1 - 20 of 27 Posts
so here lies the question. which is more efficient at cooling, 1/4" or 1/2"? i know it would probably have to do with the pump and all, but which in general is more efficient?
haha, i guess that solves my problem.. what kind of pump would you reccomend because ive heard that a buuunch of pumps dont even work right from the box
Danger Den D5 (MCP655) is the best pump out there right now.
Discussion Starter #6
nice. so if i got that tubing, that pump, all i need is a resevoir a radiator and a cpu block, correct? anything that you would reccommend?
For the CPU block, you cant do better than a Swiftech Apogee.
Getting a reservoir is a matter of personal preference. You don't even NEED one. Just get what will fit your case, there are many to choose.
There are two choices for your radiator: a watercooling radiator made especially for water cooling, or a car heatercore. The benefits of a heatercore is that it is a LOT cheaper and, in most cases, yields better performance. You will have to do a bit of modding to work with it though.
Id reccomend what i have in my sig
works wonderfully
you might not need a tripple radiator though
i like having the reservoir because it is alot easier to fill and is more efficiant IMO
Oh BTW the apogee is great becasue it preforms very well at any flow rate unlike the storm that needs high flow
GPU Block too?
Discussion Starter #14
yeah. i also heard that after a while you need to refill the resevoir.. does the stuff evaporate after a while? if so, how long does it take? (how long can it last without it being refilled?)
Discussion Starter #15
nah, i got a zalman VF-900 for the gpu, im not too worried about it really.
it dosent really evaproate but it mah have a very small leak and over a year or so you will have to top it up
ive had my setup for about a month and have noticed no difference
if your cooling your chipset i have one for sale
its a swiftech one for $19.99
Might want to fill in your system specs again...
What GPU are you runnin?
Yes, that's what it is. I forgot
Are you going to mod your case at all to accomodate for a radiator?
Discussion Starter #19
evga 7900GT stock 500/1500 OCed to 550/1600
Discussion Starter #20
nah, no case modding for me.. id be willing to make a couple screw holes, but thats about it
1 - 20 of 27 Posts
