Overclock.net - An Overclocking Community
Overclock.net - An Overclocking Community (https://www.overclock.net/forum/)
-   AMD Drivers and Overclocking Software (https://www.overclock.net/forum/70-amd-drivers-overclocking-software/)
-   -   GPU Tweak voltage control limit (https://www.overclock.net/forum/70-amd-drivers-overclocking-software/1248620-gpu-tweak-voltage-control-limit.html)
Sapientia 04-25-2012 09:35 PM
So I recently got the asus 7970 DCII. When I went to OC it, I noticed the furthest I could go with the voltage is 1060mV. OCing range enhancement is checked. What am I doing wrong?
TheJesus 04-26-2012 01:58 AM
What OC software? Afterburner, Trixx, or what?
pat031 04-26-2012 04:33 AM
Maybe you did not push the APPLY button. I did not push apply and only click the check.
The screen goes black 1 sec after yu did apply.
Maybe i'm wrong
Sapientia 04-26-2012 10:02 AM
Sorry, I thought it was more apparent. This is in GPU tweak. I tried AB, but the voltage control won't work in that either, with it checked in settings.
Maybe i'm wrong
The screen reset when I applied the overclocking range enhancement, which I did hit apply to.
TheJesus 04-26-2012 10:16 AM
Hmm, I haven't had any issues with AB. Did you try the most recent 2.20? What do you mean it won't work? Just won't slide further or won't apply the settings?
Sapientia 04-26-2012 10:44 AM
Yes, this is with 2.20. The voltage slider is grayed out, I can't adjust it. I enabled voltage adjustment in settings, but that didn't change anything. Should I try a beta version?
TheJesus 04-26-2012 10:47 AM
Make sure the following are checked:
Enable low-level hardware access interface: kernel mode
Unlock Voltage Control
Unlock Voltage Monitoring
Force Constant Voltage
Then also go to C:\Program Files (x86)\MSI Afterburner\MSIAfterburner.cfg :
UnofficialOverclockingEULA = I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
UnofficialOverclockingMode = 1 (PowerPlay features enabled) or 2 (Powerplay features disabled)
See if it works then.
Sapientia 04-26-2012 11:02 AM
All of that, and I still get this:
417
Masterchief3k 04-26-2012 12:31 PM
I get the same thing on mine, the card automatically adjusts it's voltage based on load, i'd rather not want a constant voltage = extra heat in idle, but this lack of voltage control hampers my possible OC ability. I can't get 1 GHz and i should be able to.
TheJesus 04-26-2012 02:24 PM
417
Uninstall AB, delete all profiles/settings when it asks, reboot. Install AB, run, reboot when it needs to detect, change all those settings, reboot one more time just for an extra party, now try.
I don't think I had this much trouble and I have 7950s, lol.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
