1 - 18 of 18 Posts
Ok well I just got my new RAM, 3 sticks of this stuff: http://www.newegg.com/Product/Produc...82E16820141123
And on my boot screen it only says that it checked 1 gig of memory...says the same thing in windows. However CPU-Z recognizes that there is a module in each slot...
So I'm thinkin are one of my sticks dead? or do I need to do something to make it recognize over one gig of RAM?
UPDATE:
Ok I don't think any of the sticks are dead...
I shut off my PC and took out the third stick to see if it would still read 1 Gig (i.e. to see if the third stick was dead)
Booted up, it read 1 gig, as if my third stick was dead.
I took out the second stick, and replaced it with the third stick, which if the third was dead, would make it read 512MB.
It still read 1 gig. So all my sticks are fine...
Discussion Starter #6
Originally Posted by metalkobra
try it in a different slot.
Yeah I think I'll try switching the DIMM modules around. With my old RAM setup with one arrangement it wouldn't boot with another arrangement it ran fine...
Discussion Starter #9
Originally Posted by bentrinh
Your mobo doesn't support that much?
Memory
Number of DDR Slots 3x 184pin DDR
DDR Standard DDR 400 (PC 3200)
Maximum Memory Supported 2GB
Nope...interesting, I shuffled around the sticks for a while, didn't help. Then I took the stick out of the first slot...and it only picked up 512MB.
I reset BIOS...no avail.
Makes me think there's something wrong with the third slot...but I was runnin 3x256MB sticks before. Two of them were PC2700, one of them (the one in the third slot) was PC2100 running at PC2700 speed.
Idk I flipped through BIOS it doesn't have almost anything as far as RAM goes other than overvoltage/overclocking.
Discussion Starter #11
Originally Posted by SVT_Cobra
My Gigabyte Mobo doesn't support 3 sticks. 1, 2, or 4. Perhaps yours is the same way...
It only has 3 slots...
Also, I said I was running 3 sticks fine earlier.
Discussion Starter #12
Another update:
I just put my old 3 stick setup back in...it detects all 768 megs of it...what the hell??? So nothing's dead it looks like, my board just doesn't seem to wanna recognize the stick in the third slot for some reason...even though the stick is fine...
GA-8I848P775-G Motherboard - 14 -
English
The motherboard supportsDDR memory modules, whereby BIOS will automatically detect memory
capacity and specifications. Memory modules are designed so that they can be inserted only in one direction.
The memory capacity used can differ with each slot.
Before installing the memory modules, please comply with the following conditions:
1. Please make sure that the memory used is supported by the motherboard. It is
recommended that memory of similar capacity, specifications and brand be used.
2. Before installing or removing memory modules, please make sure that the computer power
is switched off to prevent hardware damage.
3. Memory modules have a foolproof insertion design. A memory module can be installed in
only one direction. If you are unable to insert the module, please switch the direction.
1-4 Installation of Memory
D
ouble Sided DIMM S:Single Sided DIMM
X:Not Use
DDR1 DDR2 DDR3
S S S
D S S
D D X
D X D
S D X
S X D
This is the listing from your owners manual.... Is your new ram double-sided? it doesn't show support for D D D
Discussion Starter #14
GA-8I848P775-G
I'm running Socket 478, but yes, it is double sided. The RAM I had in before was single sided.
That seems to explain it though, nice find.
But now I'm really mad that I have a 512 stick that I don't know what to do with!!!! I'm wondering if I should just leave it in there maybe as a spare or something...or buy a new board or what?!? argh! I wonder if I could BS an RMA to Newegg...
Yes it does explain it. Glad I could help...
I guess you could try the rma process but there is nothing wrong with the memory... Perhaps you could just sell it to someone on this site or some other. Or, as you mentioned, you could keep it as a spare... All good ideas
Yeah that's the thing with ddr... no more than two double sided sitcks on one channel. So duel channel not only allows double the bandwith but also double the sticks.
Discussion Starter #17
*throws at wall* now there is!!!!
Haha well also my friend has a nice ECS socket 478 motherboard (865 chipset) that has 4 slots, I'm wondering if I should buy it off him, probly run me about $40. Really don't know if it's worth it. I guess I'll stick with my one gig for now, and maybe tinker with overclocking
As a stock board it might be okay. But in my experience ECS boards are not worth ANY money. They are:turd: for any kind of tweaking. I have heard they are getting better, but that wouldn't include anything more than a couple of months old...
1 - 18 of 18 Posts
