Clear CMOS jumpers - Overclock.net - An Overclocking Community
Clear CMOS jumpers
post #1 of 5 (permalink) Old 09-12-2019, 05:41 PM - Thread Starter
fra z's Avatar
Rep: 4 (Unique: 4)
Clear CMOS jumpers
Hello,
Bought a 2nd hand motherboard that arrived without the clear CMOS jumper - (I did borrow one of another board)__but that's not the point !
Where can these be purchases from? - I've looked on Ebay and bought the wrong item (too small)__someone will have them on Ebay (probably)__buy it's finding them and the correct ones as well.
Is there a specific company that makes these? - Any info and accurate information please - Thanks
fra z is offline
post #2 of 5 (permalink) Old 09-12-2019, 06:29 PM
Missing the Old days
Cerberus's Avatar
https://www.amazon.com/StarTech-2-54.../dp/B00008VF46
or
https://www.digikey.com/product-deta...337-ND/2618262
2.54mm pitch
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Do you FOLD? Maximize PPD by using a PASSKEY!!!
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #3 of 5 (permalink) Old 09-12-2019, 07:04 PM - Thread Starter
fra z's Avatar
Rep: 4 (Unique: 4)
Hello Cerberus,
Thanks for the link - 2.54 mm seems to be the standard - What I ordered was clearly smaller and would not fit onto the motherboard.
In the description of one of the items for sale was a condition mentioning actual cosmetic appearance may vary from photograph - Yeah right !!!! - Not
I've ordered from someone else but only a small pack of 5 from Ebay so I'll see if these are correct.
On my own boards I've not lost one jumper off the motherboard as these are a tight fit and are not removed ever so it was annoying to find that a used board arrived without one - and it wouldn't boot up and it was only on checking the CMOS header pins that I found there was no jumper -----
Anyhow I'll let you know when the other ones arrive ---
fra z is offline
post #4 of 5 (permalink) Old 09-12-2019, 07:22 PM
Cerberus's Avatar
good practice on loose connections, especially with open pins like these, small blade screwdriver to "open" the gap up to make it tighter.
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
Corsair RM750X
big metal box
Operating System
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Corsair 650w
Cerberus is offline
post #5 of 5 (permalink) Old 09-16-2019, 07:12 PM - Thread Starter
fra z's Avatar
Rep: 4 (Unique: 4)
>>> Yes you are quite correct - The wrong ones ordered were 2 mm - whilst the new ones are 2.54 mm - It works and is tested so I'll add a few more just in case
fra z is offline
