1 - 20 of 21 Posts
well this is the best i could come up with
cpu: E5200 @ $64.50
http://www.newegg.com/Product/Produc...82E16819116072
Mobo: Foxconn G31MV-K @ $41.99
http://www.newegg.com/Product/Produc...82E16813186145
Ram :G.SKILL 4GB @ $81.99
http://www.newegg.com/Product/Produc...82E16820231207
Monitor:Acer X193Wb Black 19" @ $114.99
http://www.newegg.com/Product/Produc...82E16824009151
Dvd drive:LG Black @ $25.99
http://www.newegg.com/Product/Produc...82E16827136177
Psu:OCZ Fatal1ty 550w @ $64.99
http://www.newegg.com/Product/Produc...82E16817341022
Keyboard:Saitek PZ30AU Black @ $33.99
http://www.newegg.com/Product/Produc...82E16823175103
Gpu:SAPPHIRE Radeon HD 5770 1GB @ $164.99
http://www.newegg.com/Product/Produc...82E16814102864
HDD:SAMSUNG HD502HI 500GB @ $49.99
http://www.newegg.com/Product/Produc...82E16822152137
Case:Thermaltake V3 Black Edition @ $49.99
http://www.newegg.com/Product/Produc...82E16811133094
Os: Microsoft Windows 7 Home Premium @ $109.99
This comes to a grand total of $808.40 without shipping
i choose a hd 5770 over the hd 5750 as i thought you wanted better but you could pick the hd 5750 and save $20 you also get a free 4GB mem stick
hope i helped
cpu: E5200 @ $64.50
hope i helped
I posted this in the AMD Build Logs subforum because I wasn't looking for a bad Intel build.
I'd much rather go AM3 and use DDR3.
Some of your links don't work.
That keyboard is too expensive.
I'd much rather have a 7200RPM HD as apposed to 5400RPM HD. I could get a converter and put my WD5000BEVT into this build if I wanted a 5400RPM HD.
Also, the monitor is pretty low end. I'll go over my budget if it means getting a much nicer monitor.
Discussion Starter · #9 ·
^ I don't need a G11 or a G15. Besides, it's way out of my budget.
Originally Posted by Afrodisiac
Looks nice. Too bad you can't fit a proper Phenom II in that budget. If you can stretch, 550 or 720 >>>>>>> Athlon II.
Well... $30 is a bit out of budget. If someone could inform me as to the performance levels of the 550, 720 and 250 then i'd better be able to make a decision.
Discussion Starter · #11 ·
Originally Posted by toyz72
i just built 2 different systems ,and had much better parts.if you use newegg you get all kinds of rebates.you can build a pretty nice system for a grand.
Thanks for contributing.
Originally Posted by T D View Post
Looks good. Technically you can't use a Win 7 Upgrade since you're not upgrading from anything though. I would look for those threads on OCN where people were selling OEM Windows 7s with USB sticks for $50 or something.
You can do a clean install with the upgrade disk. Just takes a little bit of tweaking.
Blue and Green Team!
1 - 20 of 21 Posts
