSWC"
G.Skill TridentZ 4400MHz 19-19-19-39 "F4-4400C19D-16GTZKK" cost 22% or 60€ more, seen some test in games, and cpu performance increase the faster the ram, and dont want to manual oc ram myself, just want to turn on the xmp profile and be happy,
the rest of my current pc,
psu, Cooler Master PowerSupply V750S "RS750-AMAAG1-EU"
case, Phanteks Enthoo EVOLV ATX PH-ES515E_GS,
gpu, MSI GTX 970 Gaming 4GB
cpu, cooler Cooler Master Hyper 212X would that cooler be enough to a 9900k?
SONICDK is offline
post #2 of 24 (permalink) Old 02-10-2019, 04:10 AM
Senior OCN Member
shilka's Avatar
Rep: 2696 (Unique: 1603)
The NH-D15 and the NH-D15S is the same cooler only difference is the S version is off set to one side and only comes with a single fan
Also the last few parts do you already have those or do you want to buy? and last what will you be using the machine for? AMD Ryzen might be a better option for you
Seravee
(31 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
Seagate Ironwolf Pro 10 TB
Seagate Ironwolf Pro 12 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
x5 Noctua NF-A14 FLX
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 49UH750V 4K LED TV
Keyboard
Corsair Gaming Strafe RGB
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
Other
CableMod LED Strips
shilka is online now
post #3 of 24 (permalink) Old 02-10-2019, 04:16 AM - Thread Starter
SONICDK's Avatar
Rep: 1 (Unique: 1)
okay so would the nh-d15s be a better choice, it will get a bit more expensive if i need to add the second fan?
yes everything under the psu, is my current parts,
its motherboard, memory, cpu, cooler, and paste im looking after,
im mostly going to game with my pc, with with a possibility in streaming without loosing out on too much cpu power
SONICDK is offline
post #4 of 24 (permalink) Old 02-10-2019, 04:47 AM
Senior OCN Member
shilka's Avatar
The NH-D15S is good cooler if you have a small motherboard or PCI-E slots and RAM very close to the CPU socket and the cooler needs to clear those
For most motherboards there is more than enough room for the D15 to clear, i have an X99 motherboard and with a D15 i would lose the top PCI-E slot so i bought the D15S to clear it
The second fan only makes the CPU 2c cooler so you can get the D15S if you want or you can get the D15
Seravee
(31 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
Keyboard
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
Other
CableMod LED Strips
post #5 of 24 (permalink) Old 02-10-2019, 06:21 AM
Almost Canadian
OutlawII's Avatar
Rep: 38 (Unique: 34)
If you want to run 5.0 to 5.1 on a 9900k go liquid. Dont waste your money on 4400 or 4000 mhz ram kits just get some 3200 or my preference 3600 mhz.
OutlawII is offline
post #6 of 24 (permalink) Old 02-10-2019, 08:09 AM
Memory Overclocker
Rep: 12 (Unique: 6)
You can read around here the various 9900k overclocking threads to form your own opinion, but it seems to me that most people find it hard to hit 5.0-5.1 on air cooling with that CPU unless you get really lucky in the lottery and get a CPU that will hit those speeds on low voltages.
I didn't want to mess with water cooling so I got the i7-9700k instead because it's a bit easier to air cool when overclocked and I can run it at either 5.0 or 5.1 though temps under stress test are a little higher at 5.1 than one would want for a regular load.
memory: 2x8gb
Keep in mind that one can't expect that an XMP profile above 4000MHz will "just work" and not require messing with timings to get it totally stable. If you don't want to mess with memory and want XMP to just work for sure, I'd suggest (like others have done here) just getting 3600. For gaming, there is apparently not really that much of a difference in actual performance.
Probably not.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
post #7 of 24 (permalink) Old 02-10-2019, 10:01 AM
tatmMRKIV's Avatar
Rep: 120 (Unique: 82)
I'd recommend the ASRock Taichi Ultimate mobo, over 4000mhz on ram will really need a good mobo and cpu. I did 4600 and it took alot of vccio and vccsa on a Dark, but if any mobo can do it for a reasonable price its the asrock, they have amazing memory capability.
Gigabyte is not great for memory. Especially if you have to manually do timings, which alot of people are needing to do with over 4000 memory kits on z390
All the affordable asus boards wont do over 4000mhz with mem
5.1 on all cores may be difficult to achieve on air, it was tough with a EK-360 Phoenix on a retail chip. you will need a good sample for sure
I read there are poorly optimized games that run much better over 4000mhz, people were referencing some article
theres a guy on hwbot selling some c19 4266 for low also, https://community.hwbot.org/topic/18...s-cheap-b-die/
(If y'all) ain’t ready for the old murder, then what you gonna do with the new me?
tatmMRKIV is offline
post #8 of 24 (permalink) Old 02-10-2019, 10:06 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 938 (Unique: 576)
The vanilla non-Ultimate Taichi is the same as the Ultimate if you don't care about slightly slower WiFi/10Gb LAN. Mine is great.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill 16GB DDR4 4133
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #9 of 24 (permalink) Old 02-10-2019, 10:08 AM
tatmMRKIV's Avatar
Quote: Originally Posted by The Pook View Post
The vanilla non-Ultimate Taichi is the same as the Ultimate if you don't care about slightly slower WiFi. Mine is great.
then I'd definitely recommend that, I wasnt sure. ASRock is a solid company and they put out better boards, at a much lower cost than their competitors.
post #10 of 24 (permalink) Old 02-10-2019, 10:11 AM
9 Cans of Ravioli
The Pook's Avatar
Forgot it has 10Gb LAN too, but yeah, that's about it. VRM and all the important bits are identical.
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
Audio
Philips SHP9500S
Audio
Audio
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
Tags
9900k , Help Needed , Upgrade
