PC freezing after GPU change (it's not GPU fault) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 40 (permalink) Old 04-01-2019, 05:07 PM
Graphics Junkie
UltraMega's Avatar
Rep: 59 (Unique: 53)
Your new video card draws a lot more power than your old one and your really pushing it with that power supply. For a main stream gaming desktop, never go less than 650 watts for the power supply so you have a little room to upgrade later on. Replace your power supply before anything else.
Geforce 950 power draw is about 115 watts.
Geforce 1060 power draw is about 170 watts.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is online now
post #12 of 40 (permalink) Old 04-01-2019, 05:20 PM - Thread Starter
Rep: 1 (Unique: 1)
Yeah.. I know it's not the best one but even so.. gtx1060 is 140w max.. i5-6600k is 95w.. total of 240w.. even if I OC everything my config would not pull more than 350w in best case.. make it 400w.. if psu is 600 bronze, at 400w there will still be space for another components.. and spare power as well.. if you take degradation in account.. I'd still have 100w spare headroom. Btw its 50a 12v rail...
But yeah , I'll replace that as well.
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
MSI GTX 1060 Gaming X+ 6G
Kingston HyperX Fury 2666MHz
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Cooler Master MB511 RGB
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
post #13 of 40 (permalink) Old 04-01-2019, 10:21 PM
Graphics Junkie
UltraMega's Avatar
You also have hard drives, fans, lights perhaps.
If you had no issues before you upgraded to a new GPU (that draws more power), it's almost for sure either the power supply or the GPU.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #14 of 40 (permalink) Old 04-01-2019, 10:54 PM
Have you seen my Baseball
Drake87's Avatar
Rep: 29 (Unique: 27)
Could be a bad gpu power cable. It sounds like it's the psu, or something related to it.
Drake87 is offline
post #15 of 40 (permalink) Old 04-01-2019, 11:38 PM
dontworkSundysormedaysoff
buellersdayoff's Avatar
Rep: 7 (Unique: 7)
VCCSA : 1.240v - 1.256v
VCCIO i cannot find in HWiNFO64...
Current RAM Kingston 2666mhz, system uptime 26hours, played warframe and CSGO, no freezes.. i took step further.. started both warframe and csgo at exact same time, and kept both games running, playinh 1h with every couple minutes alttabbing to another game and vice verca.. no freezes... The i just left both game running for another 5 hours.. no freezes.
And yes, changing ram : powering down PSU, unplugging cable, waiting 30 seconds to discharge capacitors, the holding power button for another 10 seconds just be 100% sure that motherboard capacitors are discharged, and only then tinkering with hardware.
Is my VCCSA max value of 1.256v bad?
It's 4x4GB HyperX fury cl15 2666MHz
Voltage is ok, a bit higher than necessary maybe but not to worry about, I think you've solved the issue with replacing the ram modules. Freezing would most likely be cpu waiting for data from faulty ram
AIRBOURNE
(10 items)
buellersbox
(17 items)
i7 7700k
asus maximus viii hero
msi 1080ti gaming x
corsair 3200mhz
samsung 950 nvme
corair rm850x
cryorig r1 universal
TT modified
Operating System
win10
acer predator x34
i7 6700k
Asus maximus VIII Hero
Msi gtx 980ti
Corsair
samsung 950 pro m.2
samsung ssd
2tb spinner
Optical Drive
blu-ray rw
Corsair RM850x
custom EKWB
Phanteks
Operating System
windoze 10
Acer X34 gsync
Keyboard
Logi Orion G910
Mouse
Logi G502
Mouse
Logi 440
Audio
Kingston Hyperx cloud II + Edifier R1280T
buellersdayoff is offline
post #16 of 40 (permalink) Old 04-02-2019, 12:17 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Its not a problem about wattage he has enough UltraMega so stop saying the PSU is not big enough thats not the problem and 50 watts more is going to make ZERO difference!
The problem is the PSU is not all that great quality it has nothing to do with the amount of wattage it can do
buellersdayoff needs a better quality not a bigger unit and even if he went a bought a 550 watt it would still be big enough
Modern PC hardware draws less power than everyone think it does
Edit: By the way buellersdayoff the 80 plus rating has nothing to do with quality and you can buy PSU´s with an 80 plus Titanium rating that are crap
The PSU you have is only rated to do its full wattage at 40c so if the PSU reach 40c it will shut off and 40c is not all that high
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #17 of 40 (permalink) Old 04-02-2019, 12:23 AM
Graphics Junkie
UltraMega's Avatar
The problem is the PSU is not all that great quality since HEC is the OEM that made it and the number of good units HEC has ever made can still be counted on one hand
True, a better 600W PSU would work or a bigger PSU of similar quality.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #18 of 40 (permalink) Old 04-02-2019, 12:26 AM
Senior OCN Member
shilka's Avatar
Turns out the 650 watt is HEC made and the 600 watt is made by Andyson so i dont know how good it is and there are no reviews
But as i said in my edit in my last post the unit can only do its full wattage at 40c so if buellersdayoff live somewhere hot thats a huge problem
Almost everything mid and high end is rated for 50c only lower end units are rated at 40c
At least they are not rated at 30c that would make them truly useless in anything but winter
Anyway the EVGA BQ series are not all that great
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #19 of 40 (permalink) Old 04-02-2019, 05:52 AM - Thread Starter
Rep: 1 (Unique: 1)
I thought so too, I had Cooler Master 500w 75+ 20a +12v rail.. It was able to push my 1060 without any problems, including all led (i have 3 led fans) but still I replaced it with EVGA, I know it's lower tier, but this PSU was in a case running i5-8600k with GTX 1080ti STRIX, and it was causing GPU to downclock itself.. not freezes.
Same PSU different RAM modules, system uptime 1 day 15 hours, 10 hours of gaming, still no freeze.
Yeah, I belive it was the RAM since no freezes now at all, not a single stutter. But still, how did Crucial passed memtest then?
Usually in my room it's steady 20-24c, both during winter and summer ( I have AC in my room) so i don't think 40c would be an issue, since I'm not drawing full wattage..
At PSU calculator... once I set everything to OC max, i would still need 490w..
+3.3V +5V +12V
10.6 A 9.3 A 34.0 A
82W 408 W
here is from PSU calculator.. this is full OC all the time, TDP 100% with GameON 24/7 settings, will all fans, all monitors, every single thing that i have
and my PSU is 600w on 12v rail with 50A... so the only thing is +40c, which will never reach under current setup, my PSU is separated from other hardware, and it has it's own dedicated space, air goes in from bottom, exit on back, case is properly set that there is at least 2.5cm between my desk and bottom of PSU (where fan is)
Yeah, I know.. this was in a budget tbh, but still plenty of power in this PSU I belive...
Yeah, I know that... on summer we have really high temperatures, but one AC is always on that cools down entire house, and there is one AC just above my desk (and PC) that I power on by need.. for example if in my room temp reach 25c, it is hot.. so I turn that AC on, drop that to 20c in 30 minutes, and great.. I never once had issues with Cooler Master 500w 75+ (which is a lot worse than this one) and that CM was rated at 0-40c as well...
39 hours of uptime, no freezes, without OC, only change - RAM memory
If any values are not in order, please do let me know
EDIT : and almost forgot, picture of GPU-z for same at as HWiNFO (ambient temperature 20.4c-22.8c measure by digital thermometer)
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
post #20 of 40 (permalink) Old 04-02-2019, 06:02 AM
Senior OCN Member
shilka's Avatar
PSU calculators always overstate numbers by at least 28% so forget about what they tell you its wrong
Your room might be at 20-25c but the PSU is will never be the same temp as the room since it needs to convert power from the wall to power the PC can use so even at ilde it needs to work
Its not a problem with wattage you got more than enough the problem is the unit is bit rubbish and only rated for full wattage at 40c
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
Tags
freeze , inteli5 , lockdown
