1 - 9 of 9 Posts
Cuddly as a Cactus
I'd go 5770, unless you're a hardcore gamer. It'll do you just fine
Originally Posted by hargybargy
can you pair a 4850 and a 4890?
Yes you can but it will be like your running two 4850's because everything adjusts to the lower cards specs, And since the 4890 has 1GB if your 4850 has 512mb that will also be cut down so they both run at 512mb, Not worth it in most cases...
Originally Posted by ablearcher
The HD5770 is inbetween the HD4870 and the HD4890.
Fixed.
1 - 9 of 9 Posts
