1 rrod help
6501 Views 17 Replies 12 Participants Last post by  iFresh
my friend has an xbox 360 but only has 1 rrod and needs help so ny clue on what to do.
1 - 18 of 18 Posts
call microsoft send it in for replacement.
usually if its 1 spot its a specific hardware failure tell him to switch out his comp cables for hdmi... If possible, or vice versa. If he cant or if that doesnt work he will have to wait for a replacement.
Originally Posted by krazyd007
he dont wanna wait for a replacement
Well it would be the wisest decision. If he tries to fix it himself there is no garrentee that it will work. If microsoft does it you'll know it'll be done right, and no warranty loss.
Okay, here is what you do:
1. First off, is there an error code on the screen?
* If above is true, then your boned that is the only way to fix it.
2. If above is false, then doing the x-clamp fix will do it.
3. How do you have your 360 situated?
4. Do you use the intercooler?
*If you do, take that damn thing off, it makes the 360 get hotter than usual.
5. How often do you spray a can of air into the back of the 360 to dislodge any dust and stuff?
Just answer these and I/we may be able to help you out.
If it goes for warranty make sure you dont forget a disc in it,my friend sent with one and couldnt get it back.
Dont do the towel trick, only temp fix, and can cause more damage then it is worth...
Originally Posted by xxicrimsonixx
dont do the towel trick, only temp fix, and can cause more damage then it is worth...
+1
1 Red Light is not covered by the three year warranty.
I love how half the people here are acting like it's going to be solved like the 3 lights get solved. That's not going to work.
E74 is an AV cable error. Try unplugging it and plugging it back in.
Also, the ANA chip may have a problem and will need to be repaired unless it's out of warranty which you're out of luck or do the ANA fix.
1 red light is not the RROD most people get their xboxes fixed for...
visit here to get some idea of what the problem may be.
I just sent my xbox with 3 light RROD last thursday? and it's already on its way back to me.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
I'd say best way to find out is to just call xbox up and ask them.
Here. Do this and post the error code
Hold down the eject button and the controller sync button until the read light flashes much faster than usual. Now push either the eject or the sync button (I do not remember which) and record how many red lights you have. Remember, the first number in the code will be when the lights start blinking fast.
Here is how you figure it out:
4 lights: 0
1 light: 1
2 lights: 2
3 lights: 3
So if you get 4142 then the code is 0102.
May not be covered by 3 year warrenty, but if it still is in 1 year of manufacturer date, it is coverd...
To OP, if you need a new Xbox, I got one available
True, but it almost seems like it's not covered since I'm pretty sure this problem doesn't occur on newer consoles.
1 - 18 of 18 Posts
