Yeah, change it to 1.335v in bios.
Disable LLC?
Disable LLC?
Where would the LLC be?Originally Posted by BallaTheFeared;13016529
Disable LLC?
Load-Line Calibration, same place you'll find your voltages I would assume.Originally Posted by Vipr3;13016539
Im running tests right now on Intel Burn Test, and it hasn't changed since I started it. So it is actually at 1.376 and not 1.35 like it says in my BIOS?Originally Posted by BallaTheFeared;13016567
1.376 at idle, load it up with prime 95 and see if it goes up or down under load.
Alright, so should I turn LLC off or keep it on?Originally Posted by BallaTheFeared;13016587
Correct.
Sounds like you have too much load line compensation, either lower your LLC level or lower your voltage in the bios.
My LLC is on auto right now, what should it be at?Originally Posted by BallaTheFeared;13016587
Correct.
Auto, On, Off. Thats it.Originally Posted by BallaTheFeared;13016764
Do you have more options than on auto and off?
