1 - 7 of 7 Posts
I recently ran blend test for around 3 hours before switching it off.
My setup:
i7 4790k (4.6ghz oc, 1.26v)
H100i
My avg temp looked to be around 70-75c but I seen like 3-5minute sections where it was going really high (must of been a part of the test??)
My cooler is seated etc. Using artic silver 5.
ONE CONCERN:
I half assed cleaned away the previous thermal compound, will this have any effect? Is it ok to clean this off with meths?
Are these temps normal for blend test prime 95 with my setup?
thanks.
My h100i seems fine, fans aren't going fast tho even though I bumped up the RPM in the BIOS. The tubes are not warm and both feel the same temp, can feel exhaust air coming out top.
thanks
I think it's very good indeed if you're running prime 95 and got the max temps 75 degrees celcius. Which version are you running at? Cleaning the old paste and replace it with a new one probably will give you an effect 1-2 degrees max.
hello friends...
i ran prime 95 for 3 hours now.. i reseated back plate because I didn't know that there was a side that made gaps for the mobo screws... haha
these are my results with latest version of prime 95 + 4.6ghz @ 1.255v i7 4790k
are these good or no /
Originally Posted by xTehJack View Post
hello friends...
Those temps are great at that OC.
Go Again!
hello friends...
Your temps look fine. They look very good for prime95 28.5 actually.
1 - 7 of 7 Posts
