8700k or a 9700k for thermals - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 11-07-2019, 03:06 AM - Thread Starter
mardon's Avatar
Rep: 44 (Unique: 40)
Hi probably the been asked 100 times on here but hopefully this is a slightly different twist on the question.
I am currently gathering the parts to upgrade my mini-ITX (Silverstone RVZ01) with the following:
New Parts:
Z370I Gaming Pro Carbon Mini-ATX (£100)
8700K (Pre delidded with Conductonaut) (£240)
Corsair LPX 3200Mhz 16GB (£60)
2070 Super
Existing
500W Silverstone SFX 500
Corsair H55 with an external 120mm and an internal 120mm low profile internal.
I'm trying to make this a value build and i've got it in my head i'd really like to have a 5ghz 24-7 overclock (silicone lottery) permitting. I'd be happy to step down to 4.9ghz etc if the jump in volts isn't worth the gain.
I've obviously got a a real thermal wall here with the size of my case and the cooling available. I'm open to new cooling but it has to fit within the case.
A second hand 9700k has just come up locally and will cost around £30 more then what I paid for the 8700k. Should I make the change for thermal reasons over performance? (I will sell on the 8700k).
I've also got one eye on the new consoles. Whats going to be better long term? 6 cores 12 threads or 8 cores 8 threads? Bearing in mind my last build 3770k lasted me 4/5 years i'd like this to be the same (on the CPU).
Any help, thoughts and comments much appreciated.
mardon is offline
post #2 of 22 (permalink) Old 11-07-2019, 08:11 AM
wingman99's Avatar
Rep: 63 (Unique: 46)
The i7 8700k will run cooler for about the same performance as the i7 9700k.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #3 of 22 (permalink) Old 11-08-2019, 06:26 PM
D-EJ915's Avatar
Rep: 5 (Unique: 5)
It is already delidded with liquid metal I would just stick with that personally, it'd be a side-grade at best.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #4 of 22 (permalink) Old 11-10-2019, 01:34 AM - Thread Starter
mardon's Avatar
Well got all the bits together.
Seems the 8700k does need some voltage to hit 5ghz. I'm at 1.345v at the moment. Think I'm close to getting stable. It passes benchmarks, cinebench, firesrike and normal Intel burn test. Fell over after 6 passes on very high.
I'm wondering if rolling the Dice on the 9700k (buyer happy to accept £280) is worth the gamble?
Do 9700k's hit 5ghz with less voltage on average?
Sent from my SM-N9600 using Tapatalk
mardon is offline
post #5 of 22 (permalink) Old 11-10-2019, 11:03 AM
wingman99's Avatar
The 9700k's need increased core voltage compared the i7 8700k's for 5.0GHz.
My i7 9700k
Prime95 AVX disabled.
Overclocking 4.9GHz LLC AUTO, DVID -0.170 = 1.320v core voltage
Noctua U14S Max temperature 96c ambient 71F,
CPU Package 176 watts
My i5 8600k
Overclocking 5.0GHz LLC AUTO, DVID +0.120 = 1.296v core voltage
Noctua U14S Max temperature 87c ambient 73F
CPU Package 122.67 watts
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #6 of 22 (permalink) Old 11-10-2019, 05:12 PM
Свет
XLifted's Avatar
Rep: 37 (Unique: 36)
Untrue. I owned both. 9700k will run cooler. 9700k is soldered. 8700k will hit the thermal ceiling with same cooling almost instant when running Aida64
Delidding 8700k may or may not be about the same. Depends on your voltage and overclocks.
I had better thermals with 9700k with overclock (same voltage). BUT...I had a golden 8700k that overclocked at lower temps, with lower voltage of about 1.26v to 5.0 ghz
If you want better thermals with no delidding/liquid metal, then go for 9700k
It will require higher voltage, but it will beat 8700k in a lot of gaming stuff, because of true 8 cores. It will perform slightly less in rendering tasks though, because of no hyperthreading
9700k is about 19% less powerful than 9900k in per core performance, 8700k about 24% weaker than 9900k.
I had 8700k, 9700k and now own 9900k.
9900k is a definite winner, 9700k is close enough second. 8700k feels like chip from another family. Hard to explain, but I would only go for 9900k because I saw limitation in both 8700k and 9700k.
9700k is more solid, but it doesn't have hyperthreading. Thus lacking rendering power of 8700k and 9900k. BUT...I would not buy 8700k, because I saw R6 Siege utilization almost 100% of that cpu at times.
100% utilization causes stutter. No stutters with 9900k. 9700k gives more headroom than 8700k for gaming, but it's right on the edge for modern gaming. 6 cores seem to be not enough for many games (for flawless gaming experience) even if you have a great GPU. As soon as CPU hits 100% you will see micro stutter.
XLifted is offline
post #7 of 22 (permalink) Old 11-10-2019, 05:19 PM
The last VRM burner
Rep: 33 (Unique: 18)
My i7 9700k
My i5 8600k
Mah dud. i5 is not i7.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #8 of 22 (permalink) Old 11-10-2019, 05:38 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1159 (Unique: 661)
ignoring that the 8600K wasn't even an option, if your 9700K needs 1.32v for 4.9 you got a crap chip. that's 5.1 voltage territory, and there's no reason to expect a golden 8700K and a terrible 9700K.
OP: I wouldn't consider buying an 8700K or a 9700K this late into 2019. the 3700/3800X are smarter buys than both and the 3900X is a better buy than the 9900K.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #9 of 22 (permalink) Old 11-10-2019, 07:48 PM
wingman99's Avatar
First you say the 9700k will run cooler, then you say the 8700k ran at lower temps with lower voltage.
Also i7 8700k 6 core is not a 8 core i7 9700k either apples to apples if you want to be specific.
I purchased the i7 9700k from silicon lottery rated 1.35v for 5.0GHz, the i7 9700k was rated at a higher core voltage than the i9 9900k at 1.30v for 5.0GHz. I sent it back to silicon lottery and got all my money back. Intel's i7 9700k's are i9 9900's that don't make the higher binning for 5.0GHz.
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #10 of 22 (permalink) Old 11-10-2019, 07:51 PM
The last VRM burner
Because you apparently do not see the difference - https://www.purepc.pl/procesory/test...niuf?page=0,51
PC for all
(21 items)
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
