Memory Speed vs Timings - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-27-2019, 03:12 AM - Thread Starter
Matt-Matt's Avatar
Rep: 224 (Unique: 176)
Hey guys,
I posted a thread a while back about some DDR4 overclocking on my system and I'd like to post and update this thread with my results as well as performance gains/losses.
As we all know; at least in the past with DDR3 Intel systems typically love speed over timings but is this still the case?
My current system is as follows:
CPU: 8700k @ 5.2GHz
RAM: 16GB (2x8GB) G-Skill Trident Z RGB 3000MHz CL16
Board: Gigabyte Gaming 7 z370 (On water)
GPU: GTX1080
Boot Drive: 970 Evo (Soon to be the Evo Plus..)
PSU: EVGA 850w P2
As for the settings I will be using I currently have two setups and am considering a third/fourth based on what people want to see.
All configs will have
CPU: 5.2GHz
Uncore: 5.0GHz
System Agent: 1.050v
Config 1: Pure Speed
Speed: 3900MHz
Timings: 16-16-17-36 1T, tRFC 526
Voltage: 1.38v
Config 2: Mixture
Speed: 3200MHz
Timings: 14-15-15-35 1T, tRFC 401
Voltage: 1.38v
Config 3: Stock (XMP)
Speed: 3000Mhz
Timings: 16-18-18-38 2T rRFC 526
Voltage: 1.38v
Config 4: ???
*** To come ***
I'm welcome to any suggestions for this and to see what I can do.
Benchmarks:
I will do some synthetics to start with, I feel that I need to tweak my mixed timings vs speed overclock a bit more however.
Eleven Fiffty Five
(24 items)
Convertible i5 3570k (De-Lidded)
Gigabyte Z77x-D3H
XFX R9 290 With Koolance Block (1179/1450)
16GB G-Skill Ares 1866
Samsung 840 Evo
Seagate Barracuda 2TB
Optical Drive
1x OEM DVD Drives
Silverstone Strider 850W
XSPC RX360
Laing D5 + XSPC Res
XSPC EX360
Heatkiller Rev 3.0
Primochill Bloodshed Red Tubing
Koolance Fullcover R9 290x Block
Thermaltake Core x71 Tempered Glass Riing Edition
Operating System
Windows 10 Pro x64
Asus VEH228H
Asus VE228H
Aavara TS742 Dual Monitor Stand
Keyboard
Ducky Shine II Cherry Blue RED Backlit Mechanical Keyboard
Mouse
Zowie FK1
Mouse
House of Stealth
Audio
Microlab Solo6c
Other
Logitech C100 Webcam
Matt-Matt is offline
post #2 of 8 (permalink) Old 04-27-2019, 05:48 AM
professional curmudgeon
looniam's Avatar
Rep: 839 (Unique: 465)
how low in timings at "stock" 3000?
for something like tightest timings vs fastest speed.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help: Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #3 of 8 (permalink) Old 04-27-2019, 06:13 AM
deepor's Avatar
Rep: 485 (Unique: 330)
Your "config 1" has faster timings than your "config 2"!
You need to translate the numbers in the timings into real time when comparing. One clock tick at 3900MHz is faster than at 3200MHz.
To do this, divide the timing by the MHz. Then use the results to compare, instead of that "14" or that "16" you've written down.
Here's are your config 1 and 2 timings translated into something that can be compared:
16-16-17-36 @ 3900MHz:
-> 0.0041, 0.0041, 0.0044, 0.0092
14-15-15-35 @ 3200 MHz:
-> 0.0044, 0.0047, 0.0047, 0.0109
EDIT: I had made a mistake here earlier and copied the wrong set of timings from the first post.
Something else to think about that I don't know how to deal with is, the CPU will never just read a single byte from RAM. It will read a certain length of bytes. This then might make settings that have better (real) timings still end up slower than a different set of settings that has worse timings but more MHz. Reading a length of 64 bytes or something might be done faster because of the MHz despite the whole thing starting slower because of worse timings. I guess it's best to simply benchmark stuff.
deepor is offline
post #4 of 8 (permalink) Old 04-27-2019, 06:23 AM - Thread Starter
Matt-Matt's Avatar
Yeah that is something that I am going to do next, it'll probably be a few days before I get any testing done on this however.
I'll also go ahead and update my BIOS as well, it seems to be having issues with a few things.
16-18-18-38 @ 3200 MHz:
Of course, that is how timings work. But we can see that lower timings vs higher speed is more the comparison.
So you're saying if i use the formula; it will tell me which is better?
As for the memory timings; 14-15-15-35 1T tRFC 401 is tighter then 16-16-17-36 1T tRFC 401 as in the numbers are lower.
I wasn't able to get the board to post any lower then the above at 3200MHz, but my BIOS is also playing up so I will flash that tomorrow.
Eleven Fiffty Five
(24 items)
Gigabyte Z77x-D3H
Samsung 840 Evo
Optical Drive
1x OEM DVD Drives
XSPC RX360
Laing D5 + XSPC Res
XSPC EX360
Heatkiller Rev 3.0
Operating System
Windows 10 Pro x64
Asus VEH228H
Asus VE228H
Keyboard
Mouse
Zowie FK1
Mouse
House of Stealth
Audio
Microlab Solo6c
Other
post #5 of 8 (permalink) Old 04-27-2019, 07:02 AM
deepor's Avatar
You can only easily compare if it's the same MHz. If the MHz are different, you only know what's tighter after you do some calculations.
The memory timing numbers are the amount of clock ticks it takes before the RAM starts to answer a request from the CPU. If the clock runs at a different MHz, then the timings mean a different real time. So what you need to compare is not:
14 vs. 16
What you need to compare is:
14/3200 vs. 16/3900
Another way to calculate stuff is this way here:
16 / 3900 * 3200 = 13.1
That "16" timing at 3900MHz is the same real time as what a "13.1" timing would be at 3200MHz. But of course you can't set a timing like "13.1", you can only configure either "13" or "14". Using 13 at 3200MHz would be a tiny bit tighter than the 16 at 3900MHz, and using 14 at 3200MHz would be quite a bit away from the 16 at 3900MHz.
deepor is offline
post #6 of 8 (permalink) Old 04-27-2019, 07:11 AM
deepor's Avatar
@Matt-Matt :
I had made a mistake in my post earlier. I had copy+pasted the wrong timings from your first post, the results of the calculations should have looked like this:
deepor is offline
post #7 of 8 (permalink) Old 04-28-2019, 01:02 AM - Thread Starter
Matt-Matt's Avatar
Update: My board is now playing up with the RAM speeds, it will POST at 3900MHz and pass memtest, but CPU-Z is reporting that it's only at 3400MHz despite it being set to 3900MHz in the BIOS?
I updated the BIOS and set the clocks the same and getting the same behavior, are there are other programs I can test this with?
I'm still not sure if this is the board changing it back or CPU-Z being broken? Thinking its the first..
Oddly enough if I set it to 3400MHz and these same timings it works in CPU-Z?
Aida64 is also reporting the same speed.. darn
Eleven Fiffty Five
(24 items)
Gigabyte Z77x-D3H
Samsung 840 Evo
Optical Drive
1x OEM DVD Drives
XSPC RX360
Laing D5 + XSPC Res
XSPC EX360
Heatkiller Rev 3.0
Operating System
Windows 10 Pro x64
Asus VEH228H
Asus VE228H
Keyboard
Mouse
Zowie FK1
Mouse
House of Stealth
Audio
Microlab Solo6c
Other
post #8 of 8 (permalink) Old 05-05-2019, 03:50 AM
MrHarris's Avatar
Rep: 9 (Unique: 9)
Hwinfo64 ..... or memtweakit from asus...
MrHarris is offline
