defect 9900k or mobo? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 06-10-2019, 04:29 AM - Thread Starter
Rep: 0
Not sure if this is the right place but anyway
I just made a build for my friend which is:
9900K
asus strix z390-i
g.skill trident z royal gold 16gb 3200mhz cl14
corsair sf750
nzxt kraken x52
samsung 970 evo 1tb
bios: 2411 (newest) - tried 2401 too..
My problem started with it crashing when doing stress testing with prime95 & intel burn test for just 5-15 mins and that was with standard bios settings..
Anyway thought well its just bad settings in the bios so i manually set the common stuff like voltage and all that and yeah 24 hrs later i havent gotten anywhere... feel like i tried everything that is possible which is trying pretty much all the guides on forums and youtube and trying from 4.2ghz to 4.9 (all cores) and dif avx offsets and even going up to 1.375v on core and all kinds of power settings and nothing works it just crashes no matter what.
So i went and tried dif ram and powersupply which changed nothing either, so now im at a point where i feels like the cpu or motherboard has to be defect because normally it work with standard bios settings but this just wont work no matter what stuff i change on it.
The temperature is around 60-70c so its not the temperature that makes it crash and vrm on motherboard is at the 80c-85c.
I prob didnt write everything i did because i literally did a million things so if anyone got an idea what might get this damn build working please be so kind.
The way it crashes is that the screen just freeze and then the pc turns off totally and starts again.
When doing prime95 large test it crashes sometimes after 45 mins..
sirtoby1337 is offline
post #2 of 6 (permalink) Old 06-17-2019, 08:00 PM
ntuason's Avatar
Rep: 175 (Unique: 155)
What GPU? Seems similar to my PSU problem where it couldn't push enough voltages and just shut off.
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz 1.39v (Direct-Die)
ASUS ROG Maximus XI Apex
ASUS ROG RTX 2080 Ti O11G
Trident Z Royal @ 4200MHz CL18
970 EVO Plus NVMe M.2 500GB
860 QVO 1TB
BarraCuda 8TB
Cooler Master MasterWatt Maker 1200
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic (White)
Operating System
Windows 10 19H2-1909 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #3 of 6 (permalink) Old 06-17-2019, 08:10 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
Take out your CMOS battery and reset the bios (may want to manually set your RAM or turn on XMP only so they are running at their rated specs/volts) before doing more tests at stock (overclock later once the problem is solved).
Seems to me that your CPU (and they run hot) is getting really hot with Prime95 and it will shut down the computer (60-70c on idle or load and while using Prime95 which is hard to fathom). You should use other stability tests.
Additionally, is your thermal paste application correct? Heatsink may also not be seated properly.
How is the airflow in the case?
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #4 of 6 (permalink) Old 06-17-2019, 09:59 PM
Overclocker
JackCY's Avatar
Rep: 363 (Unique: 260)
Corsair replaced SF450 with SF750, interesting.
Does it run stock with no OC and RAM at JEDEC?
If not then start figuring out which component is faulty and return/replace it.
Always try minimal system configuration.
If it only crashes during OC, any OC above stock... well either bad lottery luck or some setting needs changing and there may be more than before on the latest Intel platforms, or the VRM is cooking.
These problems are impossible to figure out over text.
JackCY is offline
post #5 of 6 (permalink) Old 06-18-2019, 12:21 AM
RIP OCN
Rep: 28 (Unique: 21)
Prime95 and IBT at the same time? Or either one causes a crash after 5-15 mins?
As JackCY said, you never explicitly mentioned if you tried running everything stock, although it sounds like you may have based on wording...
anti-clockwize is offline
post #6 of 6 (permalink) Old 06-18-2019, 06:54 AM
Rep: 0
What kind of monitoring tools you are using?
try HW Monitor https://www.cpuid.com/softwares/hwmonitor.html
take screenshots to share.
Asgarith
(12 items)
Dark Visionare
Intel i9 9900k
AsRock Taichi Ultimate
Asus 1070 Windforce 8GB
Corsair Vengeance LPX DDR4 3200 C16 2x16GB
Corsair Force NVMe PCIe M.2 960GB
Seasonic PRIME 750 Gold SSR-750GD2 750W 80+ Gold
Noctua NH-U14S
Cooler Master Haf Xb Evo
View Sonic 27 1440p
Keyboard
Logitech Orion
Mouse
Logitech G510
Audio
Audient
i5-2500k
ASRock Z68 EXTREME4 GEN3
Visiontel 9750
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRA
Crucial M500 256 / 1tb Samsung Spinpoint F3
Optical Drive
Samsung something
COOLER MASTER GX Series RS650-
HAF 922
Operating System
7 64
24'' Dell u2412m / 24'' Samsung t24hd
Keyboard
Das Keyboard
Mouse
Razer Imperator, Logithech g500 and TrackMan Marble Mouse
Audio
Roland V-Studio 100 / SB Audigy
Asgaroth is offline
