Hi guys,
Im currently building my new rig. Its got an i9 7900X in it so I need some serious cooling. I had settled on the following, however whilst in the process of modding my case, i have seen that there is easily enough room for a second rad in it, 280mm with enough room for push pull, could be a 60mm rad as well. In the front.
My question is, given the current parts below, could the pump/res combo have the cuts to handle a second radiator in the loop?
And next question, would this really benefit me in the way of cooling capacity?
Thanks
Radiator: EK CoolStream XE 360
Pump/Res: EK XRES 140 Revo D5 PWM
Tubing: EK Matt Black 16/11
Fittings: 6 x EK ACF Fitting 12/16mm - Black
CPU Block: EK-FB MSI X299 GAMING PRO CARBON RGB Monoblock - Nickel
Radiator Fans: 6 x EK Vardar EVO 120ER Black (2200RPM) PUSH PULL
Coolant: De-Ionised Water & Biocide
Thanks
