1 - 7 of 7 Posts
what is the recomended temp for a s478 1.8 celeron?
would you say 40c is to high when idle?
intel active monitor goes nuts under load.
iv had to up the sensor thresholds to 55c so i dont get error messages!
is my dads pc, so no care is taken of it by me, i opened up the case and gagged with dust. there was dust clogging the cpu and there is only a crappy 70mm intel hsf keeping it cool. i added a 80mm case fan to help with internal airflow, but i doubt it`ll do much good.
hmm i think a good clean inside would help, id recomend (if you dont wanna take stuff apart) some compressed air in a tin and a hoover sucking up the dust that comes out (DO NOT PUT THE HOOVER NOZZLE IN THE PC!!) ive blown a PC doing that lol
1 - 7 of 7 Posts
