ASUS ROG Rampage VI Extreme Omega + i9-9980XE Overclock help - Page 3 - Overclock.net - An Overclocking Community
post #21 of 34 (permalink) Old 06-19-2019, 12:43 AM - Thread Starter
hamood10's Avatar
Rep: 0
Quote: Originally Posted by CptSpig View Post
What is the point of having a (X299) HEDT machine if you are not going to OC the system?
Running a stability test out side of the operating system is pointless ie: memory. As far as memory I would look at G.Skill Trident Z it will be easier to get stable. I would also recommend staying away form the RGB stuff it does not overclock as well. I would recommend a mild OC on the CPU it will perform better than auto. If you need help overclocking your system we can help. Good luck!
That why I came here, I need to overclock the RAM and CPU, im using this system for High-End gaming + Video editing and rendering
hamood10 is offline
post #22 of 34 (permalink) Old 06-19-2019, 05:15 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Can you post an image of the build ?
Basic cpu oc is 4.5 at 1.2v you might be able to use 1.18v using adaptive core voltage
99..x series chips seem to have pretty tight vid reading so no need to per core adjustments so one can use All core oc'ing and only set core voltage to apply to all of them at once
Here's Jp's 4.6 bios screen shots he shared this was on a 7980xe I doubt you have to use the cache voltages omega and 99..x in general has way better cache than 79..x series voltage wise just set to max cache 30 and auto voltage.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #23 of 34 (permalink) Old 06-19-2019, 09:54 AM
Maximum OCN
CptSpig's Avatar
Rep: 79 (Unique: 47)
Attached are my 4.4 All Cores OC and 4.6 Per Core OC. The memory OC is for G.Skill TridentZ 3600 CL16 32 GB. These files are for a 7980Xe on a ASUS Rampage VI Apex. Should be a good starting point. Cooling will be a factor I am on water with a very good rad. I use the per core for CAD, Gaming and pretty much everything.
X299 RIG
(19 items)
X99 RIG
(17 items)
i9-7980XE
ASUS ROG RAMPAGE VI APEX LGA2066 DDR4 M.2 X299 EATX Motherboard
2080ti Founders Edition with 380w Bios
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Model F4-3600C16Q-32GTZKK
Samsung SSD 960 EVO NVMe M.2 500GB
Samsung SSD 850 Pro 2.5" SATAIII 512 GB
Corsair AX1500i Digital ATX Power Supply
EXC-800 Portable 800W Recirculating Liquid Chiller
Phobya G-Changer Xtreme NOVA 1080 radiator 60mm - Full Copper
CPU-390I Water Block, Nickel Top
(1)-EK-XRES 140 and (2)-DDC 3.2 PWM Elite
Bitspower Lotan
PrimoChill Praxis Wet bench
Operating System
Windows 10 Pro 64 bit
Dell Aleinware AW3418DW
Keyboard
Corsair Gaming K70 RGB Mechanical Gaming Keyboard — Cherry MX Red
Mouse
M65 PRO RGB FPS Gaming Mouse — Black
Mouse
SteelSeries QcK XXL
Audio
Corsair Vengeance 2100 wireless
i7-6950X Processor
MSI X99A GODLIKE GAMING CARBON
Nvidia TITAN X Pascal
Corsair Dominator Platinum Series 32GB (4 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit
Samsung SSD 850 PRO 2.5" SATA III 512GB
EVGA SuperNOVA 1000 G2 Power Supply
EK-XLC Predator 360 (incl. QDC) with DDC3.2 PWM pump upgrade with EK-DDC Heatsink Housing - Black
EKWB EK-FC Titan X Pascal - Acetal+Nickel
Koolance EXC-800 Portable 800W Recirculating Liquid Chiller
Operating System
ASUS ROG Swift PG279Q Gaming Monitor - 27" 2K WQHD (2560 x 1440) IPS, overclockable 165Hz, G-SYNC
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
CptSpig is offline
post #24 of 34 (permalink) Old 06-19-2019, 10:01 AM
ThrashZone's Avatar
Hi,
As i said per core oc'ing isn't necessary on 99..x series vid's and core temps are super tight together thanks to solder
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #25 of 34 (permalink) Old 06-19-2019, 10:06 AM
Maximum OCN
CptSpig's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Cooling is not the issue? I use per core because it works the best for gaming. I like to game!
X299 RIG
(19 items)
X99 RIG
(17 items)
i9-7980XE
Bitspower Lotan
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
i7-6950X Processor
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
CptSpig is offline
post #26 of 34 (permalink) Old 06-19-2019, 10:22 AM
ThrashZone's Avatar
Hi,
Cooling is still needed
Just per core adjustment to tame bad cores is not really needed unless someone wants to max some of the best cores in my case
4.8 all core
I could push probably half of them to 4.9 and still be close to the same core temps.
So I guess the solder tightened the cores a lot better than LM ever can/could.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #27 of 34 (permalink) Old 06-19-2019, 11:41 AM
ThrashZone's Avatar
Hi,
Here's a 4.6 all core little toasty but there is some room for 4.9 on at least 6 out of 14
https://www.overclock.net/forum/atta...8&d=1555541685
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #28 of 34 (permalink) Old 06-19-2019, 01:49 PM
eatthermalpaste's Avatar
Rep: 1 (Unique: 1)
To the OP - have you been able to get XMP to work on this board yet?
I'm working on a Rampage VI Extreme Omega as well and there's a few weird things going on. Never had this problem before on any other asus board, asrock, gigabyte, etc. It's like it just refuses to do anything with memory.
1. Pretty sure there's somethign wrong with CPU OC. I'm testing AVX2 with an H150i pro on 9980XE. I know it shouldn't do That well but anything over 3.8GHz is impossible. This is without memory OC.
2. Has to be something wrong with memory OC. I've tried tweaking memory voltage, system agent, vccio, vtt, and lowering ram frequency from 3200 down to 2666 (with xmp on), and loosening timings. Nothing works, cores crash instantly on p95. With memory at auto and my CPU "oc" its fine, can pass overnight - but once anything with memory is set up it can't do it.
Tried CPU swap, tried memory kit swap.
This is with a 128GB kit 3200c14.
oh and edit - on latest 0602 BIOS
Ratchet Snow White
i9-9900K
ASRock Z390 Taichi
Gigabyte GeForce RTX 2080 Gaming OC White 8G
F4-4133C19Q-32GTZSWF
Samsung 970 EVO m.2 500GB
Corsair RM850X
Corsair H100i Platinum RGB SE 240mm
CORSAIR Crystal 570X RGB Mid-Tower Case
ASUS PG348Q
Keyboard
Razer Black Widow
Mouse
Logitech G903
Mousepad
Logitech G Powerplay Wireless Charging System
Audio
SteelSeries Arctic Pro w/GameDAC
eatthermalpaste is offline
post #29 of 34 (permalink) Old 06-23-2019, 03:07 AM - Thread Starter
hamood10's Avatar
Rep: 0
This is whats happening to me, I 100% sure there is bios issue in the board, overclock CPU without touching RAM works fine, but when I start OC the RAM weird things happening, crash blue screen even black screen, currently I OC the CPU to 4.2 no issues and stable, once I just OC ram its unstable, currently bought new RAM to further test, its compatible with x299
G.Skill F4-3200C14Q-64GTZR
https://www.gskill.com/en/product/f4-3200c14q-64gtzr
hamood10 is offline
post #30 of 34 (permalink) Old 06-23-2019, 08:26 AM
Maximum OCN
CptSpig's Avatar
Hi,
The attachment you posted is a per core OC from JP. ?
X299 RIG
(19 items)
X99 RIG
(17 items)
i9-7980XE
Bitspower Lotan
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
i7-6950X Processor
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
CptSpig is offline
