1 - 4 of 4 Posts
Which would be better to go with in a WC system? I was thinking 1/2" tubing because it would bring more cold water to my CPU.
<tr>
<div>
Originally Posted by <strong>beret9987</strong>
</div>
<div style="font-style:italic">Which would be better to go with in a WC system? I was thinking 1/2" tubing because it would bring more cold water to my CPU.</div>
</td>
</tr>
</table>
</div> Use 1/2 fittings with 7/16 tubing..It's the best of both worlds, flows about as well as 1/2 but is a lot easier to work with..This is what I use.....<a href="http://www.dangerdenstore.com/product.php?productid=238&cat=33&page=1" target="_blank">Danger Den :: Tubing :: Tubing and Clamps :: 7/16" ID (5/8" OD) Masterkleer General Purpose Clear PVC Tubing</a>
yep, I use 7/16" ID masterkleer tubing and it works great, and is cheap!<br><br>
1/2" will give you greater flow then 3/8"
1/2" (or rather 7/16") Better flow, better look. I'm in love with the UV blue Primoflex. Cheap and good looks, it also doesn't kink easily.
1 - 4 of 4 Posts
