1.5 K Core i7 Build
4308 Views 67 Replies 17 Participants Last post by  FSF-Foxhound
Hello OCN, im building a new 'puter. Budget is 1500 dollars.. (Dollards hurr)
I can go a bit over. But not by too much D:
Nothing is bought yet.
The parts consist of..
Intel Core i7 920
1 X GTX 295 CO-OP
6GB DDR3 1600 MHz Memory from G.Skill
GIGABYTE GA-EX58-UD4P
Corsair 750 WATT PSU - Purchased
Prolimatech Megahalem - Purchased
HAF-932 - PURCHASED
Windows 7
Thats about it.
TOTAL: $1,169.96
This is my second core i7 build, other broke due to a heatsink issue.. dont want to talk about it much... 2 dead GTX 295s..
Any tips or suggestions, please tell me!
1 - 20 of 68 Posts
Intel Core i7 920
XFX GTX 285
6GB DDR3 1333 MHz Memory from Corsair
ASUS P6T
Rosewill 600 WATT PSU (hope its enough D
Cooler Master Hyper N 92MM CPU cooler..
Samasung 22' monitor (1680 by 1050)
WD 750 GB HDD (1TB + hard drives are usually unreliable..)
Sunbeam Transfer Black Steel ATX full tower case..
Windows Vista Home Premium i64
Thats about it.
This is what i came up with quickly using your budget. Please don't kill another system using that rosewill PSU.
Swap out that Rosewill PSU for a reliable one.
Corsair, PCP&P, Antec, and Silverstone are all trustworthy manufacturers.
thanks for the tips... dang, i'd love to give you both rep.. but.. you dont deserve it mwhahahahaha.
anyway, thanks. Can i get a newegg link for a good one? (WARNING, MY BUDGET IS BENDY)
Go atleast 1600MHz on your ram
Here you go.
http://www.newegg.com/Product/Produc...orsair%20750tx
No thank you about the RAM, i will overclock it if i really want it. Plus, DDR3 is not the best right now, so im not going nuts over it.
no seriously you are gonna want at least ddr3-1600 http://www.newegg.com/Product/Produc...82E16820226030
Also, anything cheaper :S I really dont want to go over 1.6 K... I really need a cheaper PSU.
@ microman I will always improve on my computer. Im waiting for 2GHz DDR3 or something.. I dont like going in small steps.. Its like what i did.. 9800 GT to 2 GTX 295s. That sorta thing.
Yeah its really cheap. But im looking around 70-90.
http://www.newegg.com/Product/Produc...82E16817256049
Here is a quality Silverstone 700 which is 120 before MIR and only 99.99 after. Please for the love of god dude spend a little bit more on the PSU..do it for US!!!! DO IT FOR OCN!!!!!!!!
lol. and NO microman, IM not spending that little of money on a Graphics card.
And forget the PSU.. The one you sent is more expensive D: AND i do not want to do a MIR.
Any thing a bit lower? Ill settle for 80.
huh???my GPU solutions smacks the **** out of what you had posted
What? The GTX 285 is slower than the 260? Get out lol
Also, can i get a link for that G-Skill memory.
If you want to cheap out, its better to get a solid PSU and a Phenom II build than a GTX 285/Core i7 and run it off a 60-dollar Rosewill power supply. Seriously, your priorities are wrong, GET A GOOD POWER SUPPLY GET A GOOD POWER SUPPLY GET A GOOD POWER SUPPLY GET A GOOD POWER SUPPLY. There.
His SS showed 2 GTX 260s, and GTX 260 Core 216 SLI will assrape anything except GTX 285 SLI.
1 - 20 of 68 Posts
