PC freezes for 5 seconds almost every hour - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 05-29-2019, 11:23 AM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
Hi, as the title says, I am having an issue with a PC i recently put together.
I have been getting freezes that will freeze the computer completely for about 5 seconds and unfreeze back to normal about every hour whether i am gaming or not.
On occasion, this freeze will shutdown my game application completely and bring me to the desktop. When it does this, my screen will become erratic, showing artifacts, going black with a bright white array of bars laid across horizontally in the middle of my screen from one side to the other as if there is some kind of video issue. But this only happens sometimes.
My build:
9900k at its base clock 3.6
gtx 1080ti sc black evga base clocks
ASUS Maximus hero xi wi-fi Mobo
2x16gb corsair vengeance pro rgb ram
1tb 970 m.2 nvme
1tb 960 ssd
2x2tb WD hdd
corsair H100i SE aio
Seasonic 650watt psu
3 corsair LL120 rgb fans
4x of corsair LED magnetic rgb lightstrips
i'm using 2 monitors, alienware 240hz 1080p and a secondary hp 75hz monitor 1080p if that matters.
Here is what i've tried so far:
-uninstalling and reinstalling all drivers for mobo and all other devices
-switching graphics card to different pci-e slots to check if maybe it was a faulty pci-e slot
-changing the ram placements
-since i work at best buy, i took my computer to geek squad where they ran their "MRI" software overnight to check faults for hardware and everything came back green.
I thought maybe my graphics card was the issue, so i took out my 1080ti and put in an old gtx 780 and played games on that for a while and noticed no freezing.
I also installed my old parts that were replaced with the new ones into a new computer case and put the 1080ti in that build and experienced no freezing.
My old spare parts build is:
4770k base clock
msi z87-gd65 gaming mobo
4x4gb gskill 1600mhz ddr3
corsair 750watt psu
phantek air cooler
128gb crucial ssd
This is the build i had before with the 1080ti MINUS the 750watt psu. I was using this old build with my seasonic 650watt psu as well with the 1080ti. I kept using the 650watt seasonic psu with the new 9900k build. SO the graphics card didnt have any issues with the 650watt psu in the 4770k build. When i put the old parts together after the new build, i found the corsair 750 watt laying around so i used that to just have a back up computer with my spare parts.
So like i said, the 1080ti did not have any freezes when i installed it on the spare part build. I also put the gtx 780 into my new 9900k build and experienced no freezes at all, but i did have pretty bad input lag.
I haven't tried reinstalling windows completely yet and wanted to post something about this before i did that to see what others think.
I think it is possible that my 650watt psu might be the issue but i am not so sure. Maybe the added RGB lights (and there is ALOT of rgb lights) coupled with a stronger processor, more ram, multiple hard drives/ssd, and the 1080ti, is causing the problem? But it is strange that the gtx 780 doesn't have the same problem... i believe the wattage between the 780 and 1080ti is not a HUGE difference but i may be wrong.
It really would be a pain but i could possibly interchange the PSUs and see if the 750watt on the new system changes anything, but if the problem was the psu, wouldn't it constantly have issues? Not once every hour?
Sorry for the long post but please let me know what you guys think!
Edit: I used seasonics calculator with the specs i have and it says recommended psu wattage is 564w and load wattage is 514w. but it also recommends a 750 watt psu at the same time. Ill add a snip of the calculators results.
also, im going to test the computer with all the rgb lights off to see if there are any issues persisting with them off. maybe there is just too much power draw with the added rgb with the new build.
Name:	psu results.PNG
Novacore is offline
post #2 of 18 (permalink) Old 05-29-2019, 11:41 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Which model is that Seasonic PSU?
Also did you try and test your storage drives with a program like Seagate Seatools or Hard Drive Sentinel?
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 18 (permalink) Old 05-29-2019, 11:58 AM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
I am using the prime gold 650watt. I just noticed there is a hybrid button on it and it seems to be on. Im going to turn that off and see if that changes anything.
I have not run seagate seatools or sentinel.
I have however use the MRI software from geeksquad and it does extensive checks on all hardware and it came back green, however, i can try that out as well.
Novacore is offline
post #4 of 18 (permalink) Old 05-29-2019, 12:57 PM
Senior OCN Member
shilka's Avatar
The hybrid bottom is for the fan and if you turn it off the fan will spin all the time vs on where it will spin depending on temps and load
PSU calculators by the way are rubbish and all of them will overstate numbers by at least 28% so unless the PSU is somehow broken its not the problem
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #5 of 18 (permalink) Old 05-29-2019, 03:24 PM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
thanks. So i did turn off the hybrid mode but at the same time i turned off the RGB lights and it has been 3 hours with no freeze. Not gunna celebrate yet but i will update what happens later.
Novacore is offline
post #6 of 18 (permalink) Old 05-29-2019, 04:27 PM
asuindasun's Avatar
Rep: 63 (Unique: 59)
Maybe a long shot, but do you happen to run into this when you use a file off the hdd? when I first went SSD+HDD ran into a similar issue that turned out to just be my hdd having to spin up from sleep. Double check the power settings for it.
https://www.thewindowsclub.com/preve...-sleep-windows
asuindasun is offline
post #7 of 18 (permalink) Old 05-29-2019, 08:05 PM - Thread Starter
Novacore's Avatar
Rep: 1 (Unique: 1)
It doesn't seem to be related to hdd usage because it it always in an hour interval on the dot and it can happen when while doing any task. whether im doing nothing or playing a game, still does it at the same time.
The computer seemed to be doing fine for about 5 hours this time with hybrid mode and the rgb turned off but i just got a freeze again. gunna see if the intervals are the same or not.
I may try to put in a new powersupply tomorrow.
Novacore is offline
post #8 of 18 (permalink) Old 05-29-2019, 10:01 PM
Graphics Junkie
UltraMega's Avatar
Rep: 57 (Unique: 52)
If you still have issues, one of your HDDs is failing. I'd bet money on it.
Post screens of the health tab from HDtune for both of your HDDs.
http://www.hdtune.com/
Also Geek Squad is ********. They don't do any real repairs there, they just ship them out to real repair people. Their assessment of this issue is borderline meaningless.
Are either of your HDDs western digital Blue?
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #9 of 18 (permalink) Old 05-29-2019, 10:45 PM
diggiddi's Avatar
Rep: 108 (Unique: 87)
Change your sata cables and see
But can it run.... Angry Birds???
About the NVidia GTX 970
"When comes down to it, it's really a $250 card with lies printed all over the box."--Rexer
diggiddi is offline
post #10 of 18 (permalink) Old 05-29-2019, 11:01 PM
High Clocker
bmgjet's Avatar
Rep: 192 (Unique: 166)
Run DPC checker in background.
Check its log when it has a mini freeze and should let you know what driver/program was called at the time.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
