i9 9900k IHS material? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 06-15-2019, 06:45 PM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
Quote: Originally Posted by Blameless View Post
Nickel-plated copper with an additional gold layer on the underside to improve solder wettability.
There is no aluminum in the IHS.
Pretty much, but since it's soldered one risks damage to die and not much gain in thermals let alone performance. So... why bother with LM when it's soldered.
Some units are easy to delid some not, even when not soldered. Some snap open some you have to go back and forth in direction to work the material loose.
JackCY is offline
post #12 of 16 (permalink) Old 06-15-2019, 08:26 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 179 (Unique: 93)
This is what confused me, the 9900K comes already soldered onto the IHS (best decision yet from that Company), still we have some here who think that delidding it will make it vastly more superior with heat transfer.
This on going disease has carried over from all those years of Trash Intel paste-gump, that they continue to delid their current 9900K's under that illusion of getting superior heat performance transfer.
Hope everyone considers the facts before undertaking such an insane delusion, you know you won't get any of your money back from any retailer, when they discover your damaged folly.
Wasting your money on a continuing basis to help maintain the Capitalist System to turn over, then whom am I to stop anyone from contributing, ..... please carry on......
Elrick is offline
post #13 of 16 (permalink) Old 06-15-2019, 08:47 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1449 (Unique: 731)
Technically if you OC your warranty is already void so who cares
Deliding and putting liquid metal or going direct die still gets you (arguably) worthwhile temp gains on top of better temp consistently across all cores. It's not an illusion or maintaining the capitalist syetem
https://www.tomshardware.com/reviews...n2,5618-4.html
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #14 of 16 (permalink) Old 06-15-2019, 09:18 PM
Elrick's Avatar
Looks like Intel still fails, with even soldered on IHS designs .
Now I understand those using Intel gear - delid EVERYTHING that comes from that company .
Elrick is offline
post #15 of 16 (permalink) Old 06-25-2019, 06:43 PM
postem's Avatar
Rep: 17 (Unique: 12)
Quote: Originally Posted by Falkentyne View Post
I use liquid metal between IHS and heatsink on my NH-D15.
Every C reduction helps. But I did take extra precautions to protect against LM spillover:
1) Super 33+ tape around the socket, going from the edge of the IHS covering the retention mechanism.
2) Polyurethane foam dam (air conditioner foam) cutout in the shape of the IHS, with a few mm to spare, for extra protection and to help against oxidation.
Just a question: what temps do you get with Noctua D15 on 9900K? Im using same cooler on 8700K, dellied its rocking as low as 65C on 20-30C room temps.
I was considering going on a 9900K, around 4.8-4.9 ghz.
Did you tested it too (temps) without delliding?
postem is offline
post #16 of 16 (permalink) Old 06-25-2019, 07:27 PM
Facepalm
Falkentyne's Avatar
Rep: 463 (Unique: 321)
I don't remember. Totally depends on the test conditions and ambients and its summer time now too. Doesn't help.
If ambients are in control i get around 78C temps at x47/x44 speeds at 1.230v with LLC High (LLC5) with 15K Prime95 fixed FFT FMA3.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
