1 - 20 of 58 Posts
Hi
my system flow 0.6 GPM is to low?
1x cpu block Alhacool
1x GPu block Alhacool
1x rad 360 Alphacool XT45
1x VRM water block EKWB Mainboard
1x Northbridge EKWB Mainboard
Pump ddc-1t 106 galon/hour with reservoir 150ml
All system use 0.8liter water
Maximum water temp 50C
AMD FX-8350 4Ghz
ATI HD7950 overclocked edition
buy new pump DDC 3.25 238galon/hour or D5 396galons/hour or Innovatek Eheim PCPS 12V Pump + AGB? 317galon/hour
or 2xDDC dual top 2x 106galon/hour
or new rad 2x360 or alphacool Monsta 1x360?
Thanks to help
Casual Watercooler
You probably have a restriction somewhere in your loop. If your pump has a normal flow rate of 106 gal/hour or 1.77 gal/min, and right now you are registering only 0.60 gal/min, there is a definite blockage somewhere.
On the other hand, the DDC pump may not have enough pressure to overcome those blocks. You could go with the dual top for added insurance. My personal preference is to go with the D5 pump: good workhorse, huge flow rate, and a rock solid performer.
Overclock Failed...
Some questions and observations:
How are you determining flow rate?
Water temp 50°C, If that's true, I'd shut it off and throw it away!
Maximum water temp should be no more than 10°c above ambient temp, 5° would be typical, 2° would be very good.
How are you measuring water temp?
The flow rate specs you list for the pumps have nothing to do with how much water they will move through the restrictions in a WCing system. Those are the flow rates for unrestricted flow. Google pump PQ curve.
Here's the PQ curve for your pump from Martin's Liquid Lab's testing.
Hi,
First question
Flow meter use Koolance
http://koolance.com/dcb-fm01-flow-meter-adapter-with-display
http://koolance.com/ins-fm16-coolant-flow-meter
Water temp using water temperature sensor in reservoir
http://www.alphacool.com/product_info.php/info/p434_-Temperature-sensor-G1-4.html
Scythe kaze master 2
Radiator is wery hot.
Problem is VRM mosfet in mainboard is very hot
Laser meter VRM temp is 80C ferrite core is 100C max core cpu is used.FX8350
VRM is water cooled very quickly increases temperature water.
Is possible buy D5 EK Water Blocks EK-D5 Vario X-RES 140
+ use ddc set EK Water Blocks EK-DDC 3.2 PWM X-RES 140
in one system and one radiator to serial connection?
first, what fans are you using? that 360 rad should cool a little better than that.
second, you have another thread already saying you have a d5 on its way.
2x ddc-1t with a (or 2 good) tops works well. yes in a single loop running pumps in serial.
can you put up a picture of your loop? something doesnt sound right.
so you only have the 1 ddc-1t pump right now, correct? do you already have an aftermarket pump top?
send @bmaverick a pm here or go to his website and ask how much to ship a new ddc-1t to you. i dont know where you are.
i am using 2x ddc-1t from bmaverick. also using the swiftech 35x2 top with res. i run my pumps about 9v (probably less because of fan controllers 'losing' voltage) and my temps are absolutely fine.
you really should have another radiator. 1x 360 cooling a 'hot' gpu plus a HOT cpu plus vrm that get hot. and you are using low rpm fans to try to rid your rad of that heat. i would get another radiator or faster fans(rad would be better) and check with bmaverick about a second ddc-1t.
both billbartuska and ninhalem are right and wrong.
a d5 instead of a ddc wont improve anything in your loop. adding will improve it of course.
10* over ambient is good, IF you have an ambient of anything less than 35*C. this is the number most people shoot for being maximum, 10*C ambient/water delta. a delta of 2*C is 'hardcore' water cooling. basically, as long as your temps under load are better than air and its quieter, you have spent money to water cool for a reason that was 'justified'.
if my ambient is 18*C and i have a delta of 20*C, thats a water temp of 38*C which is fine. as long as water temp is not 50*C you are fine. most water cooling gear is only rated to 50*C.
*edited*-saw you upped the pic-
clean the dust off your pilters please! how much room do you have between the fans and the case? looks to be about an inch.
and yes you do have an aftermarket top. what pump top is it? which is first after your pump?
Discussion Starter · #11 ·
New idiea:
not buy D5 pump
buy new radiator
Change Alphacool Radiator XT45 to bigger
1. Alphacool Monsta 360
or
2.XSPC RX360 V3 Price is same 108Euro
When is not good flow and temp
+ change DDC pump to D5pump
Next pc brother AMD 6core
use ddc pump and xt45 radiator
I have time to Monday change order.
you wont see a difference changing radiators. it will be a SMALL difference. the same with changing pumps. it will be a small difference.
reread post #8
what is your vcore under load?
thats a lot of voltage. you should be looking at adding a radiator.
restriction (more pumping power), voltage (is quite a bit), rad space(for your rpm)
pick 2(or 3)
add another pump to overcome restriction, lower vcore, add another radiator and/or add fans/change them out for higher rpm fans
all just my opinions though. the only way i see to lower your temps.
what is your ambient temp anyway? this will say a lot also.
1: Run two pumps in serial, the DDC-1T has excellent power/performance, and is a good budget pump but with chipset and northbridge cooling on top of a CPU and GPU waterblock you're likely pushing the limits of a single DDC-1T. You don't necessarily need two DDC-1Ts, you could put a D5 and a DDC in the same loop, both pumps will have a higher nominal flow than what you'll be getting, meaning one wont bottle neck the other.
2: What are your ambient temps? A 3.120mm will run hot with that setup, but 50c is WAY too high for that setup which means one of two things, you have a high ambient temp or something is preventing it from cooling properly. I highly doubt your ambient temps are above 30 celsius or you'd be sweating profusely just by being the same room. Check to make sure your radiator is clear from dust buildup, that's going to be a huge factor for preventing your radiator from cooling properly.
3: Add radiators. I know I said that other rad should be cooling better, but even then a single 3.120mm rad is a little low if you're trying to push some overclocks like you are.
4: It's hard to tell just by pics but it seems like your rad is REALLY close to your chassis, meaning that may be obstructing airflow. You could either use some larger spacers, or drill 3 110mm diameter holes in the top of your chassis and push the rad flush with the chassis, allowing it to vent directly into the chassis.
I have not seen any testing on how accurate the Koolance flow meters and adaptor is, but seeing as 4 different sensors can be used without any sort of adjustment it would suggest that they might not be all that accurate.
The Aquacomputer models have very different settings for different models and even different settings for the diameter of tubing being used in the system.
The DDC1T is one of the lower power pumps for the number of blocks in the system though.
Koolance flow meter display is adjustable. It selects which flow meter automatically, and you use a little switch to select tubing diameter, it's just hidden behind the drive bay mounting plate.
The recessed switches and what not are hidden behind the drive bay mounting plate.
Ah, OK then I was totally wrong. Thanks for that, I had never heard that before.
It just seems surprisingly low flow.
It does seem pretty low.... OP might want to take his waterblocks apart to be sure something isn't blocking the flow, but then again he is running 4 different water blocks on it. I'm not sure which chipset and NB waterblock he's using but they can very between very low restriction, and the same amount of restriction as a CPU block. But then again AGAIN martins tests would indicate he needs 5PSI pressure drop to be @ .6GPM...
So yeah, OP you might want to drain your loop and inspect the waterblocks and what not to be sure they aren't clogged up.
1 - 20 of 58 Posts
