PC freezes for 5 seconds almost every hour - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 05-30-2019, 07:09 AM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by diggiddi View Post
Change your sata cables and see
Yeah i should, they are pretty old.
Quote: Originally Posted by bmgjet View Post
Run DPC checker in background.
Check its log when it has a mini freeze and should let you know what driver/program was called at the time.
Ill try that, thanks.
Quote: Originally Posted by UltraMega View Post
If you still have issues, one of your HDDs is failing. I'd bet money on it.
Post screens of the health tab from HDtune for both of your HDDs.
http://www.hdtune.com/
Also Geek Squad is ********. They don't do any real repairs there, they just ship them out to real repair people. Their assessment of this issue is borderline meaningless.
Are either of your HDDs western digital Blue?
ill try hdtune thanks. *EDIT* BOTH OF MY HDDS ARE seagate ST2000DM001. My WD is not installed atm*. It is just weird it is happening now because this problem did not arise when it was in my old build. I changed the processor/mobo/heatsink/m.2/ram nvme and now im having this issue.
There were no issues like this with the 4770k/msi mobo/phantek heatsink/no m.2/ddr3 ram build from before.
ALSO, i did reinstall windows completely and i didnt have any issues for a while but then i started getting issues every 2 hours this time. gunna keep testing. thanks.
Novacore is offline
post #12 of 18 (permalink) Old 05-30-2019, 10:04 AM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
Here is some pics of my 2 HDDs on HDtune
Novacore is offline
post #13 of 18 (permalink) Old 05-30-2019, 01:38 PM
Graphics Junkie
UltraMega's Avatar
Rep: 59 (Unique: 53)
Hmm, interesting. Drives look good. Still could be one of them. Try disconnecting both drives and see if the issues still occurs.
For an issues like this, if it's not the drive it will be pretty hard to pin down, but my next guess would be the power supply.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #14 of 18 (permalink) Old 05-30-2019, 01:50 PM
mmonnin's Avatar
Rep: 292 (Unique: 137)
The timing makes me thing some software app is running every so often. Anything in event log every hour? AV Scan?
mmonnin is offline
post #15 of 18 (permalink) Old 05-30-2019, 02:15 PM
Funguseater's Avatar
Rep: 9 (Unique: 8)
Hi, have you tried looking at the Windows Event Viewer to find an error code?
Good Luck.
Funguseater is offline
post #16 of 18 (permalink) Old 06-01-2019, 06:40 AM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
Yes that is what im thinking as well BUT I am not sure what happened, but i have not received any freezes all day. I was still receiving freezes after a reinstallation of windows but a day later, the freezes APPEARED to stop. Going to see what happens from here on and will update.
Yes, my friend said something about it being a possible app, although, when i check event viewer, there is nothing that coincides with the freezes.
Good Luck.
Thanks, and yes i have. Unfortunately, there was nothing in event viewer that coincides with the freezes at all.
BUT like i said above, i miraculously have been receiving no freezes as of late and will see if that changes in the near future and will update. Thank you.
Novacore is offline
post #17 of 18 (permalink) Old 06-03-2019, 04:23 PM
Memory Overclocker
Rep: 24 (Unique: 10)
This is a long shot, but after building my newest system, I had occasional freezes until I discovered that it was being caused by one of my drives (an older SATA DVD drive). Apparently, it didn't like the particular SATA chipset/driver that was behind the SATA port it was plugged into (something to do with some older standard the old drive was using). When I unplugged the DVD drive, the freezes went away. I have since replaced the DVD drive with a new one.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
post #18 of 18 (permalink) Old 06-03-2019, 05:00 PM
Thingamajig's Avatar
Rep: 138 (Unique: 122)
Storage usually is the cause of most sluggish data transfers or odd lockups/hangups.
check drive temperatures and see if they're running within limits, most likely are but deffo worth a check. also do some error checking on them to ensure they're not on their last legs.
Umbra
(10 items)
i7 7700K
ASUS ROG Strix z270i ITX
Zotac 1070 Mini
Corsair Vengeance LPX (2x8GB) DDR4
2x 2TB Seagate Guardian Barracuda 2.5"
M.2 Western Digital Black 256GB
Optical Drive
Panasonic UJ-265 SATA Slot Blu-ray Writer
700w Silverstone SST-SX700-LPT SFX
Heatkiller v3 CPU Block
Cougar QBX Mini
Thingamajig is offline
