-=LGA775 Club=- - Page 201 - Overclock.net - An Overclocking Community
-=LGA775 Club=-
post #2001 of 2010 (permalink) Old 01-14-2020, 07:34 AM
Retrorockit's Avatar
Rep: 28 (Unique: 13)
I'm having a problem with my Optiplex 380. One stick of my Gskills Ripjaws 2x4GB DDR3 1333 CAS7 died. RMA'd it and the new kit won't boot. I also got some Hynix DDR3 1333 2x4GB ( advertised as CAS6 at Newegg, but CAS9 at that [email protected]!) They won't boot either. I wonder if all the new RAM is high density x128, and the x64 I need is going to have to be old stuff? Reset the CMOS, set BIOS defaults, nothing runs except the old Kingston 2x4GB kit. Really unhappy because One of the old 4GB modules would run my itself. Now I have 0 4GB modules.
Dell Dimension E520 [email protected]
Delta GFB1212VHG, 8GB DDR2-800
R9-285 ITX 2GB DDR5, 240GB SSD
http://valid.x86.fr/l2j5p1
Retrorockit is offline
post #2002 of 2010 (permalink) Old 01-14-2020, 12:01 PM
Are you sure about that?
TwilightRavens's Avatar
Rep: 20 (Unique: 12)
-=LGA775 Club=-
The kit I used in my nForce 790i, you might be able to find somewhere, it worked flawlessly for me and is not high density RAM, G.SKILL F3-2133C9D-8GXL RipjawsX Series 8GB (2 x 4GB) should be the model to look for, lower speed bins of that kit should work without issue as well, i was able to get 1866mhz at cl8.
CPU’s I’ve owned: P4 630, P4 631, C2D E6320, C2D E6700, X3230, QX9650, X5470, i7 920, i7 3770K ES, Pentium 2020M, i5 4690K, i7 5775C, Athlon XP 3200+, Athlon 64 X2 1.8GHz, A10 4600M, Ryzen 5 2600X, Ryzen 7 3800X (soon to be)
GPU’s I‘ve owned: GeForce2 MX400, 8800GTX, GTX 285, 2 x GTX 660 SLI (sold 1), ATi x1300, R9 380, R9 290X, GTX 1070, GTX 1080.
AM4 (in progress)
(10 items)
Broadwell-DT
(17 items)
ASRock X570 Taichi
EVGA GTX 1080 Superclocked FTW
G.Skill TridentZ RGB 3600MHz 2 x 16GB
Samsung 970 Pro M.2 SSD 512GB
Seagate Barracuda 7200RPM 4TB
EVGA Supernova 750W P2
Corsair H110i v2
Operating System
Windows 10 Pro
Keyboard
Logitech G213 Prodigy
Mouse
Logitech G502 Hero Gaming Mouse
Intel i7-5775C @ 4.5GHz
ASUS Z97-E/USB 3.1
EVGA GeForce GTX 1080 SC @ 2126MHz
Intel Iris Pro Graphics 6200
Corsair Vengeance Pro DDR3 2000MHz (16GB) (10-12-10-29)
Samsung 850 Evo SATA III SSD 120GB (OS)
Seagate Barracuda 7200RPM HDD 2TB (Standard game and applications)
Crucial M500 SATA III SSD 960GB (fast load games)
Corsair RM850 850W 80+ Gold
Corsair H100i v2
Corsair Carbide Clear 400C
Operating System
Windows 10 Pro x64 1903
Sceptre 27" Curved 144Hz Gaming LED Monitor
19” LCD 1440x900 Dynex Monitor
Keyboard
Mouse
Other
ASUS PCE-AC56 PCI-E Wireless Express Adapter
TwilightRavens is offline
post #2003 of 2010 (permalink) Old 01-14-2020, 01:58 PM
Thanks for the reply but my old Opti 380 G41 only runs at 1066 RAM speed. 1333 modules and 1600 should be able to run that but IDK if faster stuff will go that slow. They sent me the same kit I had been running for 2 years. Not sure what's going on.
post #2004 of 2010 (permalink) Old 01-14-2020, 02:18 PM
Like a fox!
kithylin's Avatar
Rep: 86 (Unique: 66)
In my personal experience newer DDR3 that's designed to run on 1.50v for Dram voltage seems to be "hit and miss" in terms of compatibility for 775 platforms. Sometimes it works, most of the time it doesn't. Generally I have had a lot more success getting older DDR3 that originally was designed to run at 1.65v to work on 775 systems. Remember that 1.5v DDR3 came out after the "Sandy Bridge Era" and was designed for those computers and everything else that came after that still used DDR3. I know there is "low voltage" DDR3L designed to run at 1.5v, but that doesn't seem to work very well for 775 systems either. And pretty much any DDR3 you buy brand new today is all going to be 1.5v ram anymore. The only way to get older ram is to find an exact model number of older ram that you know worked at 1.65v and then find someone still selling that old ram new-old-stock, or buy it used online somewhere.
kithylin is offline
post #2005 of 2010 (permalink) Old 01-14-2020, 05:27 PM
I'm not seeing 1.65V. listed as an OEM Voltage for DR3. Just aftermarket overclocked parts. My Dell is only going to be running at 1.5V. 1066 speed due to the locked BIOS.
But the RAM that was working for me was purchased in 2015. The same part# now isn't working. So something does seem to be different. Nemix RAM sells Dell rated memory, but I haven't looked for 4GB modules that won't be listed for the Opti 380 anyway. Officially it only supports 4GB RAM. I'll see what Gskill has to say.
post #2006 of 2010 (permalink) Old 01-14-2020, 05:41 PM
771on775 user,Complainer
schuck6566's Avatar
Rep: 102 (Unique: 63)
schuck6566 is offline
post #2007 of 2010 (permalink) Old 01-14-2020, 05:45 PM
I'll see if they can send me a set of those.
post #2008 of 2010 (permalink) Old 01-16-2020, 09:08 AM
Gskill just wants to send me some CAS9 1066 RAM. I'd rather have my single good stick of CAS7 back. I suppose it's all they have.
Nemix RAM sells some Dell Optiplex RAM and it's 1rx8. The Hynix that also isn't running is 2rx8. So that's the only indication I have for a solution.
post #2009 of 2010 (permalink) Old 01-16-2020, 05:33 PM
Like a fox!
kithylin's Avatar
At least it's actually 1066 ram that the system was designed for. That should (in theory anyway) be optimal for that system in terms of compatibility.
kithylin is offline
post #2010 of 2010 (permalink) Old 01-16-2020, 07:10 PM
I paid for CAS7 DDR3 1333 and it worked fine at 1066 CAS7. With a locked BIOS CAS latency is the only RAM performance spec I care about. [email protected] sucks.
I just got in a Dell X48 motherboard that runs 1333, and maybe even 1600 DDR3 with 400fsb enabled. No idea if these modules will work or not. Maybe I should throw it in a machine just to see if these modules will work with that MB before I send them back.
