Best Coolers for X58 LGA1366 ? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 06-27-2020, 06:53 AM - Thread Starter
Rep: 0
https://valid.x86.fr/vkqg6u
Hi, after trying to overclock my i7 960 X58 system years ago with no luck I decided to have another go, being furloughed off work gave me some free time, I finally got to the bottom of the failure that crashed my system every time I tried to crank things up a bit. Turned out to be a faulty PSU. I am now at 4.236Ghz but I am seeing some alarming CPU temps when running 3DMark. What is the best aircooler available for the LGA1366, or at this level do I really need to go water cooled. Temp peaked at 95c. while running 3DMark at 1080p
I have modded my old case and mounted the new PSU externally on top and added 2 extra case fans where the PSU used to be, currently running a basic coolermaster TX3
What coolers are you guys running ?
GT390 is offline
post #2 of 12 (permalink) Old 07-02-2020, 06:01 PM
Rep: 0
https://avatars.mds.yandex.net/get-m...959149006/orig
Thermalright Silver Arrow
Fobia2000 is offline
post #3 of 12 (permalink) Old 07-02-2020, 07:18 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
My X58 960 ran on watercooling 6-7 years at 4.2Ghz, never on air. Finding a powerful modern air cooler to fit 1366 is what you need to find first.
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #4 of 12 (permalink) Old 07-03-2020, 02:41 PM
D-EJ915's Avatar
Rep: 15 (Unique: 14)
Thermalright ones generally fit.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #5 of 12 (permalink) Old 07-03-2020, 04:27 PM
Fix it till its broke
Owterspace's Avatar
Rep: 9 (Unique: 5)
I have Le Grand Macho RT and True Spirit 140 Power and both are excellent on 1366
3770K @ 4700MHz 1.35v/Thermalright True Spirit 140 Power TY-143 Push/Pull
ASRock Z77 OC Formula|8GB G.Skill Mix @ 1100MHz 9-11-9-28-2T 1.68v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S 256 Striped
CM Silent Pro M2 850|Fractal Define R4/5x 120x38 1x 92x38|ZM-MFC2
Owterspace is offline
post #6 of 12 (permalink) Old 07-06-2020, 03:34 AM - Thread Starter
Rep: 0
Thanks for the replies guys, I started thinking water was going to be my best option but I saw a cheap used Sythe Ninja 3 and decided to give it a go.
My full load CPU temp has dropped by 20c !!! from 95c to 75c.. I cant quite believe how much difference it has made, wondering now if there was something wrong with the old coolermaster TX3 or is the Ninja 3 just so much better
GT390 is offline
post #7 of 12 (permalink) Old 07-06-2020, 03:41 AM - Thread Starter
Rep: 0
Quote: Originally Posted by Fobia2000 View Post
Hi Fobia2000....
Interested to see you are running a X5680, I picked one up a few weeks ago to see if it would work in my setup, Asus P6T Deluxe ver.1
It gets into bios ok and recognizes the 5680 but it wont boot into windows and just hangs with a black screen, any ideas ?
GT390 is offline
post #8 of 12 (permalink) Old 07-06-2020, 04:31 AM
FOCAL ARIA FTW
Wishmaker's Avatar
Rep: 362 (Unique: 282)
Before I swapped to the Xeon chip, I ran a 920 C0 at 3.8 - 4.2 GHz with 4.4 suicide runs in benching by using a push pull Zalman ZF3 on a Venomous X.
The Xeon is cooled by the same VX and it runs 24/7 4.2 GHz at 1.42V or something.
FLOOR STANDING SYSTEM: FOCAL ARIA 948 WITH NAD C388 & NAD C568 & REGA PLANAR 3 / HOME CINEMA : YAMAHA AVENTAGE RX-A860
DESKTOP AUDIO: DENON AHD-2000/5000 -MARK LAWTON & DENON AHD-9200 WITH PIZZA STACK / TOPPING A50 HiFi BALANCED HEADPHONE AMP & D50S HI-RES DAC & P50 REGULATED LINEAR PSU
Wishmaker is offline
post #9 of 12 (permalink) Old 07-06-2020, 05:34 AM
Rep: 0
Hello ! I have two coolers "Cooler Master V8" and "Thermalright Silver Arrow" between them, too 20-25 degrees difference.
"V8" even the installation of high-speed 140mm. fan does not help with overclock 4.4ghz.
"Silver Arrow" 4.4ghz+ easy . The only negative, it's big. To install it in my Midi-Tower, you need to disassemble everything.
post #10 of 12 (permalink) Old 07-06-2020, 08:31 AM
Rep: 0
Hi Fobia2000....
Update bios to the latest version.
https://www.asus.com/Motherboards/P6...HelpDesk_BIOS/
If the download freezes before the splash screen of the operating system, possibly with a flashing cursor "_", the problem may be in the disk drive.
Is there no problem with another CPU?
