1 - 7 of 7 Posts
11900k, 4000mhz 15-16-16-36, 3090 ftw3 ultra, 3 firecuda 520 2tb, 2 4tb firecuda 120, aorus z590 XWF
Ok been messing around, and think I found a problem. Hope I am wrong. I have 1/2" with 5/8" Compression. I am using 7/16 with 5/8 od. am I wrong for doing so. I dont seem to be able to get the Compression to screw down?
It will not screw down all the way. Just get it snug on the fitting. If you try to tighten it all the way, you will have to use pliers to get it back off. I'm guessing you used hot water to soak the 7/16 to get it on the 1/2 fitting then.
No not yet, i got pretty good a getting a 7/16 on a 1/2. but never used compression. kind of wishing I would have went with 1/2 x 3/4. and same with compression now. But I cant re order all the fitting now. so I am stuck with this build as 1/2x5/8 compression fittings and 7/16x5/8 tubbing.
It shouldn't be a problem provided you can get it pretty tight since it's a compression fitting. Doesn't necessarily need to be screwed down completely.
Discussion Starter · #6 ·
yeah the compression fittings are just for looks, I been running my loop now for about a year now with 1/2 barbs and 7/16 tub with no clamps and not one leak yet. but I like the look of the compression fitting. I just heated the tube up in really hot water and it let the fitting close about 1/2 the way or little more, so not bad, like the look but like the look of it almost closed better.
1 - 7 of 7 Posts
