PC freezing after GPU change (it's not GPU fault) - Overclock.net - An Overclocking Community
post #1 of 40 (permalink) Old 03-31-2019, 08:13 PM - Thread Starter
Rep: 1 (Unique: 1)
Hey guys,
First of, here is my whole configuration. I will try to provide as much details as I can.
PSU : EVGA 600 BQ 80+ Bronze (600w)
MB : Asus Z170-A (LG1151 socket)
CPU : Intel Core i5-6600k
GPU : MSI GeForce GTX1060 6GB Gaming X Plus (9GHz memory speed)
COOLER : Cooler Master Hyper EVO 212 (single fan, push config)
RAM : Crucial CT8G4DFS8213.M8FA 1x8GB
SSD : Samsung 850 EVO 250GB (AHCI)
HDD : Some WB blue just for file storage
Monitor 1 : Asus 24" IPS panel 5ms connected via HDMI
Monitor 2 : LG 19" TFT panel 5ms connect via VGA (GPU > Display Port to VGA active adapter > VGA > Monitor)
Mouse : Genius Deathtaker
Keyboard : Genius K9 Gaming
PC CASE : Cooler Master MasterBox 511 RGB
Fans : 3 pressure fans pushing air in from front of case, 2 airflow fans pushing air out of case (one at end of case, and one on top)
Fans are DC, not PWM, all properly configured in BIOS, 3 fans are on separate headers, and 2 are on splitter (splitter is default noctua splitter that you get from buying their fans)
Hardware temperatures (all temperature are measured by HWiNFO64 while ambient temperature is 21-23c) :
CPU idle : 24-26c
CPU heavy load (prime95 26.6) : 50-54c
GPU idle : ~35c (fan off by default)
GPU heavy load (heaven, furmark, superposition) : not a SINGLE time reached more than 64c, and that 64c was one peak, usually it sits between 62-63c (fans start spinning at 61c)
Sorry for long post, but want to make sure you have all informations, issue is following:
I had Gigabyte GTX950, sold it, and bought used GTX 1060 from above. Before installing new GPU, I went into safe mode and used DDU to wipe all GPU drivers from system, then installed new GPU and all drivers for it from GeForce Experiance.
New GPU is here, everything is great, played Apex Legends on everything ULTRA (except textures, because ultra textures requires 8GB VRAM, and my GPU is 6GB VRAM), pushing between 80-144 FPS (Played for 2 hours). Then I played bit of warframe, also everything on ultra but with vsync ON to 60Hz(fps).. not a single issue, after that I start CSGO and my PC freezes completely with audio glitch. By that I mean, the last sound I heard milisecond before freezing is the sound that is repeating constantly. Nothing works, keyboard, mouse, even restart button on my pc case is not working. Only way is to hold power button to force shutdown or switch PSU switch to off.
Friend told me that CSGO is built on ancient engine, and that MAY be some driver conflict... okay, I did FULL Windows 10 wipe, by that i mean full reinstall from USB, and formatting ssd from scratch. First thing after new windows install, installed Asus chipset drivers, then everything else for motherboard (just drivers, not a single software, with exception of Realtek HD Audio Manager), then GeForce Experience, then latest NVIDIA drivers from GFE. After that Steam and Origin (Warframe, CSGO, Apex Legends).. that was left overnight to download... when I woke up, i started first CSGO since that's the one that kept my PC freezing, played for and hour.. no freeze. Great, I thought my problems were solved... Then later that day I start Warframe (when you install warframe on new system it launches at 800x600 windowed mode) entered email and password, submit, PC FREEZE. At that point I'm already blaming GPU, since with previous GPU didn't had ANY errors nor freezes. Took my GPU to friends PC, we stress tested it for 1h, not a single issue. Came back home, put GPU in my system, load up windows, warframe, PC FREEZE. That's not good enough... friend brings his Zotac GTX 1080 mini, we put it in my system, start up warframe, PC FREEZE, restart pc, start CSGO, PC FREEZE.
I really don't think it's faulty GPU unit, because it's simply nearly impossible that 2 different GPU's from 2 different vendors, freezes system in exactly same way. If it was ANY other type of crash, I would return GPU instantly.. but like I said... 2 different GPU's on my system, exactly same freeze.
Things I tried :
-Full Windows 10 reinstall
-Power Options set to "High Performance"
-Reinstalling GPU drivers
-Disabling 2nd monitor (19" one) that had adapter, and used only main one with straight HDMI cable
-Tried with another monitor with native DVI-D with straight DVI-D to DVI-D cable
-Removing ALL and ANY types of overclocks (I do my CPU overclock via XTU software)
-BIOS load optimized defaults
-BIOS battery remove
-Reseating RAM memory to all 4 available slots
-Unplugging HDD and using SSD only
-Switched SSD from SATA Express 10Gbps lane to default SATA 6Gbps lane
-Disabling iGPU in BIOS
-Ran Prime95 26.6 for 30 minutes, no errors
-Ran Heaven for 1h, no errors
-Ran MemTest86 for full 4 cycles (13 test, 4 times ~ 2h30m), no errors
-Setting DRAM Frequency from AUTO to DDR4-2133MHz (that's my RAM speed)
-Cleaning GPU and RAM connectors on motherboard (canned air cleaning)
-Powering my PC separately from monitors, other power outlet
-Powering my PC from different source (not on same fuse as my TV and monitors, fuse that doesn't have anything drawing power from it)
-Powering my PC directly to power outlet (without any extension cords)
-Unplugging all USB devices, just leaving ethernet, keyboard, mouse and power cable
-Scanned entire PC for viruses (Licenced ESET Internet Security 12.1.31.0 [latest version with all updates] that I've been using for more than 2 years)
-Every Windows 10 update
-Disabling Virtualization in BIOS
-Inspecting all capacitors on motherboard (all are fine)
-Plugging keyboard and mouse to USB2.0
All of that and freezes still happens. But the thing is, it's full freeze-lockdown, there is no BSOD, no errors, so I can't even read what's causing the issue because it's just freezing, it doesn't give any error, I tried to leave it frozen for 30 seconds to see if BSOD will show up, but it didn't. When PC freezes, on my other monitor I have GPU-Z and HWiNFO64 opened, when freeze happens (minimum-maximum stats by HWiNFO64) :
CPU temp 30c-44c
CPU Vcore : 1.184v-1.248v
CPU fan : 730RPM-893RPM
CPU usage : 0.07%-100%
GPU temp : 55c-61c
GPU Vcore : 0.625v-1.063v
GPU fan : 0RPM - 844RPM (0%- 30%)
GPU Core Load : 0%-72%
DRAM 1.200v
5 other chassis fans from ~760-920RPM
SSD temperature 28-34c
All cores thermal throttling : NO - NO
All cores critical temperature : NO - NO
All cores Power Limit : NO - NO
Package/Ring Thermal throttling : NO - NO
Package/Ring critical temperature : NO - NO
Package/Ring Power Limit Exceeded : NO - NO
CPU Package Power : 18.488W - 50.488W (TDP 91W)
GPU Power : 8.837W - 128.555W (TDP 125W)
My motherboard doesn't have VRM temperature sensors, in HWiNFO64 they introduced that meter (VR VCC) for Hasswel CPUs, and it's showing for me as 79c-84c, but when I touch VRMs with my finger, they are MAXIMUM 40c, because I can hold my finger on them and it won't burn me, it will not cause that heat, that I have to move my finger (home heating system is at 60c, so I know how it feels when you touch 60c radiator).
Latest thing that I tried was removing 1x8GB Crucial RAM and putting in 4x4GB Kingston HyperX DDR4-2666MHz (I had to borrow it from friend, it's not mine) and since then, I've been actively playing Warframe for about 1h, and CSGO for 30 minutes, no freezes. I left my Warframe running in background (single player instance with heavy open world RAM usage) AND started CSGO just in main menu... Warframe was in background for 4 hours WITH CSGO for about 1 hour... No freezes. Now, I don't want to jynx it, but I highly think it's RAM memory fault, because since I put Kingston, didn't had any freeze (PC uptime with games 5h20m), that's very little time to test if it's RAM fault or not because even with Crucial RAM it happend that I play games for 2,3 hours and no freezes, then I start game and PC FREEZE.
1. Is it possible that Crucial RAM was faulty, but GTX 950 wasn't able to utilize those sectors because of being lower end GPU?
2. Is it possible that GTX 1060 is more aggressive and needs dual channel?
3. How is possible that only thing I changed was GPU and those issues start to happen, and it's not GPU fault?
4. Is it possible that MemTest86 needs more than 2 hours to find RAM issue?
5. I've read somewhere that MemTest86 is there to report hardcore error, it's not reliability of RAM test, true?
6. I left my PC running overnight, just on desktop mode, and when I wake up, it's working, not frozen, IF RAM is culprit wouldn't that happen anyway?
I will continue to test throughout the day, since it's 5am currently, and will report if anything strange happens. I know I made reaaaly long post, but I wanted this to be in details as much as possible in order to narrow down the issue and get as much input from you guys, your thoughts, opinions, advises, suggestions...
Thank you for reading this until the end
PS : I actually had to type and save in text editor all text in order to save what I typed if I get freeze, but I didn't. Also important note : freezes happens only during launching the game, or playing the game, it did not happen in desktop/internet browsing/youtube, etc...
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
MSI GTX 1060 Gaming X+ 6G
Kingston HyperX Fury 2666MHz
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Cooler Master MB511 RGB
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
post #2 of 40 (permalink) Old 04-01-2019, 12:24 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Might or might not be related but your PSU is not very good
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 40 (permalink) Old 04-01-2019, 01:58 AM
RIP OCN
Rep: 28 (Unique: 21)
Yeah was going to say I've had similar issues related to PSU or with motherboard power draw. Maybe check with a program like hwinfo to see what your 12V, 5V and 3.3V rails are pulling.
anti-clockwize is offline
post #4 of 40 (permalink) Old 04-01-2019, 02:05 AM
Senior OCN Member
shilka's Avatar
Software readings are very inaccurate so a digtal multi meter is much better
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #5 of 40 (permalink) Old 04-01-2019, 03:49 AM - Thread Starter
Rep: 1 (Unique: 1)
PSU is tested with i5-8600k and GTX 1080ti ROG Strix.. it caused gpu clocs reducing, but not freezing. 1080ti is more than 250w, mine is max 130w
Hwinfo (min-max status)
+5v : 5.040v - 5.040v
+12v : 11.904v - 12.000v
There are multiple 3v...
3VCC : 3.312v - 3.344v
3VSB_ATX : 3.376 v - 3.392v
BAT_3V : 3.088v - 3.105v
Yeah, I dont have it or know where to put "needles" to measure even if I had it.. If it's from 24pin then i can manage to measure that.. but if it's from MB diode, small smd or something.. then I can't.
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
post #6 of 40 (permalink) Old 04-01-2019, 05:05 AM
dontworkSundysormedaysoff
buellersdayoff's Avatar
Rep: 7 (Unique: 7)
May have missed it, but have you got the latest bios for the mobo? From what I've seen freezes are usually memory related and looks like you've isolated the issue with the ram being swapped out, it might be a bad stick try clocking it lower than stock. Also try hci memtest or gsat for memory testing.
AIRBOURNE
(10 items)
buellersbox
(17 items)
i7 7700k
asus maximus viii hero
msi 1080ti gaming x
corsair 3200mhz
samsung 950 nvme
corair rm850x
cryorig r1 universal
TT modified
Operating System
win10
acer predator x34
i7 6700k
Asus maximus VIII Hero
Msi gtx 980ti
Corsair
samsung 950 pro m.2
samsung ssd
2tb spinner
Optical Drive
blu-ray rw
Corsair RM850x
custom EKWB
Phanteks
Operating System
windoze 10
Acer X34 gsync
Keyboard
Logi Orion G910
Mouse
Logi G502
Mouse
Logi 440
Audio
Kingston Hyperx cloud II + Edifier R1280T
buellersdayoff is offline
post #7 of 40 (permalink) Old 04-01-2019, 05:32 AM
Rep: 57 (Unique: 56)
Should be the ram. If your able to, enable XMP in BIOS with the Crucial ram. If not take a look and check if the stick runs at 2400mhz, if it runs 2133mhz, then change it. Just leave timings auto for now, but they run CL17 at 1,2v.
DoctorNick is offline
post #8 of 40 (permalink) Old 04-01-2019, 09:37 AM - Thread Starter
Rep: 1 (Unique: 1)
I cannot belive that I missed saying that. Yes I have upgraded BIOS to latest version (version 3802 : date 27.01.2018) when I bought this MB. Almost first thing I've done when I got it.
I really hope that was the problem, uptime 19h and no freezes, but that's still not valid, since even with previous RAM it used to be uptime of 2 days, no freezes and then ran CSGO and FREEZE.
Currently my Crucial is not here, I lend it to some guy since I already have Kingston here that I can use. I don't think I can clock it any lower.. by default that stick is 2133MHz .. I don't know if my MB allows me to go lower than that.. but still, how did it passed memtest then? If there is something not working as intended, shouldn't error pop up almost instantly? Because those freezes were happening only when gaming, while desktop / web, it did not happen.. But still.. 2 freezes per day at least and 4 cycles of memtest showed no error... Is memtest86 supposed to show only "bad sectors" on RAM itself, or check timing, latency, reliability, voltages? As for other tests you mentioned, thank you for taking time to recommend me those, I'll do them on this Kingstons to make sure they are okay, but since Crucial RAM is currently not here and I can't test it ATM, if this Kingston turns up not to have freezes, Crucial one is instantly going into trash can
Crucial is not XMP compatible... I tried EZ_XMP switch on MB itself with Crucial RAM, there was no XMP profile in BIOS and, still it was freezing. Also, Crucial is default 2133MHz, not 2400MHz.
THE ONLY THING I can remember and it might affect RAM itself : When I changed GPU, friend bring this Kingston that I'm currently using to see effects of GTX1060 with 8GB ram single channel (2133MHz) Crucial vs. Kingston 2x4GB dual channel (2666MHz), because it is somewhat fair 8GB vs 8GB comparison. Once I put his RAM, I also overclocked his RAM to 2933MHz. He had to got, I just unplugged RAM, put mine (Crucial) in, and booted PC, I was away for 2 or 3 minutes, I came back and there was no picture on monitor, instantly I remembered that I did not returned frequency back to AUTO, so I forced shutdown, BIOS booted in safe mode, and returned back to auto. I should also mention, OCing RAM was inside BIOS was JUST changing DRAM frequency from AUTO to DDR4-2933, didn't messed with any voltage and CL timings. Could that damaged my Crucial RAM? it tried to push 2933MHz, and it failed, maybe pushing more voltage on AUTO settings?
Another thing maybe you guys, can help me, when I was putting those Kingston RAMs in slots, I put all 4 stick, FANs full speed, no post and MB led was constantly switching between CPU and RAM led (red light).. After that I removed all sticks and just put 2 sticks (slots 2 and 4 - dual channel), post was there, windows booted perfectly.. then I shutdown, remove those from slots 2 and 4, and put exact same modules in slots 1 and 3.. again, post, windows boots up perfectly... after that I put again 2 more modules, and... post was there, windows booted perfectly?
Why didn't wanted to boot first time with all 4 sticks? When I was removing RAM, there was this crackling sound, like connectors are breaking, of course that was not the case, I do this very carefully, and after couple of installations and removal of RAM stick, I noticed that sound was gone... maybe no one placed before me any sticks in those slots and they are well.. kinda like brand new... I will continue to test with Kingston RAM and keep you posted here.
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
post #9 of 40 (permalink) Old 04-01-2019, 01:41 PM
Rep: 7 (Unique: 7)
I hope you shut off the power supply and discharge mobo power before tinkering with ram modules, anyway the problem could be related to the memory controller on the cpu, check the vccio vccsa voltages are below 1.25v
AIRBOURNE
(10 items)
buellersbox
(17 items)
i7 7700k
msi 1080ti gaming x
corsair 3200mhz
samsung 950 nvme
corair rm850x
TT modified
Operating System
win10
acer predator x34
i7 6700k
Msi gtx 980ti
Corsair
samsung 950 pro m.2
samsung ssd
2tb spinner
Optical Drive
blu-ray rw
Corsair RM850x
custom EKWB
Phanteks
Operating System
windoze 10
Acer X34 gsync
Keyboard
Logi Orion G910
Mouse
Logi G502
Mouse
Logi 440
Audio
post #10 of 40 (permalink) Old 04-01-2019, 04:27 PM - Thread Starter
Rep: 1 (Unique: 1)
VCCSA : 1.240v - 1.256v
VCCIO i cannot find in HWiNFO64...
Current RAM Kingston 2666mhz, system uptime 26hours, played warframe and CSGO, no freezes.. i took step further.. started both warframe and csgo at exact same time, and kept both games running, playinh 1h with every couple minutes alttabbing to another game and vice verca.. no freezes... The i just left both game running for another 5 hours.. no freezes.
And yes, changing ram : powering down PSU, unplugging cable, waiting 30 seconds to discharge capacitors, the holding power button for another 10 seconds just be 100% sure that motherboard capacitors are discharged, and only then tinkering with hardware.
Is my VCCSA max value of 1.256v bad?
It's 4x4GB HyperX fury cl15 2666MHz
MilanceX iCore
(12 items)
i5-6600k
Asus Z170-A
Samsung EVO 250GB
EVGA - BQ 600W
Hyper EVO 212
Operating System
Windows 10 Pro
Asus VX239
Keyboard
Genius Gaming K9
Mouse
Genius Deathtaker
MilanceX is offline
Tags
freeze , inteli5 , lockdown
