-=LGA775 Club=- - Page 194 - Overclock.net - An Overclocking Community
-=LGA775 Club=-
post #1931 of 1942 (permalink) Old 07-18-2019, 09:05 AM
Rep: 0
Quote: Originally Posted by schuck6566 View Post
looks nice!
Cheers mate.
Had a longer post, but the time out monster ate it.
It's the mobo from my old main computer which back then sported an E6450, 4x1GB RAM and a 8800GTS 320MB.
After watching some Youtube, I brought it back up from the basement.
Upgraded to an X5460 after I found a modded BIOS online, 4x2GB sticks and a 780Ti GHz Edition on used deals, and then I might've gone a bit overboard.
New PSU, AIO, case, SSD, fans, cable extensions...
Tho it's a pretty sweet machine. It runs perfectly at 4GHz. I've had it working really well at 4.2GHz. CPU temps are fine, but the mobo components starts to ramp up in temp, so I keep it at "only" 4GHz.
I'd say a 780Ti (or 970) is about the limit to what is reasonable to pair it with. I've played a lot of Ghost Recon: Wildlands and Rise/Shadow of the Tomb Raider on it, and it's actually a pretty decent experience after tweaking the correct settings. Compared to a GTX680, they run soooo much smoother with the 780Ti.
At peak enthusiasm, I also picked up a used kit with a QX9650 with a decent Thermaltake aircooler, a P5E-Deluxe, BIOS modded to Rampage Formula and 8GB RAM. It's been collecting dust for a while, but now it's up with some spare parts, in a shiny new NZXT H500.
It's currently running at 4.15GHz, 10x415, 1.425V, which seems to be the most I can squeeze out of the CPU, so I'm working on memory timings now. I'm hitting 450 in CB R15 with it.
Sadly I only have the 8800GTS for now, but to my surprise it can run Tomb Raider 2013 and Outlast (from late 2013) really well at 720p. Hopefully I can pick up a used RX570 or similar for it
I'll report back on it, and kick some life into this thread again
The Glashare is offline
post #1932 of 1942 (permalink) Old 07-18-2019, 10:46 PM
Are you sure about that?
TwilightRavens's Avatar
Rep: 18 (Unique: 11)
Quote: Originally Posted by The Glashare View Post
Here's my Abit IP35-E rig. X5460 @4GHz
Working on a QX9650 at the moment, currently at 4.15GHz.
Mine takes way too much voltage for anything above 4GHz, probably going to get an X5470 in the next week for the quest of 4.5GHz.
"If I bought an RTX 2080 ti, I couldn't even afford to think or breathe, let alone pay bills."
"If you haven't killed a motherboard lately, you're not pushing it hard enough."
Ye Olde Faithful
(14 items)
Intel® Xeon™ X5470 (LGA 771) 4.43GHz (1.43v) 466 x 9.5
EVGA nForce 790i SLI Ultra (132-CK-NF79)
EVGA GTX 1080 Superclocked
G.Skill RipjawsX DDR3 2 x 4GB (8GB) 1866MHz (9-10-10-27 CR1) 1.65v
Kingston A400 2.5" SATA III SSD 120GB
Crucial MX100 SSD 960GB
EVGA Supernova Platinum 750W PQ
Cooler Master MasterLiquid Lite ML240L RGB
Fractal Design Focus G
Operating System
Windows 10 Pro Build 1903 (x64)
Keyboard
Logitech G213 Prodigy RGB
Mouse
Logitec M510 Wireless Mouse
Other
Noctua NF-F12 PWM
Other
Noctua NF-F12 PWM
TwilightRavens is offline
post #1933 of 1942 (permalink) Old 07-19-2019, 01:08 AM
Rep: 0
I hope you get a good one I wouldn't hold my breath for 4.5GHz with conventional cooling, but who knows?
With a better motherboard than the IP35-E I guess I could try to push the X5460 beyond 4.2. I'd love to find an IP35-Pro, but they seem pretty rare in Sweden.
post #1934 of 1942 (permalink) Old 07-19-2019, 11:15 AM
I’m on water cooling, so temps and voltage isn’t too much of an issue, once I get a northbridge fan for the 790i fsb clocks shouldn’t be too hard to get.
Ye Olde Faithful
(14 items)
Operating System
Keyboard
Mouse
Other
Noctua NF-F12 PWM
Other
Noctua NF-F12 PWM
post #1935 of 1942 (permalink) Old 07-20-2019, 04:16 AM
Rep: 0
Nice! A couple of good exhaust fans make decent difference too, in my experience.
Got the QX6950 up to 4.2GHz with 1.44+ Volts. Seems stable, and doesn't produce too much hot air. Tho it's clear the voltage will have to increase pretty dramatically if I want to go further now. Tried to tune the RAM timings aswell, but anything below 5-5-5-15 and it wont even boot.
Still pretty nice. I haven't seen too many people reaching 4.2GHz (not that I've dug around much)
Waiting for a plain white led strip, then I'll get some photos of this beast
post #1936 of 1942 (permalink) Old 07-20-2019, 10:27 AM
I managed to get my RAM up to 1800MHz (9-10-9-27) but DDR3 not DDR2 and the northbridge just burns up so I have to settle on 1600 (9-9-9-24)
Ye Olde Faithful
(14 items)
Operating System
Keyboard
Mouse
Other
Noctua NF-F12 PWM
Other
Noctua NF-F12 PWM
post #1937 of 1942 (permalink) Old 07-26-2019, 12:10 AM
Rep: 0
I put a 1060 6GB in with the QX6950 yesterday, and tried some Ghost Recon: Wildlands.
Instinct says to go with 1080p, but then the GPU is totally bottlenecked by the CPU, so I went 1440p.
It actually plays really well without really compromising on the settings. Sure, low shadows, and low Level of Detail as they seem to be the most taxing for the CPU, but other than that it's Ultra textures, TAA, 16x AF, SBAO and all that. Looks great.
Framerates keep between 30 and 45 (same as at 1080p), CPU is pretty much pinned at 100%, but it's still smooth and very playable. There's an occational stutter when driving or flying, but that happens on my main rig aswell (8700k, 1070ti). It does get hot tho. Might prove handy come winter..
No surprises here really as this is pretty much the same story as with the X5460/780Ti.
post #1938 of 1942 (permalink) Old 07-26-2019, 06:53 AM
I thought about getting a GTX 1060 6GB for the system, I had a 1070 in it for a while before I ended up just giving it to the wife seeing as it would just pair better with her 2600X than with a QX9650, I keep swapping back and forth between her previous R9 380 and my old 290X that was in my Z97 rig before I jumped to the GTX 1080. I want to keep the 290X in there but the VRM’s just get so hot, so I can’t really do anything until I figure out some way to cool it a bit better.
You also might want to consider getting a 790i board, they are a bit pricey but it’s a really good investment especially if you want to clock high and have high RAM clocks, downside would be you’d need to throw some DDR3 in there but if you wanted to stay DDR2 I think the 780i is DDR2 and pretty much the same board. DDR3 only pulls ever so slightly ahead when running a high fsb, other than that the performance is roughly the same +/- a few %.
Ye Olde Faithful
(14 items)
Operating System
Keyboard
Mouse
Other
Noctua NF-F12 PWM
Other
Noctua NF-F12 PWM
post #1939 of 1942 (permalink) Old 08-12-2019, 08:44 PM
Upgraded the QX9650 to a Xeon X5470 and its running a lot better than the QX9650 ever did, also threw the GTX 1080 in there for fun and its going pretty well so far, waiting on my new 750W psu to come in the mail tomorrow so I can shoot for a higher overclock, but 4.1GHz so far seems like its running strong.
Edit: got it running 4.35GHz stable with one jump in voltage.
Ye Olde Faithful
(14 items)
Operating System
Keyboard
Mouse
Other
Noctua NF-F12 PWM
Other
Noctua NF-F12 PWM
post #1940 of 1942 (permalink) Old 08-13-2019, 04:45 PM
Zostacular
zoson's Avatar
Rep: 102 (Unique: 85)
Q9650 was awesome! I didn't even have a QX and clocked 9x500 for 4.5GHz
Zostacular 2.0
(23 items)
i7 6950x
ASUS Rampage V Extreme
NVIDIA RTX 2080 FE
NVIDIA RTX 2080 FE
G.Skill Ripjaws V DDR4 3000MHz
Samsung 960 EVO
HGST NAS 8TB
Optical Drive
Pioneer BDR 203
Corsair RM1000
EK Velocity D-RGB
MCP35x2
6x Gentle Typhoon AP-00
OCCOOL 240 Crossflow
Nemesis 120
Cubitek Magic Cube AIO
Operating System
Windows 10 Professional
ASUS ROG Swift PG278Q
QNIX 2710
Keyboard
Das Keyboard Professional
Mouse
Razer Mamba 2012
Mouse
Razer Goliathus
Audio
Swans M10
Audio
V-MODA Crossfade M100
i7 990x @ 4665MHz
ASUS Rampage III Extreme
MSI N770 2GD5/OC
MSI N770 2GD5/OC
Mushkin Redline Ridgeback 992057 6x4GB 1600MHz 7-7-7-24-100-1T
1TB Samsung 840 EVO
Western Digital Red 3TB
Optical Drive
Pioneer 8x BD-RW 24x DVD+-R
Optical Drive
ASUS DVD+-RW 24x/12x/48x
Corsair TX950
HardwareLabs Black Ice GTX 120
HardwareLabs Black Ice GT Stealth 120
7x Scythe Gentle Typhoon AP-00
Enermax Magma UC-MA12
Lian-Li PC-A10B
Operating System
Windows 7 Ultimate x64
2x Dell SP2309W 23" 2048x1152
Keyboard
Das Keyboard Model S
Mouse
Logitech MX Revolution Bluetooth and Razer Deathadder 3500
Mouse
Razer Goliathus Standard
Audio
Swans M10
Other
Netgear WNDR3700
zoson is offline
